Like Tree46Likes
Old 01-18-2010, 08:17 PM   #1846
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Danny-b23 View Post
There is adjustable timing on these motors, but I'm not sure if the adjustment range dips down into the negative timing or not.
I think they are...
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 01-18-2010, 08:24 PM   #1847
jhautz's Avatar
Trader Rating: 85 (100%+)
Originally Posted by charlie_b View Post
Cough Cough...Yeah, don't cross breed Hobbywing with Speedpassion. Its like mating a Chihuahua with a Saint Bernard. Don't do it! And No, they are definitely not the same.
Which one is the Chihuahua....
jhautz is offline   Reply With Quote
Old 01-18-2010, 11:58 PM   #1848
cherry2blost's Avatar
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 01-19-2010, 12:14 AM   #1849
TryHard's Avatar
Originally Posted by veecee View Post
Sorry to hear about the bad luck Ed. So was it just motor damage or did it overheat the speedy also?
I tried 107 and thought it was a bit too aggressive especially in warmer weather with a 10.5 (33-35 degrees C ambient temp). It had awesome grunt but motor gets hot quickly, then fades. I'm going to try 110 this wkend.
It did both unfortuantly... End of the run the motor smelt a bit hot, and had huge drag brakes, not a good sign.
Unplugged it all, put a spare motor in and...nothing.. Power was going to the servo and reciever (so I guess the BEC circuit is fine), but speedo itself was completely dead, no reponse to trying to set it up or run it. Also plugged in the LCD box, and just get the connecting esc message.. Oh well off to Schuey uk for repair..
As for the 107, I'm begining to get the impression that the DRRS is controlling the speed of the timing ramp in the firmware, hence why a higher number is giving more heat (faster/steeper ramp). Certainly for future I think 7 is the max to run without changing my gearing from 6ish. On smaller tracks where your on the throttle less might be able to get away with it, but where I was running its too much.
The ESC timing basically controls how much boost you have, so more timing should equal more boost, so a lower DRRS figure may be the way to go, and max out the timing for top end.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-19-2010, 02:45 AM   #1850
sosidge's Avatar
Originally Posted by Goingfast View Post
Question
Can I retard the timing on these motor?
Where is the zero timing mark?
I took a few measurements already...
The factory setting (middle of the slot) is at a true 30deg timing, what most other manufacturers call zero.
Fully retarded on the endbell is -10deg from that, fully advanced is +10deg from that.
For some reason SP have marked the endbell to give the impression that the range is only from 0 to 10, with a default of 5. That is clearly wrong as there is 20deg movement in the slot.
Old 01-19-2010, 05:52 AM   #1851
Goingfast's Avatar
I'm hoping your right....The will solve my problem..Thanks
Old 01-19-2010, 08:22 AM   #1852
Solara's Avatar
Trader Rating: 16 (100%+)
I actually find the 1110 software has the best all around performance for 17.5 and 13.5 motor (or may be 10.5 11.5 motor too). At least, 1110 software does cool down the motor by a lot (if gearing correctly). Performance wise, I don't see any advantage from 1107 over the 1110. Except 1107 get the motor hotter for no other reason.
Give 1110 software a try...........
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-19-2010, 09:15 AM   #1853
razzor's Avatar
will be doing that at the regional championships this coming weekend.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-19-2010, 10:20 AM   #1854
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
have a question...I installed the 1110 on both my sons car and mine..while I bench tested them I noticed a little shutter at low/mid throttle..anyone else notice it??? and the 1007 is defiantly more aggressive and has a little better top end.
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 01-19-2010, 10:23 AM   #1855
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you have new software to try
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-19-2010, 11:07 AM   #1856
TryHard's Avatar
That's just you finding the start of the timing ramp... I've seen this on other speedos as well (MMPro) so nothing to worry about
As for the softwares, I did try the 107 and 110 back to back, and do prefer the 107... However, you do need to tweak the settings to get it too run cooler, whereas the 110 you can seemingly keep them at max. Personally so far turned faster laps with the 107.
Not sure who else has noticed, but the zip file I downloaded off the SP site has a pdf doc with recomended setings for 17.5 from none other than Viktor Wilck (and speaking to some SP drivers this weekend, he has actually run it... So they aren't suggestions). Worth giving them a punt
HiH
Ed
Old 01-19-2010, 11:15 AM   #1857
dsyed1's Avatar
HiH
Ed
I have had a similar experience... the following is the best setup that I could come up with 107... I agree 110 you can max everything out without temp concerns but 107 is faster for me in the end
ESC: SP GT 2.0 (PRO)
Firmware: 107
FDR: 104/46*1.9 = 4.29
Battery: Thunder Power 7.4v 40C
Motor: SP V3 17.5R
Track: 100 Foot Straight away total 100/50 foot
SP ESC Timing: 22 degrees
DRRS: 9
Drag Brake: 10%
Motor Timing: 10 degrees
Capacitor: SP Super Cap
I have tried running at 26 esc timining but prefer the performance and temp with 22, the physical motor timing is max. Coming off between 145-155F
dsyed1 is offline   Reply With Quote
Old 01-19-2010, 11:26 AM   #1858
Ed, or anyone....
You tried running the 107 setup with a high power lipo 53 40c, then with a lower power lipo? Might keep it cool as not so much waste.
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 01-19-2010, 11:29 AM   #1859
thanks everyone...Adam says there working on new software, so keep your eyes peeled
Old 01-19-2010, 03:40 PM   #1860
Send a message via MSN to Bigger Brother
Ran those settings tonight but with 13.5 Seemed pretty good, guessed a starting point with gearing and only made slight adjustments. Felt I had plenty of power throughout the rev range. Was only a club meeting so didn't want to push things too far, but has given me an idea of what to try this weekend.
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
