Like Tree12Likes
Old 01-26-2010, 10:46 AM   #1966
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by hacker07 View Post
I know it says stock spec, but it looks like a smaller GT2 as far as footprint, so will it still have the same specs, meaning will it still handle mod motors as well?
Well being is called "stock" spec I would say no, the software is going to be designed for stock only, just like the new 2.0 stock software isn't good for mod.
As for "physical" capability, yes it is designed to handle a mod motor
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-26-2010, 11:16 AM   #1967
irgo's Avatar
Originally Posted by Cain View Post
adam: do we have a software update coming to us in the future for the GT2.0 that will have a turbo feature, or is that only going to be available in the GT2.1?
Cain, There would be no Turbo on Software Updates,
Turbo is not about Timing or Software.
Unless if the GT it self has been changed on it's hardware.
or Secretly Build in inside the GT 2.x that had not yet been revealed
by it's Speed Passion software.
That's why many Turbo Features should be shut-off on some Races.
but still question is why not speed passion add Turbo Features yet?
Quark Force
irgo is offline   Reply With Quote
Old 01-26-2010, 11:22 AM   #1968
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
It is only a matter of time. Development isn't as easy as one may think. There are a lot of trial and errors involved. Perfection is achieved when all is done right to begin with. You can't just figure out the magic software and pull it out of a hat and say "here it is!" Just be patient.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 01-26-2010, 12:06 PM   #1969
AGNO's Avatar
The description of the GT 2.1 Pro stock on Red RC speaks of only 1:12 ... but can also handle touring at 7.4 volts?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-26-2010, 12:11 PM   #1970
abailey21's Avatar
yes
K.C.C.O.
Old 01-26-2010, 12:13 PM   #1971
energydrink's Avatar
how should I gear a 4.0 V3.0 in a tc ?
Tamiya 415 MSXX...Associated B44...TOP Photon...Mugen MBX6
energydrink is offline   Reply With Quote
Old 01-26-2010, 12:19 PM   #1972
abailey21's Avatar
How fast can you handle?
How are other mod drivers gearing their 4.0's?
I ask because I seriously don't know but 2 mod tc guys and neither run a motor that low, they're both running 5.5's
K.C.C.O.
Old 01-26-2010, 01:09 PM   #1973
lochness42's Avatar
try to check manual you got with motor - there are recommended FDR ranges for each motor.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-26-2010, 01:13 PM   #1974
rc-racer-kirby's Avatar
Send a message via MSN to rc-racer-kirby
OK so say i went for the GT2.0 and installed stock software. Could i just use the latest update at every track? I attend 2 tracks regurally in summer, one is very fast and open, one is quite tight. everytime i go to a diffrent tracks i dont want to be going through every update just to go fast. Which makes me think i should go for the LRP Stock Spec
rc-racer-kirby is offline   Reply With Quote
Old 01-26-2010, 03:01 PM   #1975
Racer X's Avatar
Hey, I'll trade you my LRP SPX for your 2.0 then! I think that one stock software profile will suit most tracks...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 01-26-2010, 04:35 PM   #1976
Coldn's Avatar
Send a message via MSN to Coldn
Originally Posted by Coldn View Post
anyone know the specs from v3 10.5T??
Spec. RPM per volt, kV:
RPM:
Power:
Efficiency:
anybody can help me??
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 01-26-2010, 05:56 PM   #1977
TEM
TEM's Avatar
Where did you find information on what the "tekin turbo" really is?
According to this http://forum.teamtekin.com/phpbb3/vi...hp?f=30&t=2413 from tekin's forum, it looks like a software thing! The key is timing change proportional to motor speed. It's variable timing!
TEM doesn't advertise for free! Does anyone else notice that a LOT of companies are not even packaging decals with their products?
TEM is offline   Reply With Quote
Old 01-26-2010, 06:00 PM   #1978
Super Moderator
And I believe they added it with just a software change, not a hardware change.
Dave H is offline   Reply With Quote
Old 01-26-2010, 06:11 PM   #1979
TEM
TEM's Avatar
I guess we would need new software for the PC (one with parameter change for "turbo" settings) and new firmware for the ESC.
MAYBE the only thing I can think of as a limiting factor is if the ESC's microcontroller can handle all the timing functions.
Basically we are talking about a launch timing (low) that gets the car moving from standstill.
Acceleration range timing advance. Start RPM to End RPM presets and the number of degrees of advance presets per 1000rpm of change (as per Tekin, but it can literally be anything depending on motor, track, etc).
Top Speed Boost; advance of X degrees IF full throttle was held on to for preset amount of time. And tekin even says this doesn't work for short tracks!
All makes very logical sense to me!
Old 01-26-2010, 06:12 PM   #1980
Trader Rating: 23 (100%+)
how the new motors holding up? im looking for an 8.5 in a 2wd offroad, these things have some torque to them or are they more top end? i like them because the quick bullet connectors to them for the motor.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
