Old 01-24-2010, 03:26 PM   #1921
TEM
TEM's Avatar
Originally Posted by cheehtae View Post
s when you buy the speedo it des not come with the programming card yet? I need a new speedo and SP is on my top list.
I think a lot of people have this confused including myself in the beginning.
There are 2 different programming devices.
1 is the programming card that comes in the box. It's for changing settings only (brakes, punch, timing, etc)
2 is the LCD programmer and it's sold separately. That's for changing firmware. ie swtiching from the profile out of the box to the 1107 or 1110,etc.
TEM is offline   Reply With Quote
Old 01-24-2010, 03:27 PM   #1922
rc-racer-kirby's Avatar
Send a message via MSN to rc-racer-kirby
Thank you for quick response!
It does not seem as complicated as i thought, once i have the stock software it will have all the settings and run good for stock? Or is there more to be done?
Dont like the idea of buying the program card but i suppose it still works out at a decent price alltogether
What is the talk of recalibrating the ESC after changing the settings? Is this just resetting? but wouldnt that take it back to factory settings? Never heard of this before.
Why is it i have heard of people switching between updates during a raceday? is there further updates that make a diffrence for diffrent tracks etc.
rc-racer-kirby is offline   Reply With Quote
Old 01-24-2010, 03:40 PM   #1923
sosidge's Avatar
The stock software is good to go once installed, but you can fine tune the profile (punch, drag brake etc) to your own tastes also.
It is simply recalibrating the ESC to your radio. It has no effect on the software or profile settings.
You can only do this if you have a PC trackside. I don't take one and have never wished I had one with me.
Old 01-24-2010, 03:40 PM   #1924
TEM
TEM's Avatar
If you want to be cheap; you will just have to find a friend who's got the LCD programmer. For price-point, I think the Speed Passion is a very sensible buy.
You need a computer and the LCD programmer to change the firmware on the ESC. You do not need to do this all the time in most cases. I'm sure once I get it figured out, I"ll leave the notebook AND the LCD programmer at home. IF a new firmware comes out, I'll bring everything to the track to switch back and forth to test, etc.
As for the recalibration thing; that's basically ME! Sorry if that cause confusion with anyone else. The recalibration is as described above. When you update the firmware, reset the ESC and speedo. That's basically the initial setup thing (turn the speedo with the program button held down, neutral the throttle and press button, full on, press button, full brakes, press button). Something really stupid I overlooked.
Old 01-24-2010, 10:13 PM   #1925
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
saw this when i surfing the ebay..
Speedpassion
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-25-2010, 01:34 AM   #1926
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Sorry should this be posted before...
I installed the stock profile onto my SP GT2 and ever since it flashes green and makes a beeping noise..
After working out if I used a battery this enabled me to put a different profile on and as long as it was not stock the controller worked fine.
Anyhelp here will be great, really want the stock profile to work
Alex
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 01-25-2010, 02:22 PM   #1927
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Alex
By your sig, I'm guessing you are running 12th 1cell. If so.....turn the battery protection OFF.
nearest I can tell these new "STOCK" setups are working only in 2cell (7.4volt) ......TryHard and myself have discussed this issue back in this thread.
GOOD LUCK
Mark
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 01-25-2010, 03:00 PM   #1928
OK so say a new stock update came out? It may offer more speed for example better for larger tracks? so people take the pc to the track to see if they want that extra speed or if it was better before?
It all still sounds very comlicated, not sure if i should go for the LRP SXX Stock Spec instead
Would it take me long to get the GT2.0 setup to my liking for every track i go to?
Old 01-25-2010, 03:15 PM   #1929
dfiantii's Avatar
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
My .02 cents on this is that you could go ahead and buy the LRP esc but when Tekin and SpeedPassion come out with new software that "spanks" the LRP, you will be buying another LRP. Or you could just bite the bullet get the SP or Tekin which ever is your flavor and only have to load new software. Hell now a days i think you could buy one of those netbooks for about what you would pay for an ESC.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-25-2010, 05:46 PM   #1930
Coldn's Avatar
Send a message via MSN to Coldn
anyone know the specs from v3 10.5T??
Spec. RPM per volt, kV:
RPM:
Power:
Efficiency:
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 01-25-2010, 08:26 PM   #1931
Trader Rating: 40 (100%+)
When you calibrate your radio the instructions say to do so with your EPA at 100% what do you do if your radio say maxes out at 150? Do you still calibrate at 100 or would you use the 150? I've seen this question answered on here before I believe but I can't find it.
AndysD8 is offline   Reply With Quote
Old 01-25-2010, 08:33 PM   #1932
abailey21's Avatar
Trader Rating: 36 (100%+)
I always calibrate at 100% like the instructions say, afterwards I will bump my EPA's to the maxed out setting, mines 120%, yours is 150%
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-25-2010, 08:40 PM   #1933
TEM
TEM's Avatar
Why would you bump it up to above 100% afterwards???
TEM doesn't advertise for free! Does anyone else notice that a LOT of companies are not even packaging decals with their products?
Old 01-25-2010, 08:56 PM   #1934
Thanks! Mine might be 120 as well I don't have it in front of me at the moment I just knew that it's over 100. By bumping it up after calibration do you actually gain anything?
Old 01-25-2010, 09:02 PM   #1935
abailey21's Avatar
I found this on a fluke
In the prototype stages of the 2.0 I noticed my LPF was running really hot (180) on average.
My friends asked where my EPA's were, I said 100% because the 1.1's hated being anything OTHER than 100%.
My buddy Matt jumped my EPA's to 150% on my DX3R and I gained a few things.
1. My temps averaged about 110 degrees after the switch, (from 180ish).
2. I gained a higher top speed
3. the overall feel of the ESC was smoother.
4.My motor temps dropped about 15-30 degrees
5. I had stronger brakes
It was a 110% improvement and honestly it was a fluke that Matty found it
K.C.C.O.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
