Like Tree12Likes
Old 12-31-2009, 01:20 PM   #1576
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by razzor View Post
On the lcd programmer when you connect it to the esc the last button on the right will toggle between the 3 stored settings.
You can also name these settings in the software before hand so its easy to identify.
Good to know..i never put more than one profile at a time..im gonna have to start doing that.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 12-31-2009, 04:34 PM   #1577
abailey21's Avatar
Trader Rating: 36 (100%+)
I find it interesting I preach to you guys on a daily basis on the importance of good solder, and a good soldering iron, Yet I caught myself using some cheap ass solder that ruined the tip of my Hakko tonight...
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-31-2009, 10:25 PM   #1578
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Originally Posted by TC4Racer123 View Post
My Speed Passion 17.5 motor will be coming in the mail soon. I will be using it with a Novak Havoc ESC (i know... i do want the 2.0 LPF, but i really don't have 200$ to drop on an ESC right now..) in a TC4. Usually i use a Venom 5000 lipo. The internal drive on the TC4 is 2.5. Right now I'm using a 68t spur and a 35t pinion with the Havoc, for a FDR of about 4.8 I think. What do you all think would be a good FDR to start with? Thanks
Dan
I'm currently running 3.57 80t x 56t pinion (64p) on my team carbon tub tc4, with a SP 1.1 and v3 17.5 motor timing max for a smallish indoor track here, temped at 150 to 170f. For a large local indoor track(60x100) I've gone down as low as 3.39 (59t) temped around 160f.........trackpower 4900 gold brick....
anyway......run a few minuets and watch temps and LAP times, one may go up and the other down. Gear for lap times!
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 12-31-2009, 11:27 PM   #1579
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
Adam- Are you guys taking fri off or will you be at the shop? I need a motor... so if nothing else you can send it my way monday... be a nice b-day present if i get it on wed...lol
17.5 and 13.5
Thanks,
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 01-01-2010, 04:18 AM   #1580
Stusdal's Avatar
Hi
Got the GT 2.0 Pro. And will be running eigther a LRP 9,5T motor or a Corally 5,5T. I'm running 2Cell Lipos.
What Start mode and timing would you suggest for the two motors?
Serpent || Futaba || Protoform || Orca || GensACE || Sorex ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 01-01-2010, 04:11 PM   #1581
Born2Run's Avatar
Could someone tell me where i can download the latest software update? I cannot find it on speedpassion.net
Whatever
Born2Run is offline   Reply With Quote
Old 01-01-2010, 04:14 PM   #1582
Default Download 1.32??
Hi all. Happy New Year!!
Can someone please walk me through the 1.32 download process. I'm using a friends LCD programmer until mine arrives and would like the new prog.
Thanks much,
Rob.........
*Restructuring* :)
Robio is offline   Reply With Quote
Old 01-01-2010, 04:18 PM   #1583
Ah Ha! That much I know.
If you go to the SP site, go to "accesories", Click on the LCD programmer. When the page comes up there will be buttons across the top. Click on "downloads". There will be a file for the new 1.32 program. If that's what you're looking for, that should do it.
Rob.....
*Restructuring* :)
Old 01-01-2010, 04:25 PM   #1584
Born2Run's Avatar
Rob.....
I found it.It wasn't on "accesories" but on "optional parts" Thanks a lot.
Whatever
Old 01-02-2010, 12:28 PM   #1585
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
so is it confirm that 110 is a good software for 13.5?? i will be testing my new gt 2.0 lfp and is in the process of downloading a new software..
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 01-02-2010, 01:37 PM   #1586
Stein Tumert's Avatar
Have tested for 2 days both 107 and 110 with SP 13.5T V3 motor on an indoor track (medium size/fairly tight/about 10 sec laptime). All settings in ESC maxed out as well as the timing on the motor set to max. Rubber tires (Sorex 36).
The 107 feels faster (more push/aggresive), but the fastest laptimes as well as 5 min total came with the 110 version. It feels a bit softer than the 107 version, but is still fast. Improved personal best over 5 min with one lap (about 10 seconds) with the 110 software compared to recent personal best with the GM120 ESC/GM13.5T motor as well as 2 tenths on laptime, so the 110 it will be for the next race
Motor temp was about 55-57 degrees Celcius with 110 after 6 minutes. With the 107, the temp increased to 70 degrees celcius (about 170 F) after 6 minutes. FDR was 6.35 which is max allowed in our local winter champs.
Can imagine the 107 would be better on larger track. Will test 107 (or any replacement) later when the snow is gone and the outdoor season starts again in the spring...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is online now   Reply With Quote
Old 01-02-2010, 02:03 PM   #1587
Trader Rating: 20 (100%+)
Default Help me figure this out.
I downloaded the new software for my SP 2.0 LPF. I am running a 13.5 class at my local club. From what I have read the 110 is way to go? I am running a cyclone tc with a sp 13.5 first gen motor. Can some one me point if in a good set up for my esc, also what FDR should I start with. Remember my SP 13.5 is the first gen.
Second question I trying to set up my sons car to run VTA 21.5 on a HPI pro 4, Again same question as far a starting setting and FDR. Same ESC, hovever the motor is a Novak 21.5 ss.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 01-02-2010, 07:35 PM   #1588
Sterlzy's Avatar
Trader Rating: 29 (100%+)
Hi all,
Can someone please tell me where i can get my hands on these 2 Speed Passion products and that actually have them in stock?
I need the new Speed Passion 98802prob GT-Pro Brushless ESC Version 2
and also a 138115v3 competition 3.0 Brushless 11.5 Motor.
I need these asap as i need to do some testing before TITC.
Regards
Ben
Sterlzy is offline   Reply With Quote
Old 01-02-2010, 08:17 PM   #1589
caltek1's Avatar
Trader Rating: 35 (100%+)
Try Team Twister in Sydney.
http://teamtwisterhobbies.com/index....b7bfc9ae63fda4
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 01-03-2010, 03:38 AM   #1590
Originally Posted by Sterlzy View Post
Hi all,
Regards
Ben
Hi,
You can also try Tom @ FormulaRC - www.formularc.com.au
Can send overnight via Express Post.
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
