Like Tree3Likes
Old 01-26-2010, 06:22 PM   #1981
energydrink's Avatar
Originally Posted by abailey21 View Post
How fast can you handle?
How are other mod drivers gearing their 4.0's?
I ask because I seriously don't know but 2 mod tc guys and neither run a motor that low, they're both running 5.5's
thanks for the help.
Originally Posted by lochness42 View Post
try to check manual you got with motor - there are recommended FDR ranges for each motor.
Ok, thanks. and what about esc settings with a speedpassion 2.0 for timing and stuff like that ?
Tamiya 415 MSXX...Associated B44...TOP Photon...Mugen MBX6
energydrink is offline   Reply With Quote
Old 01-26-2010, 06:42 PM   #1982
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by energydrink View Post
how should I gear a 4.0 V3.0 in a tc ?
I geared the 4.0 V2 motor around 8.75 to 9.25 depending on the size of the track.
Old 01-26-2010, 06:45 PM   #1983
Super Moderator
Marcos.J's Avatar
For Mod I've ran :
Drag brake#3
DRRS #5
brake force #2
Initial brake#1
neutral #2
timing #3 and #4 depending on track
Old 01-26-2010, 10:13 PM   #1984
razzor's Avatar
The local guys are running the 4.0 on lipo and the general gearing is around 21 - 24mm roll out track depending
Use 205g firmware or 323 and dont run timing higher than 18 deg with DRSS 5 or 6.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-26-2010, 10:38 PM   #1985
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Originally Posted by TEM View Post
I guess we would need new software for the PC (one with parameter change for "turbo" settings) and new firmware for the ESC.
MAYBE the only thing I can think of as a limiting factor is if the ESC's microcontroller can handle all the timing functions.
Basically we are talking about a launch timing (low) that gets the car moving from standstill.
Acceleration range timing advance. Start RPM to End RPM presets and the number of degrees of advance presets per 1000rpm of change (as per Tekin, but it can literally be anything depending on motor, track, etc).
Top Speed Boost; advance of X degrees IF full throttle was held on to for preset amount of time. And tekin even says this doesn't work for short tracks!
All makes very logical sense to me!
I think SP would need something different than what you speak of so it does not seem to copy what Tekin has.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-27-2010, 08:35 AM   #1986
irgo's Avatar
Default SpeedPassion GT2.x Turbo
Originally Posted by charlie_b View Post
It is only a matter of time. Development isn't as easy as one may think. There are a lot of trial and errors involved. Perfection is achieved when all is done right to begin with. You can't just figure out the magic software and pull it out of a hat and say "here it is!" Just be patient.
Cant wait...
Where did you find information on what the "tekin turbo" really is?
According to this http://forum.teamtekin.com/phpbb3/vi...hp?f=30&t=2413 from tekin's forum, it looks like a software thing! The key is timing change proportional to motor speed. It's variable timing!
All of those I've been ask Adam on previous,
What is Called Dynamic Advanced Multi Timing,
it is not only, Physical Timing (motor) and Advanced Multi Timing (software).
which is now noted on GT 2.1 Pro Stock
it's likely different timing on different rpm edge.
Which software doing.
While torque is maintained.
Quark Force
irgo is offline   Reply With Quote
Old 01-27-2010, 01:51 PM   #1987
F-1
HellO! Which ceramic bearings I can to buy for Speed Passion V3 6.5t motor?? Or Standart is OK??
F-1 is offline   Reply With Quote
Old 01-27-2010, 03:15 PM   #1988
TryHard's Avatar
For thoose asking about a 4.0t setup, have a look at this file from the Europe guys, details what they are running (it's included with the v1.32 software download from the SP site).
Also, regarding 12th.... Elliott Harper was running a GT2.0 in his CRC this weekend, TQing and winning the Stock class on the saturday (10.5/4cell). Asked him about his settings, and they are as follows;
Firmware; 107Stock
Motor; Comp v3
Drag brake; 0%
Initial Brak; as Drag
DRRS; 6
ESC timing; max (26.25)
Motor timing; max (+10)
Voltage cutoff; off
Gearing; 56mmpr
He did mention the motor was getting a bit too hot... so maybe use thoose as a baseline, but with a little less ESC timing to start. He also mentioned that he tried higher on the DRRS setting, but felt he had the same speed with more heat, so no need to go higher.
HiH
Ed
Old 01-27-2010, 06:11 PM   #1989
HanIce's Avatar
Trader Rating: 12 (93%+)
Can anyone tell me what rotor diameter comes with the speed passion 17.5 v3??
I heard plenty good stuff about this motor, but how does it compare to the fantom ion2???
# GRID FIVE RACING TEAM #
👑🔱 king AE B5M🔱👑
HanIce is offline   Reply With Quote
Old 01-27-2010, 06:13 PM   #1990
mr crum's Avatar
Send a message via Yahoo to mr crum
roar legal 12.3 mm rotor just like all sp spec motors
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-27-2010, 06:17 PM   #1991
HanIce's Avatar
Thank you.
👑🔱 king AE B5M🔱👑
Old 01-27-2010, 08:41 PM   #1992
FIVE 7's Avatar
Thumbs up 12th Scale Firmware....
Wonder how he was getting the 107 profile to work with only a 4 cell. I have tried it along with a few others here with the 1S and no luck.....must be just that little extra voltage bump from 3.7 to 4.8 that makes the difference. Although I just Won and TQ'd in a local event this past weekend with my XII with a 1S and V3 17.5 using the GT 2.0 LPF. I used the 312a firmware and it worked really well.
Can"t wait for the new 2.1 to come out.....
Brent
Thompson Valley R/C Race Club - Prez -
XRAY - TAMIYA - ORCA - MOTIV - PROTOFORM - FUTABA - GFORCE - SWEEP - TLR
FIVE 7 is offline   Reply With Quote
Old 01-27-2010, 10:42 PM   #1993
RTR canada's Avatar
so we will probably get the new software when they release the 2.1!! anyone know the release day? lol
RTR canada is offline   Reply With Quote
Old 01-27-2010, 10:58 PM   #1994
RTR canada's Avatar
anyone know what the equivalent KV's a 17.5 motor would be?
Old 01-28-2010, 01:23 AM   #1995
SlideMasteR's Avatar
Default new stock software
hi guys
I have a SP v2.0 LPF which I have just loaded the new stock softeware on and was wondering if and by how much I should change my roll out by ? currently running it in 10.5 touring class.
another question, I see in the new v1.32 software that there is 2 stock profiles, what is the diff between the two and which one would best suite 10.5 ?
tx in advance
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
