Like Tree46Likes
Old 01-17-2010, 01:52 PM   #1831
Trader Rating: 40 (100%+)
Does anyone here run the sp ultra sportsman 17.5? Would that be considered the v2? I found one at a good price and looking to here some opinions on it. I currently run the lrp x11 17.5 and I'm not really happy with it. I run the sp lpf gt 2.0 with the 107 software. Any opinions on this motor would be appreciated!
AndysD8 is offline   Reply With Quote
Old 01-17-2010, 02:34 PM   #1832
hollywood tc5's Avatar
Default 3.0 17.5
hey question for the team what fdr is good to start with on this motor. Im running tekin 203 Im at a 5.2 ,and its fast but the motors only comeing off the track at 120 degrees so i can get some more out of it and sugesstions????? Thanks for your time
BOSS MOTORSPORTS
wrecking ball,sox,hollywood
BOSS MOTORSPORTS
hollywood tc5 is offline   Reply With Quote
Old 01-17-2010, 02:45 PM   #1833
My tekin settings for the SP17.5v3
Throttle Profile: 5
Timing Boost: 50
Turbo Boost: 8
Turbo Delay: .2
Start RPM: 3000
End RPM: 13000
Ramp Delay: 2
FDR: 5.3
Motor Temp: 125 to 135 degrees
Track: 50x100 med. high bite carpet
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 01-17-2010, 03:13 PM   #1834
TryHard's Avatar
Well, got back from the track today and well... not a good day
My blue star GT2.0 is now sitting unwired on my desk, having seemingly closely followed my comp3 10.5 on the way too mega hot-dom. Double
Basically think, that for the first time in a long while, I pushed the motor just too far. Was running the 107 software, and whilst it had been coming off quite hot, felt there was more to come, so turned the DRRS up one notch to 8, and then it went pop... So, think I found the limit, at that gearing at least!
Prior to that it had certainly been fast, running;
Firmware; 107STOCK
ESC Timing; 22
DRRS; 7
Drag brake; 10%
Intial brake; Drag
Dead band; 6ms
FDR; 5.93
Motor timing; +10
Rotor; Red ring (12.5mm outer/5mm core)
So, as a warning, you really need to be hot (geddit) on the temps... I think probably what I should have done was up the ESC timing over the DRRS. Oh well, live and learn.
Cheers
Ed
Old 01-18-2010, 07:25 AM   #1835
Send a message via MSN to Bigger Brother
Ouch, that doesn't sound good Ed!
Just got my GT2.0 through today, hopefully going to try it out tomorrow night at a club meeting before Eversley at the weekend.
A few quick questions:
1) The capacitor that is included - is it necessary to run it all the time?
2) Any tips on a starting point for gearing? I'm thinking 107 software, with DDRS at 8 and ESC timing at 22.5. Motor is a SP v3 13.5, std rotor, timing at middle point, track is 19m x 12m with a full length straight.
3) I'm guessing a "safe" max motor temp is 70 deg C?
Thanks for any tips
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 01-18-2010, 07:29 AM   #1836
abailey21's Avatar
Trader Rating: 36 (100%+)
Thanks for any tips
Oli
1. We wouldn't include it you weren't supposed to run it
2. 4.5ish FDR, like any new esc and motor gear conservatively and make changes according to feel and temp
3. 170F is higher than I would personally go
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-18-2010, 11:22 AM   #1837
Sorry if this was covered before but I have some questions regarding to the SP 13.5 V3.
The motor comes with a purple rotor factory assembled. I assume it is this one:
http://www.speedpassion.net/en/productDetails.asp?p=91
There is an other purple rotor in the option parts, this one:
http://www.speedpassion.net/en/productDetails.asp?p=86
What is the difference in appearance and/or in dimensions between the two?
Is the second one fits in the 13.5?
If so how will it affect the performance of the motor?
cvt01 is offline   Reply With Quote
Old 01-18-2010, 11:24 AM   #1838
razzor's Avatar
Definately YES !!!
DRSS 8 just makes unnecessary heat in my opinion.
Prefer 5 or 6 with 107. Has plenty rip especially if you lower the timing and gear up a bit. As suggested though start conservative with gearing and go from there.
60-65 deg/c max but with 107 i am getting performance with temps consistantly below 60 deg/c
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-18-2010, 11:27 AM   #1839
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
for those of you also running USVTA with your speed passion setups, can you comment on what you have noticed as far as the timing settings on the Speed Passion GT2.0s (Pro or LPF) that seem to be more comparable to the performance of non-timing ESCs like a Novak Havoc or GTB? DARKSIDE is looking for info on this on the thread, and my experience was that the 11.25 timing or the step below seemed about the same to what the Havoc driver was doing speed wise, but I am not on a larger track so can't comment if it keeps revving out.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-18-2010, 01:08 PM   #1840
Originally Posted by abailey21 View Post
Yeah man, I'll get them on here tonight
Hey Adam,
Suppose you might get to posting your 4wd settings?
Thanks man, Rob........
*Restructuring* :)
Robio is offline   Reply With Quote
Old 01-18-2010, 02:53 PM   #1841
TryHard's Avatar
Thanks for any tips
Oli
Err yeah, not so good, as through in my dodgey module, and cracking the screen in my netbook, not a cheap weekend
Still, forgot to mention that the 107Stock was also working really well in my 12th... plenty of grunt on the infield, and good top end... although I think my lack of 12th running is telling as I really need to true my rear tyres down, 50mm... almost big enough to eat thoose lol!
Cheers
Ed
Old 01-18-2010, 02:56 PM   #1842
sosidge's Avatar
Thanks for any tips
Oli
Let me know how you get along with gearing the motor, I found that anything below 6:1 with the 107 and default programming took away the rip and increased heat without adding enough to the top end. This is with a 30m straight. Got as low as 5.3:1 and the car was soft in the infield.
It could be that I was still way under-geared though, and the motor hadn't found it's sweet spot.
Old 01-18-2010, 02:57 PM   #1843
veecee's Avatar
Trader Rating: 34 (100%+)
Sorry to hear about the bad luck Ed. So was it just motor damage or did it overheat the speedy also?
I tried 107 and thought it was a bit too aggressive especially in warmer weather with a 10.5 (33-35 degrees C ambient temp). It had awesome grunt but motor gets hot quickly, then fades. I'm going to try 110 this wkend.
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 01-18-2010, 05:54 PM   #1844
Goingfast's Avatar
Trader Rating: 29 (100%+)
Default V3 motor
Question
Can I retard the timing on these motor?
Where is the zero timing mark?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 01-18-2010, 06:06 PM   #1845
Danny-b23's Avatar
Originally Posted by Goingfast View Post
Question
Can I retard or advance the timing on these motor?
There is adjustable timing on these motors, but I'm not sure if the adjustment range dips down into the negative timing or not.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
