The Speed Passion Thread >
Like Tree57Likes
Old 12-30-2009, 12:10 AM
  #1531
Stein Tumert's Avatar
Originally Posted by TC4Racer123
I just bought the Speed Passion 17.5 on A-Main, should be here within like, a week. Will i ned to buy those motor clamp things for the wires? or will the wires just solder on? or doe it come with them??
Dan
Comes with the motor...
Stein Tumert is offline
Old 12-30-2009, 12:19 AM
  #1532
1.32
stock 107 or 110
312
323
Is there a reference table?
What is what? what is the difference between different software?
I myself use Orgnial Software that is from the factory (what is this?) (GT2.0 carbon)
Run Schumacher mi3.5 with 90 main drive, 39 pin .= 4.15 (v3.0 17.5 engine) engine is around 52 degrees C (as recommended by there for me in the program path)?
So I have ordered an LCD programming box to experiment with the software, but then of course want to know what those are different and makes the difference
Zooberg is offline
Old 12-30-2009, 01:16 AM
  #1533
Super Moderator
charlie_b's Avatar
1.31 Older firmware
1.32 Latest Firmware
stock 107 or 110 Latest programs for Stock Racing Only
312 previous program for Stock
323 Previous program for Mod/13.5
It is more feel than anything...it all depends on your driving.
I myself use Orgnial Software that is from the factory (what is this?) (GT2.0 carbon) 205G is what came with your ESC.
To make it simple, just download the latest firmware(1.32). if youa re only gonna run stock(8.5-21.5) then your 2 choices are 107 or 110. For mod, 205G or 323. You really don't need to worry about the rest, nor will the average racers ever really feel the difference anyway.
Anyway, hope this simplifies things. Making things more simple always makes for a better race experience.
Cheers from the USA, Sweden!
charlie_b is offline
Old 12-30-2009, 02:16 AM
  #1534
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
charlie b, are you relating the above to 2 cell lipo/ 6 cell nimh applications?
you/we must get the LCD box to read what the program is/came on our esc. My 2.0 lpf carbon came with 323 on it. might be different for the PRO model?
Great explaination above
I run 12th with the lpf, 13.5 and 17.5.......323 on 13.5 very smooth, 323 on 17.5= total mush! Have run 312 on 17.5, excellent results. I talked with Adam and he confirmed that this was the way to go......Yes, we're talking more about the newer/newest releases here, I'm just out on the edge making this work for 1 cell lipo. Seems this changes the line between 'stock' and 'mod'.
What ever happened to the "Burn yer Motor up" profile?
Drillit is offline
Old 12-30-2009, 02:25 AM
  #1535
Super Moderator
charlie_b's Avatar
Originally Posted by Drillit
charlie b, are you relating the above to 2 cell lipo/ 6 cell nimh applications? Yes Sir
you/we must get the LCD box to read what the program is/came on our esc. My 2.0 lpf carbon came with 323 on it. might be different for the PRO model?The newer batches came with the newer 323 programs. The 1st generation 2.0's came with the 205G. In any rate, upgrading to the 1.32 firmware should be a much better choice if one wants to upgrade.
Thankyou again.
Old 12-30-2009, 02:35 AM
  #1536
Drillit's Avatar
I thinks I might start calling California rather than Florida for info
Gotta be easier on my cell bill..........
Drillit is offline
Old 12-30-2009, 02:47 AM
  #1537
But another thing I thought of ..
What are the differences more precisely between them different .. What happens between them different?
More RPM? less? punch curves? Yes, what happens?
Zooberg is offline
Old 12-30-2009, 03:13 AM
  #1538
cyanyde's Avatar
you mean like tekin?
Nope. Even tekin does not allow you to dictate timing/rpm. Its only how much fixed timing, then turbo timing at a certain time after full throttle. I'd say currently only Mamba Max Pro allows better tweaking as you can program 0-Max Timing to start and top out at a certain rpms.
cyanyde is offline
Old 12-30-2009, 03:55 AM
  #1539
Super Moderator
charlie_b's Avatar
Between shawn and adam, they really have a lot on their plate. Solara does a good job answering as well...so i wouldn
t be too hard n adam and shawn
Old 12-30-2009, 03:57 AM
  #1540
Super Moderator
charlie_b's Avatar
Non of us knows for sure...thats why there are several trying them out and reporting this. There is no graph for us mortal folk to look at.
Old 12-30-2009, 04:53 AM
  #1541
Drillit's Avatar
Yes, those boys down there are absolutely awsome to deal with!!!!Thanks for your help and thoughts on the matter of Speed Passion
Drillit is offline
Old 12-30-2009, 05:38 AM
  #1542
No, I only bought a motor, I kept the esc. Do I need to get new wires??
Edit: nevermind, I read that comment wrong. Sorry, and thank you for the answer!
TC4Racer123 is offline
Old 12-30-2009, 01:12 PM
  #1543
Trader Rating: 17 (100%+)
Originally Posted by seaball
i ran the 110 software with a 13.5v3 geared at 4.24 on a 90ft track... (full timing, drrs at six or seven) and a fairly soft trigger finger.
See....the track I was at would be no use for 4.24 unless I go only 1/2 throttle....I would definitely try that @ Trackside and Harbor. I think they are close to 100 feet straight.
Solara is offline
Old 12-30-2009, 01:21 PM
  #1544
Adam and Shawn are both awesome to deal with...if you have waranty or ordering question, they are the only ppl you should deal with. But here on SP thread, any one of us who owns SP products are more then happy to help answer your question and share setup/opinion....
Afterall, we are those who get our own speedo fired, motor burned, months before SP release the 1107 and 1110 software.....we did the hard part so you don't have to.
Solara is offline
Old 12-30-2009, 01:25 PM
  #1545
Super Moderator
charlie_b's Avatar
Originally Posted by Solara
we were the one who get our own speedo fired, motor burned,
Was Adam talking about me again??? LOL
