Like Tree46Likes
Old 02-01-2010, 10:27 AM   #2041
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by nascarfan3199 View Post
quick question, does the gt2.0 lpf come with a programmer? i recieved mine today w/o one
Where did you buy it from?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-01-2010, 10:30 AM   #2042
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
brand new mine did as well as the pro version.
Is there any issue using the older style programmer (V1.1) on the 2.0 series? Seems its just the numbering is different thats all.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 02-01-2010, 10:33 AM   #2043
nascarfan3199's Avatar
Here on rctech. But the box was factory sealed and the seals werent broken.
nascarfan3199 is offline   Reply With Quote
Old 02-01-2010, 10:37 AM   #2044
abailey21's Avatar
email me your address [email protected]
K.C.C.O.
Old 02-01-2010, 10:37 AM   #2045
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by abailey21 View Post
all of the sensors in the V3 motors are the same
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 02-01-2010, 10:45 AM   #2046
what software vesion does the esc come with from the factory, also i need the lcd programer to update software correct? thanks for the help
Old 02-01-2010, 10:55 AM   #2047
qcrc's Avatar
The 1.1 and 2.0 boxes are different.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 02-01-2010, 04:43 PM   #2048
mr crum's Avatar
Send a message via Yahoo to mr crum
the 2.0 comes with 205g and yes u need the lcd box to change software
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 02-02-2010, 02:45 AM   #2049
guinnes.s's Avatar
Originally Posted by Solara View Post
I used 4.8 final drive with the original or novak type 13.5 motor on a 40x100 footer track...not a problem, with very good speed.
Here is the thing you need to try.....your 7.7 final is WAY OFF...try 4.8 with your motor timing (the timing on your phyical motor) set to the middle...then keep gearing up untill you like the speed. I know the V3 13.5 ran alot cooler then any other 13.5 so gearing up is not a problem.
But if your track is REALLY tight (you never say how small is your track...) gearing up does not makes your any faster...you need punch and corner speeds....
yes i need punch out of corner,this is the track
http://www.youtube.com/watch?v=gBZgz9AFNfs
and up against GM ESC's
is it possible to flash the firmware on SP GT 1.1 ???
guinnes.s is offline   Reply With Quote
Old 02-02-2010, 04:20 AM   #2050
razzor's Avatar
Cant flash the GT 1.1 unfortunately.
If needing more punch might be an idea to lower the timing a bit and up gearing to make up for lost speed.
If you can post you settings we could possibly help more.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-02-2010, 05:01 AM   #2051
guinnes.s's Avatar
punch and timing are at max and 7.6 fdr.
ps regarding the flashing
http://www.rceasy.com/2008/04/04/spe...sc-version-11/.
Old 02-02-2010, 05:57 AM   #2052
razzor's Avatar
like i mentioned earlier try reducing the timing to around 18 and then check motor temps and if its cooler than currently then gear up a tooth or two.
also try DRSS at 6 or 7. I dont find the higher DRSS settings to be any punchier. Also if your motor has adjustable timing then reduce timing on the motor and run max timing on esc. unfortunately that is all i can suggest. To get faster you would have to look at getting a newer esc.
Casterracing ZX1.5R
Old 02-02-2010, 10:39 AM   #2053
mark79's Avatar
Can someone give me a quick run through on how to change the timing on my V3 13.5 motor.
Just in case i do something wrong
AE RC8.2 powered by Picco Boost.
mark79 is offline   Reply With Quote
Old 02-02-2010, 10:44 AM   #2054
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Just Loosen the 3 motor screws, tap the shaft a little then you can move the timing sensor. tighten up the screws, then you are good. Here is a vid to show how you take a V3 motor apart.
http://www.youtube.com/watch?v=6iFTO54uGM0
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 02-02-2010, 12:09 PM   #2055
Solara's Avatar
Trader Rating: 16 (100%+)
Those are the prototype wording of the speedo almost 2 years ago. The actual 1.1 does NOT have the USB update feature cause that was used on the later GT2.0 version instead.
The V1.1. just cannot have the GT2 software update and the verion on the April 2008 V1.1 speedo or later has the latest 1.1 software already, there were no more update after that on V1.1.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
