Old 01-16-2010, 10:25 AM   #1366
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey guys, would anyone know where I can get the U1301 diff grease in stock from a USA based shop preferably? Tried finding it on the Schumacher USA website, but a search for the number came up dry. Thanks for any help!
Old 01-16-2010, 10:52 AM   #1367
abailey21's Avatar
Trader Rating: 36 (100%+)
I know i have some on the shelf, but check A Main cause they may have some and their closest to you
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-16-2010, 10:55 AM   #1368
No luck on their website, I'll give you a shout on Monday!
Old 01-16-2010, 11:05 AM   #1369
abailey21's Avatar
I look forward to another heart to heart with you Randlemen
K.C.C.O.
Old 01-16-2010, 05:57 PM   #1370
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by grippgoat View Post
Hrm. The manual doesn't say anything about gluing the chassis like the XRay manuals do. Is gluing recommended or not? If I glue it, is tire glue OK, or should I get some other kind of CA?
-Mike
some say ca-ing the edges can make it tweak, some say no way, I sand my edges with 400 grit, CA (thin or med tire glue) the edges, and resand with 600 or 1000 grit. I also sand the faces of the chassis, (just cause i don't want to freak out when the shiny stuff gets scratched). your equipment will work fine, if dropping in a 21.5 for scale spec (our version of RCGT) your going to need a smaller spur gear then what comes in the kit. you will need a schumacher spur. if using a silvercan the stock spur will be fine.
I have a pretty good setup, build as the manual says, the the following changes, rear of car.. 30wt rear shock oil, go to the outter hole on the rear hub, 2mm spacers under balls on rear camber link, rear shocks leaned all the in.
front.. 2mm spacers on hinge pin holders, 1mm spacer under balls on camber link plate, (instead of under the plate) 40wt shock oil. front diff high, rear diff low. mazda speed 6 body.
stop by the pit anytime for help/spare parts
pick up 2 two groove camber plates, 2 one groove plates, set of arms front and rear, extra set of medium front c hubs and one set of steering knuckles and one set of narrow front hexs for the mi3, one set of complete cvd's then figure out which spurs you might need. you should be good to go after that, anything else you might need, i might have.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 01-16-2010, 06:05 PM   #1371
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Skypilot,
What are the premises of this class you speak of? How popular is it, what are you guys running, how are people taking to it, ETC ETC.. Looking for a good budget class for my summer parking lot series. Lot of interest in running a basic class for people that have older tub cars (xxx-s tc3's) that don't wanna move up rite now. Most of us don't wanna run RCGT bodies, because we want people to wanna move up classes and not stick to one.
-Mike
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 01-16-2010, 08:22 PM   #1372
skypilot's Avatar
click on link and scroll down to Scale Spec.
http://seattlerc.files.wordpress.com...race-bible.pdf
Old 01-16-2010, 10:01 PM   #1373
Thanks for the tips. I've already ordered the Subaru body, so I'll definitely be going with that to start with. I'm sure I will have destroyed it by the time I stop sucking enough for the body to really make much difference to my overall race performance. I'll be running a pre-painted 200mm HPI Impreza body in Scale Spec to replace my NSX body which has more tape than plastic at this point.
I haven't looked at the gear charts on the Mi4 yet, but I've been running 4.6 FDR in Scale Spec, and I think even higher can work with the new Tekin software. I don't know what people have been running for stock touring.
If I'm going to be investing in gears, do you think I should go with 64p or 48p? All my pinions are 64p (35, 42, 44, 46, 47, 50), but if the grit comes back, it seems like 48p might be better. I also imagine 48p might be better on asphalt in the summer. On the Mi4, do people usually adjust gearing with the spur or the pinion? Or both?
Owen: Is the parma bumper something that's a specific fit for the Mi4, or a universal part that requires trimming? Also, did you sand + paint pen for appearance, or for durability? Or both? Does the sanding add durability without CA?
-Mike
Old 01-16-2010, 10:23 PM   #1374
-Mike
I don't really care about durability since I run asphalt, so it is for appearance.
And Parma makes a specific Schumacer bumper.
-Mike
Old 01-17-2010, 10:22 AM   #1375
skypilot's Avatar
the parma bumper is thicker then the stock schumacher bumper. my first one i tried to cut down. didn't really like the looks of it, so the second one i used spacers on the top plate to make it work, your welcome to the cut down bumper if you want it and if I can find it.
Old 01-17-2010, 11:22 AM   #1376
I just got my new Mi4LP Pro! :-)
+ YouTube Video
andy3000 is offline   Reply With Quote
Old 01-17-2010, 11:29 AM   #1377
Just need black turn buckles and the rest of my electronics
Old 01-17-2010, 11:33 AM   #1378
nice looking car
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 01-17-2010, 08:41 PM   #1379
Originally Posted by SRW141 View Post
nice looking car
Thank you sir
Old 01-17-2010, 09:08 PM   #1380
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Its only taken you a month and a half to get that far!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
