Old 01-30-2010, 12:58 PM   #2026
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Originally Posted by TryHard View Post
Yeah, I've been debating this... it is a pretty tight fit, and the speedo is pretty far off the edge of the chassis. Aslo, if I put the heatsink on, there isn't a huge amount of clearance, certainly not enough for the pins too pull out fully from the holes.
For now, I'll run it as is, and if it does come apart, then figure out how to keep them together, without resorting to super glue
Ed
Instead of superglue what about hot glue.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-30-2010, 02:31 PM   #2027
Smile
Ed
I'd try Teflon thread seal tape, the type that you use to stop water leaking out of connectors in pipes. It only sticks to itself so won't do any permanent changes and its not going to be affected by the temperatures we get to. I love it! Otherwise I can also recommend dental floss. I use both of these in my day job as a Low Temperature physicist and can vouch for their performance below 1 mK.
Rocking Donkey is offline   Reply With Quote
Old 01-30-2010, 02:46 PM   #2028
razzor's Avatar
shoogoo should also do a a good job holding it together and can be removed pretty easy.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-30-2010, 02:52 PM   #2029
AdrianM's Avatar
The old standby has always been heat shrink tubing. You can get it in any size you want if you look around. Some LHS used to carry bigger sizes to cover sub-c cells and complete packs.
Adrian Martinez
Old 01-30-2010, 03:15 PM   #2030
irgo's Avatar
Ed
gap is the best for cooling temps by enough air room
for the bottom fet that has no heatsink
that should not reduced
The top pcb is quite heavier than the bottom pcb,
if this can be inverted
it will also great for Low CG, but requires new Heatsink
like teamwave heatsink have it cools the bottom wafer.
Quark Force
irgo is offline   Reply With Quote
Old 01-31-2010, 11:29 PM   #2031
Goingfast's Avatar
Trader Rating: 29 (100%+)
Default Timing Sensor
I have 17.5 V3 speedpassion...my Timing sensor plug in the motor got damaged..
Question about the V3 speedpassion motor sensor,17.5 are the same sensor as others? Will the mod V3 sensor works in my 17.5motor ?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 01-31-2010, 11:32 PM   #2032
HappyHippo's Avatar
Any one tryet 2,0 gt LP speedo in 1:12 scale and witch software is the best for 12 scale racing?
HappyHippo is offline   Reply With Quote
Old 02-01-2010, 02:07 AM   #2033
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
1 cell LiPo or 4 cell nimh? I run 1cell LiPo and have only been able to get the 312 to work in 17.5 motors, 323 or 312 with 13.5 motors. The newest 'stock' software does not work with 1 cell even when you turn off the 'bat protection'.
TryHard seems to be having good luck with 4 cell nimh with the 107 and 110? He described his results back a couple pages....
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 02-01-2010, 04:47 AM   #2034
eceer's Avatar
Hi All, Would any one know the optimal temperature range for the "Competition 3.0 - 17.5R"? I installed the new stock software over the weekend and was getting temps around the 85C mark. This was running without a heat sink or fan. Which I'm going to install for next meeting. But if someone says that the temp is fine then I wont bother.
Thanks in Advance.
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 02-01-2010, 06:51 AM   #2035
gramm's Avatar
Can someone suggest a starting roll-out for my SP Competition 3.0 10.5R in 1s World GT? Track would probably be described as a regular size carpet track. Oh yeah, speedo is a regular old sphere TC spec. Thanks
Cheers
Daniel
Last edited by gramm; 02-01-2010 at 06:54 AM. Reason: forgot the all-important esc info
gramm is offline   Reply With Quote
Old 02-01-2010, 06:55 AM   #2036
abailey21's Avatar
Trader Rating: 36 (100%+)
all of the sensors in the V3 motors are the same
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-01-2010, 09:16 AM   #2037
Solara's Avatar
Originally Posted by guinnes.s View Post
what about the timing on the motor?leave it in the middle settings?
thanx
ps: 4.8 final drive in a small track like that?
I used 4.8 final drive with the original or novak type 13.5 motor on a 40x100 footer track...not a problem, with very good speed.
Here is the thing you need to try.....your 7.7 final is WAY OFF...try 4.8 with your motor timing (the timing on your phyical motor) set to the middle...then keep gearing up untill you like the speed. I know the V3 13.5 ran alot cooler then any other 13.5 so gearing up is not a problem.
But if your track is REALLY tight (you never say how small is your track...) gearing up does not makes your any faster...you need punch and corner speeds....
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 02-01-2010, 09:23 AM   #2038
Solara's Avatar
Thanks in Advance.
I would say GEAR DOWN.....80C is probably what I would stop gearing up and 75C is probabbly what I would prefer to run.
Old 02-01-2010, 10:40 AM   #2039
razzor's Avatar
Thanks in Advance.
That is a on the HOT side.
I would suggest dropping a few teeth or look at reducing some timing.
I wouldnt go higher than 70deg and for me my motors run nothing higher than 65 deg.
Casterracing ZX1.5R
Old 02-01-2010, 11:23 AM   #2040
nascarfan3199's Avatar
quick question, does the gt2.0 lpf come with a programmer? i recieved mine today w/o one
nascarfan3199 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
