Old 04-06-2009, 12:18 PM   #1
Krupted's Avatar
Post Team Assoc. 18r
I have a big problem with my 18r. I'm getting tired of messing with the steering trim all the time. How or what should I do to fix this Wheel slop problem. And where can I get it?
Losi 22m 2.0
Losi SCTe
Axial SCX10 Deadbolt Crawler
Krupted is offline   Reply With Quote
Old 04-06-2009, 12:40 PM   #2
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
This question should be in the Micro/Mini section.
Depending on how much work you want to do, a turnbuckle steering system would work. Another route that you may want to take is purchasing the Xray M18 Servo Saver kit as well as the Driven Productions Steering Drag Link.
IIGQ4U is offline   Reply With Quote
Old 04-06-2009, 12:45 PM   #3
Ffejdat's Avatar
You can try the micro forums under this forum, they have whole threads on the 18b,t, and r cars. couple things to try, the stock servo saver is very weak even when new, some people tighten them up with an o ring stretched over the spring part of the servo saver, or they get an aftermarket stonger metal spring, I myself would at least replace the stock servo saver with a brand new Associated one, including the front and rear part with the little tab that the spring part grabs as this wears out and then there is slop no matter what. You can also run an aftermarket drag link to take out some slop, bottom line though, htese 18's often have a little slop in the steering no matter what, go check out the micro forums for more fixes, try bigboytoys website for parts.
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
team assoicated 18r thread! nitsuj2k Micro and Mini Scales 1205 11-03-2015 03:08 PM
SEO by vBSEO 3.5.0
