Like Tree8Likes
Old 01-29-2010, 07:48 AM   #2011
Tech Legend
Cain's Avatar
Trader Rating: 223 (100%+)
the handheld does look old now that you mention it.
No prob though as I have the LCD one and a few of the "newer" ones laying around here. will test out and confirm.
Thanks for the tip!
< RC10B6D | Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-29-2010, 09:51 AM   #2012
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by guinnes.s View Post
wonder if you can help guys,
im racing with a SP GT 1.0 ESC and a SP 13.5 V3 in a very small indoor carpet and im not able to get some serious torque from the motor.
due to the size of the track im using a 7.7FDR and the motor is practically cold after 5 minutes of race.
i havent played with any timing on the motor so is set as out of the box.
the esc settings are DRRS 9 AND AMTS 8.
Any tips to help me?
this is the track in regard http://www.youtube.com/watch?v=gBZgz9AFNfs
You geared way too low for that motor...try 4.8 final drive with AMTS 26.26 (max) and try DRRA @ 7.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-29-2010, 09:56 AM   #2013
Solara's Avatar
Originally Posted by Cain View Post
Anyone know why a Speed Passion 2.0 GT LPF when using the included programmer (NOT the LCD One) would not go up to option to enable or disable heat protection as stated on the handheld unit? The ESC works fine, but when programming it via the hand held, it won't go that high (I beleive its option 11, stops on 10)
Option 10 is the heat protection on using GT2 card....the old V1.0 V1.1 card has 11 options cause 1 of those was brushed/brushless motor options.
Old 01-29-2010, 10:28 AM   #2014
Tech Legend
Cain's Avatar
ahh ok. That makes a lot of sense then.
Thanks for the heads up!
Old 01-29-2010, 02:54 PM   #2015
TryHard's Avatar
Evening all... first off a warning... thoose with a nervous disposition for naked electronics should probably look away now!
Anyway, in running a GT2.0 in my 12th, I really need to drop it's height a bit, as moulding the shell to fit is a bit of an issue. So first off I though why not just grind down the heatsink... and well it developed a bit further than that now, and it no longer has a case, the +V and -V power wires connectors are the otehr way up, and the motor ones have been ground down as well (kept them the right way up to provide T-bar clearance). The keen eyed of you might also spot that there's no reciever wire in the later pics... as I've hard wired that too the pins underneath! My original plan was to run the wire through the ESC (2nd pic), put then left the plug as the tallest point... now the wires the lowest
To provide a secure and flat mounting point, I found a flat piece of thin plastic, and used some black silicone sealent to hold it all in place.
I'm still undecided as too whether to bother mounting up the heatsink (in the pics it's just resting on the FETS), but if I do, I picked up some thermally conductive adhesive tape used in PC's, so will do the trick nicely
Quite pleased with this little project... roll on next weekend
Regards
Ed
Oh, I should point out... if anyone else does something similar, it WILL void any warrenty...
The Speed Passion Thread-img_1595.jpg   The Speed Passion Thread-img_1600.jpg   The Speed Passion Thread-img_1601.jpg   The Speed Passion Thread-img_1607.jpg   The Speed Passion Thread-img_1608.jpg
Old 01-29-2010, 03:14 PM   #2016
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
well at least you should be able to see the red/green LEDs now
No Guts, No Glory!
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 01-29-2010, 06:02 PM   #2017
guinnes.s's Avatar
what about the timing on the motor?leave it in the middle settings?
thanx
ps: 4.8 final drive in a small track like that?
guinnes.s is offline   Reply With Quote
Old 01-29-2010, 06:36 PM   #2018
MikeXray's Avatar
Trader Rating: 73 (100%+)
Regards
Ed
You need something to keep the 2 halves of the board together, a big hit is going to seperate them.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-29-2010, 07:34 PM   #2019
CraigM's Avatar
Trader Rating: 34 (100%+)
GT2.1 looks to be on the pace at ETS, 2nd fastest in pro stock qualifying. Upgradable software and it comes in blue, I think I'm sold
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-29-2010, 11:06 PM   #2020
dfiantii's Avatar
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Can someone tell me what the part number is for the V3 13.5 SP motor that has timing adjustment. I think I just bought a used one where you can't adjust timing.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-29-2010, 11:22 PM   #2021
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Its SP138135V3 and should look like this.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 01-30-2010, 01:57 AM   #2022
irgo's Avatar
Default TRF 416 Electric Everywhere
TRF 416
Incoming
Must wait for Speed Passion Wireless Powers,
But this soon ..
TRF 416 H-Cell Free energy
and it's not too slow.
Video
Eh.. you can buy them now !
buy
Quark Force
irgo is offline   Reply With Quote
Old 01-30-2010, 06:12 AM   #2023
When are the cirtix motors going to be available?
dr_speed is offline   Reply With Quote
Old 01-30-2010, 07:31 AM   #2024
irgo's Avatar
same Question
When is Cirtix is available ?
Quark Force
Old 01-30-2010, 11:32 AM   #2025
TryHard's Avatar
Yeah, I've been debating this... it is a pretty tight fit, and the speedo is pretty far off the edge of the chassis. Aslo, if I put the heatsink on, there isn't a huge amount of clearance, certainly not enough for the pins too pull out fully from the holes.
For now, I'll run it as is, and if it does come apart, then figure out how to keep them together, without resorting to super glue
Ed
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
