Old 04-30-2009, 07:25 AM   #151
abailey21's Avatar
Trader Rating: 36 (100%+)
Thanks Marcos I would have answered those but I don't run mod at all in TC lol
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-30-2009, 07:53 AM   #152
xraysteve's Avatar
thanks for the info marcos. thats a great help for me.
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 04-30-2009, 08:00 AM   #153
xraysteve's Avatar
can you plug the GT2 Pro carbon edition into a computer if so where can i buy the plug.
Old 04-30-2009, 08:04 AM   #154
abailey21's Avatar
Your going to need wither the LCD Programming box (SPLCD01) or the motor checker (SPBA01).
The receiver cable will plug into either of those boxes then plug into your computer.
K.C.C.O.
Old 04-30-2009, 09:42 AM   #155
xraysteve's Avatar
What does the LCD Programming box do for me. Does it let me make finer adjustment then the hand held it came with. Are there any update I can get for it off the web.
Old 04-30-2009, 09:45 AM   #156
abailey21's Avatar
The LCD box works the same as the stock box that comes with the ESC but you get the USB port to update the ESC software, as well as finer adjustments on things like drag brake where you can have a custom level of drag brake, not just the box settings
K.C.C.O.
Old 04-30-2009, 10:21 AM   #157
Super Moderator
Marcos.J's Avatar
Trader Rating: 141 (100%+)
lol
no problem
Old 04-30-2009, 10:27 AM   #158
abailey21's Avatar
Marcos can u jump to the Schuie thread I have a couple guys asking a question you have the answer too
Originally Posted by Marcos.J View Post
lol
no problem
K.C.C.O.
Old 04-30-2009, 10:45 AM   #159
asw7576's Avatar
Originally Posted by MTX View Post
Can anyone give me some suggestions. Thx
I just installed new ESC (SP GT2 Pro carbon edition) on T2009 xray. I intended to use LRP brushless motor (3.5 turn with 13mm sintered). and running Lipo 7.4v 5000nimh 30c.
My questions.
1. what is the best FDR (ratio) should I run?
2. What is the max temp of my motor and esc should I run for safety?
3. Can i measure torque using SP brushless analysis tool
So you still looking for 2nd opinion huh ??
10.50 FDR is already safe range.
Max temp for Motor is 80C ( after 5 min run )
Max temp for ESC is 80C ( after 5 min run )
Max means max, don't cross over it.
Old 04-30-2009, 10:54 AM   #160
Super Moderator
Marcos.J's Avatar
well if I must
I have another 6 pack for you
Old 04-30-2009, 10:56 AM   #161
abailey21's Avatar
Thats good to hear cause I'm detoxing right now
well if I must
K.C.C.O.
Old 04-30-2009, 11:08 AM   #162
Super Moderator
Marcos.J's Avatar
I got that posted on the Schumacher thread
Old 04-30-2009, 11:48 AM   #163
hobbipro's Avatar
Trader Rating: 21 (100%+)
I just picked up a LPF 2.0 carbon edition, and have one question. In the set up instructions it shows a LED that is somewhere on the solder posts side that you can look at while programming your radio set-up. For the life of me I dont see the LED, even a place for it. I even pealed the "A,B,C" decal back a little to see if it was covered up. However I do hear the set-up tones and got it done. Just wonder what I'm missing, or not seeing.
hobbipro is offline   Reply With Quote
Old 04-30-2009, 11:50 AM   #164
abailey21's Avatar
Just use the tones, the led's are burried lol
It was a small design flaw, they're in there but you can see them
K.C.C.O.
Old 04-30-2009, 12:21 PM   #165
hobbipro's Avatar
Guess someone forgot to make a small "window" to see the LED!
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
