Like Tree3Likes
Old 04-30-2009, 11:23 AM   #166
abailey21's Avatar
Trader Rating: 36 (100%+)
agreed lol
Originally Posted by hobbipro View Post
Guess someone forgot to make a small "window" to see the LED!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-30-2009, 12:43 PM   #167
I just picked up a LPF 2.0 carbon edition, and have one question. In the set up instructions it shows a LED that is somewhere on the solder posts side that you can look at while programming your radio set-up. For the life of me I dont see the LED, even a place for it. I even pealed the "A,B,C" decal back a little to see if it was covered up. However I do hear the set-up tones and got it done. Just wonder what I'm missing, or not seeing.
I had the very same problem, I had to sit in a dark room and then I could just about see the LEDS .
FLAT OUT is offline   Reply With Quote
Old 04-30-2009, 12:48 PM   #168
abailey21's Avatar
yeah it's much easier to use the tones,
holding down the setup button it will beep consistantly...
Push once for neutral, it will beep once
hold full throttle and push again it'll beep twice
hold full brake and push again it will beep 3 times
turn off then on and your good to go
K.C.C.O.
Old 04-30-2009, 01:20 PM   #169
hi,
i just want to ask 1 question. On the speed passion LPF v1.1 box, it said that the motor limit is 5.5t on 7.2v. My question is, if I'm using 7.4v lipo battery on a 5.5t bl motor, would it damage my esc??
Jr_Dorifto is offline   Reply With Quote
Old 04-30-2009, 01:24 PM   #170
abailey21's Avatar
No, your fine with a 2S LiPo
Originally Posted by Jr_Dorifto View Post
hi,
K.C.C.O.
Old 05-01-2009, 07:49 PM   #171
Default LPF V2
Hey guys, new GT2 is awesome, But now am thinking of LPF for youngest son who races 10.5. Does the LPF have any speciaist stock profiles for the speck classes like the SPX? Also what is timing on the fly I have seen mentioned on the LPF,, thanks in advance
warpspeed57 is offline   Reply With Quote
Old 05-02-2009, 05:44 AM   #172
steveonamission's Avatar
Hi Guys
Thinking of getting a SP GT2 as a back up speedo.
What i was wondering though, would i notice any power difference between the LPF and PRO version running 6.5/lipo.?
Thanks in advance
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 05-02-2009, 07:53 AM   #173
Heya,
Could anyone explain what 'AMTS' Timing settings on the program card do?
If you could explain when and why you would change the timing that would be great
madwestmo is offline   Reply With Quote
Old 05-03-2009, 12:26 AM   #174
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 34 (100%+)
Originally Posted by madwestmo View Post
Heya,
Check post #16 on page 2 of this thread...excellent info on gearing/timing advance relationship!
-rocky b
flatspunout is offline   Reply With Quote
Old 05-03-2009, 11:34 AM   #175
After struggling with cogging issues for the past two weeks with my speed passion LPF v2 + 10.5, I decided after reading on here from someone else to move a shim to the other side of the rotor so it sat closer to the sensor.
This worked and solved all my problems, my question to speed passion guys is why should I have to do that? Surely the motor should be ready to run out the packet...
TC5
www.keiransmart.co.uk
Keiran is offline   Reply With Quote
Old 05-03-2009, 08:42 PM   #176
My 13.5 came out of the box with zero endplay, so I had to re-shim it to get to the .5mm endplay tolerance that was recommended. There was no noticeable performance increase afterwards (it was already a rocket anyway) but I imagine the rotor bearings will thank me in the long run.
-rocky b
Old 05-03-2009, 09:24 PM   #177
skypilot's Avatar
Trader Rating: 14 (100%+)
just like with brushed motors, double checking everything first is a good idea. glad the re-shimming worked
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-04-2009, 02:01 AM   #178
Hiya
First post here so be gentle
I have ran brushed for a long time now and ive decided on going brushless with my cyclone TC , i decided to go for 13.5t speed passion combo , but im not quite sure how to gear it at the moment
The tracks i run are a small indoor carpet track and a slightly larger outdoor asphalt track , currently i only have a 84t spur and 23t pinion with all the standard pulleys , i want to get some new gears but dont want to end up buying all the wrong ones , so im after a rough guide as to what range of spur/pinions i should get...
Also i do have the brushless motor mounts if that makes any difference
oh and also both carpet and outdoor tracks i run rubber and 7.4v 5000 lipo
Thanks for any help/advice its really appriecated because i am lost
Mark
Well i have got the speed passion 13.5 combo , i decided to get a 78t spur/36t Pinion and are 48DP , it works out at 4.68 FDR....
I ran my car for between 5-10mins and i checked the temp , i have no thermometer so i just touched it with my thumb , i cud only hold it on there 2-3 secs , it seems to run too hot or is it just me ?? , i even turned the motor timing down to the lowest and is still very hot , also i have got the over heat protection setting 'on' on my speed control but this didnt kick in
am i worrying about nothing ??
Old 05-04-2009, 06:41 AM   #179
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
normal racing conditions are between 5 to 6 minutes, if you are running it hard for 10 minutes the motor will get a little hot. 4.68 is a normal gear for a SP13.5 thats the ratio that I normally run on my SP13.5 and my motor temps are about 160- 165 degrees after 6 minutes of racing.
What is your track like? is it tight and technical? open track? How much drag brake are you using? how hard are you driving the car? There are alot of things that can make the motor hot besides gearing and timing.
Old 05-04-2009, 09:01 PM   #180
Powerlink's Avatar
Send a message via AIM to Powerlink
Default broken plastic on the SP grandtur 2.0
I'm on my second grand turismo pro 2.0 .I love this Esc. however I put my car down on the track ..run it a few laps and the darn bottom case half of the ESC is separating from the top and cracking .This has happend to me twice now. Who can I send these ESC's to so they can replace the cases .I bought them two weeks ago ,and have the recepts . The plastic looks very thin and brittle on the bottom half of the ESC's . Thanks Karl
Karl Rolf
Powerlink is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
