Like Tree3Likes
Old 01-08-2010, 03:11 PM   #1681
I am reading the last posts since December and i canot find anything about 731c firmware.
Does anyone knows whats about that program?
I am using 4.5T V3 motor and 323 program.
Is the 731 better for mod motors?
Team Magic G4JS - Orion wasp .12 - Traxxas 4tec - O.S 18 tz
Team Magic E4FS - speed passion GT 2 pro - 4T ver 2 - 4.5T Ver 3
Kyosho spada 09 - Kyosho mini-z monster - Kyosho mini-z mr-02
memix is offline   Reply With Quote
Old 01-08-2010, 03:21 PM   #1682
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I originally posted this question on the 12scale thread but this might be a better place to ask.
Question to anyone running an external receiver pack (7.4 lipo etc) on SP v2 esc.
Do you guys still plug all 3 esc wires (Red, White & Black) in the receiver when running a external receiver pack? or do you not plug the RED.
I've tried taking the Red wire out the everything works Ok when running an external pack but is a hassle when changing ESC settings as I need to plug back the Red wire again when connecting to program card.
Thanks in advance.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-08-2010, 03:56 PM   #1683
TryHard's Avatar
Thanks in advance.
Why not leave the reciever lead plugged into the reciver, and plug in another one too the ESC end... SP conviently include two length reciever leads in the box, so I've got the longer one permanently mounted into the LCD box now... means i never have to squirel away with the reciever plugs
HiH
Ed
Old 01-08-2010, 04:07 PM   #1684
Trader Rating: 8 (90%+)
Originally Posted by Tha Skinny View Post
So who is running the 2.0 with the new software at the Novak race and how is it standing up? I know today was just practice but.........
I will ask again...
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 01-09-2010, 01:19 PM   #1685
Mopar's Avatar
Was running 3.456 FDR with 323 software on medium to large outdoor track. Changing to 110 software, how much pinion change am I looking at? Current spur / pinion is 96/50. Thanks
Mopar is offline   Reply With Quote
Old 01-09-2010, 01:59 PM   #1686
mr crum's Avatar
Send a message via Yahoo to mr crum
atleast 3 teeth
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-09-2010, 02:08 PM   #1687
razzor's Avatar
the pinion size difference varies depending on track size.
I would suggest anything from 4 - 7 teeth .
Only real way to see is to try different combinations.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-09-2010, 05:26 PM   #1688
Mopar's Avatar
All right, with my MI4 I had to change to a 106 spur as I didn't have range to go down 4 teeth on pinion as motor was almost against the bulkhead and rear sprocket. 106/46 gives 4.147 FDR. Will give that a try.
Old 01-09-2010, 07:53 PM   #1689
Tech Legend
Cain's Avatar
Trader Rating: 220 (100%+)
tried the 107 VTA class, with a Novak Ballistic 21.5 . took a bit to figure out how to get it to work well, had no torque, so eventually I settled on 10 degrees timing on the motor, and about a 5.00 FDR, and went with a VTA friendly timing of 11.25 (any reason we can't adjust timing in single increments?) .
With this kind of setup, it woke my motor up for the track. I was very surprised how much more punch I had than before, almost night and day. I was worried for a second that my ESC was messed up or something. And temps was still in the 135 degree range after 8 minutes.
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< HB Racing D413 x 2>
Old 01-09-2010, 08:16 PM   #1690
dsyed1's Avatar
Originally Posted by Stein Tumert View Post
SP 13.5T V3.... FDR is only 6.3...max allowed in our winter series....but plenty fast for our track...
(some guys run FDR around 8 with SPX and this motor and are fast, i.e. winning)
Motor should be able to take quite a bit more with free FDR...but needs testing...
Toni Rheinard recommended 4.7 with 107 firmware...
thanks for sharing... what are your track dimentions... and any idea if you are running max physical timing on the motor or stock 5 degrees?
dsyed1 is offline   Reply With Quote
Old 01-09-2010, 08:20 PM   #1691
RTR canada's Avatar
I ran my 009 with 96 and 35 with the 107 update i like the low end but need a little more speed? Any ideas? My motor temp was 125f. Thanks
RTR canada is offline   Reply With Quote
Old 01-09-2010, 08:36 PM   #1692
dsyed1's Avatar
what motor and speedo are you running?
Old 01-10-2010, 11:11 AM   #1693
RTR canada's Avatar
im using the 2.0pro and 3.0motor in the 17.5 class.
Old 01-10-2010, 01:32 PM   #1694
TryHard's Avatar
Too anyone who says the SP speedo is a bit big... it does fit in almost anything! (only a minor bit of bodyshell shaping need ). Some thinner motor wires and superflexy sensor lead are on their way to make it neater still
Actually tried out a few bits today, switching between the 323a, 110 and 107 Stock firmwares. Have to say, I prefered the 107Stock, but with the timing up at max, and DRRS at 7. Plenty of rip out of the corners, and good (it seemed) top speed. Was a bit hard to gauge as I was the only 12th running round, so was just going off lap time and feel. But for my first time out with a 12th, felt really good
Ed
Old 01-10-2010, 03:38 PM   #1695
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Nice job there Ed.......what motor and roll-out? If I may ask
4cell nimh vs 1s lipo, the extra volt might make enough difference to be able to run the 107 and 110. I found that I couldn't run those on 1s 13.5. If that is a mod set-up you have got there....the extra revs might account for the usability of the new software. (noticed itty-bitty pinion)
Does your set-up run ok without a booster or rec pack? 5, 6 or 8 min run time?
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
