Like Tree12Likes
Old 01-28-2010, 03:14 AM   #1996
razzor's Avatar
Slide the difference is essentially that 107 is a bit more aggressive/punchy compared to 110 which feels smoother.
107 also seems to keep motors a bit hotter than 110.
For gearing you will drop at least 5-6 6teeth but it is still track dependent.
On my 17.5 i dropped from a 58mm roll out to a 48/47mm rollout and am faster than my previous lap times with the 312 firmware.
Would recommend the 110 Firmware, it just feels more consistant and smooth.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-28-2010, 03:31 AM   #1997
SlideMasteR's Avatar
Thanks Razzor
will give it a try and see this weekend ! any idea where I can get the brushless analysis tool in SA ? as that can reprogram the esc and check my motors
tx again
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 01-28-2010, 05:28 AM   #1998
razzor's Avatar
try Grand Prix. Personally i dont see it being a beneficial buy.
Best is to get some good track time !!
Casterracing ZX1.5R
Old 01-28-2010, 01:29 PM   #1999
AdminD's Avatar
Default Speed Passion GT 2.1 ProStock
Adam, is This Speed Passion GT 2.1 ProStock,
is Speed Passion GT 2.0 LPF With Stock Software ?
So SP GT 2.1 ProStock The same Hardware with SP GT 2.0 LPF.
Sliders
AdminD is offline   Reply With Quote
Old 01-28-2010, 02:43 PM   #2000
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
where can we order the new 2.1 gt esc?
kriiiss is offline   Reply With Quote
Old 01-28-2010, 02:47 PM   #2001
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Won't be out till mid to late Feb. guys. So it will be a little bit.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 01-28-2010, 08:49 PM   #2002
abailey21's Avatar
Trader Rating: 36 (100%+)
Not available yet guys, but check "rc action pics" on Saturday and I'll have it in a car
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-28-2010, 09:09 PM   #2003
guinnes.s's Avatar
wonder if you can help guys,
im racing with a SP GT 1.0 ESC and a SP 13.5 V3 in a very small indoor carpet and im not able to get some serious torque from the motor.
due to the size of the track im using a 7.7FDR and the motor is practically cold after 5 minutes of race.
i havent played with any timing on the motor so is set as out of the box.
the esc settings are DRRS 9 AND AMTS 8.
Any tips to help me?
this is the track in regard http://www.youtube.com/watch?v=gBZgz9AFNfs
guinnes.s is offline   Reply With Quote
Old 01-28-2010, 09:46 PM   #2004
razzor's Avatar
if motor is still cool then gear up a bit more.
If wanting a bit more rip you can pull back timing a bit.
Casterracing ZX1.5R
Old 01-28-2010, 09:47 PM   #2005
we ran yesterday at k90 with the new software and it is really good, had to drop 4 teeth on the pinion and the motor temp was at 79 deg c after about 6 min running, lets see what happens at the nats now?
another quick question, can the firmware be changed on a GT1.1 ??
Old 01-28-2010, 09:51 PM   #2006
razzor's Avatar
i suggest dropping another tooth or 2 and see if you can keep the same lap times with a cooler motor. What timing where you running ? default 22.5 ? if yes you can pick up the timing to get a bit more rpm or drop to 18 to keep the punch..
firmware cant be updated on the 1.1 unfortunately.
Casterracing ZX1.5R
Old 01-28-2010, 10:44 PM   #2007
yip it was default 22.5 will try dropping another tooth and upping the timing and compare lap times, tx for the info
Old 01-29-2010, 12:00 AM   #2008
smilekt's Avatar
is it GT 2 turbo will come out?
smilekt is offline   Reply With Quote
Old 01-29-2010, 05:23 AM   #2009
Tech Legend
Cain's Avatar
Trader Rating: 232 (100%+)
Anyone know why a Speed Passion 2.0 GT LPF when using the included programmer (NOT the LCD One) would not go up to option to enable or disable heat protection as stated on the handheld unit? The ESC works fine, but when programming it via the hand held, it won't go that high (I beleive its option 11, stops on 10)
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-29-2010, 07:42 AM   #2010
razzor's Avatar
i have only had that happen when using a old V1 hand programmer.
Casterracing ZX1.5R
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
