Old 01-11-2010, 10:44 AM   #1336
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by abailey21 View Post
I can't wait till i get that call after you "race" with a car broken in half cause you cant drive
Lmao you sponsor me!
If my car is broke In half, what does yours look like after you run 25.5?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-11-2010, 02:30 PM   #1337
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
it doesnt matter he just builds another one
Old 01-11-2010, 08:05 PM   #1338
The Bear's Avatar
Adam, your witisisms are lacking and you are posting them to people who care more about what color the car is than what place it comes in.
yeah, I said it.
Now who has a setup thats battle tested against top tier drivers? Lamberts setup has seen it's share. While it calls for a more sensitive feel on the lift, it is balls fast. Who has the competition to gauge against and where are the ideas?
I'll pose 3 to shred/dismiss or consider:
1.) a bushing in place of the bearing on the steering post to remove a little of the up-down slop
2.) a thicker pin in the cvd: the set screw can warp it so easily
3.) a thicker graphite on the acerman and steering plate: 3mm?
g'on, do your best/worst
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 01-11-2010, 08:14 PM   #1339
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
yeah, I said it.
We can win, and look good.
And at least we take pride in our car's
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 01-11-2010, 08:20 PM   #1340
yeah, I said it.
http://www.RCRacing.com/Page.cfm?Inf...ceResultsID=23
The names Brandon Clements look it up. The look of my car has no effect on how it gets driven, it is no shelf queen, I dont run with yahoo's.
1- File the post down till its flush with the bearing. Takes the slop out. If you want to get the slop out of the casters, drill and use a grub screw to hold the cvd pin in, gets rid of the e clips, and takes slop out if you do it right
2- Dont crash, you wont bend the pin! Simple fix. If you want to go to something tougher, Run a TIR spool, with tamiya steel CVD's
3- No answer.
Old 01-11-2010, 08:20 PM   #1341
At least Adam may know how to spell "witticisms"
Old 01-12-2010, 06:24 AM   #1342
Trader Rating: 10 (92%+)
Hi, I'm an off road guy thinking about venturing into on road. I have a few noob questions.
I will ask these questions as if I am buying a 'race' s1 version. Below is what I know the differences.
* Tough S1 composite chassis and top deck with optimized flex.
* Tough S1 composite shock towers.
* Simplified shock design for ease of use.
* Plastic driveshafts & hexes with steel axles.
* RACE spec carbon chrome diff balls & thrust bearing.
* Short Medium flex wishbones for improved impact absorption.
how good are the 'simplified' shocks on the 'race'?
plastic drive shafts? doesnt sound very assuring and sound like they wont be reliable, someone correct me if im wrong.
short arms are not available where I will be ordering my kit. How much are the normal arms longer, and what handling affects?
I would gather the plastic driveshafts wont last very long, and hence would it be better to go all out and buy a 'pro' kit?
What parts break the most?
how much would it cost to upgrade to the 'pro' shocks and driveshafts? So basically a composite 'pro'!
Lastly, I assume the 'race' comes with a ball diff in the front. What parts do I need for a spool? I have heard spools are better, for 17.5 stock racing at least.
captain stacker is offline   Reply With Quote
Old 01-12-2010, 06:31 AM   #1343
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
how'd the regionals go?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-12-2010, 07:20 AM   #1344
abailey21's Avatar
Trader Rating: 36 (100%+)
My witticisms are lacking so badly I can only spell!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-12-2010, 02:59 PM   #1345
The Bear's Avatar
Glad you guys took the post well!
Blkdoutrvo - Excellent, looks like you are comfy with you setup!
1.) really? Just file it down? *I'm sitting here with files, so... really?*
2.) well,, I typically run for pace than hot lap and while I can't say I don't sometimes leave an impression on our boards, I'm still finding more wear than I'd like...... could easily just be me though. For those 'rare' times I do though, I'm thinking a kydex bumper plate is my next move. hate or love the idea?
3.) I have chewed through 3 steering plates, is my reason for bringing it up.
Captain Stacker - In my most humble opinion, "run what you brung". plastic or alloy, just get to the track to have a good time and learn. Enjoy the larning curve and take it one step at a time, you could easily go as cheaply as possible and build up as the need calls. Gets you to the track the most with the least effort. Eventually you'll want to upgrade and get 'this' or 'that' but just go to try and get laps in. Good luck!
Owen - nice call, it won't be the last time I flub a funny on spelling. I'm down with a good looking car, but the most frequent question for Shui drivers seem to be the looks. And really, thats fine, but it's an easy mark to make fun of
Sir - I managed to teach and make a qual at the race, put me 3rd behind Haynes and Amato. It was good enough(with a couple tweaks) that I was in second when I managed to break out my bad. Pulled some lap times on par and I thank you for returning her to me unharmed. I'll try again when I have something a little more solid.
Heading to the January Jam this weekend, we'll see......
Old 01-12-2010, 03:31 PM   #1346
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I don't know if the Mi4 is like the Mi3, but on my Mi3 I used a 5 mm D X .2 mm tamiya him . They come in a package of 15 shims I think. 3 X .1 m, 3 X .2 mm, and 3 X .3 mm. They are also pretty pimp when it comes to shimming any unwanted play out of the axle/CVD components. Credit goes to seabass for that one. I only discovered it after tearing down McGoo's car at his kitchen table after his famous Nats run.
Old 01-12-2010, 05:26 PM   #1347
Rdog's Avatar
Trader Rating: 83 (100%+)
What spur gear are you guys running for 17.5 and 13.5? 64 pitch? Thanks guys
Rdog is offline   Reply With Quote
Old 01-12-2010, 05:29 PM   #1348
picco007's Avatar
Trader Rating: 87 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
I have a 114 in my car for 17.5......
EA Motorsports
picco007 is offline   Reply With Quote
Old 01-12-2010, 05:33 PM   #1349
I'm using a 106 right now. But thinking about changing to 114
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 01-12-2010, 05:54 PM   #1350
qcrc's Avatar
Bear, I see that you are thinking about using a kydex bumper. Are you breaking parts? Since the Mi3 and the MF arms came out I have rearly seen a broken front end on a Schuie. The only thing that seems to go in a wreck is the bumper itself. Has anyone ever tried to do what they did with the rear shock tower by moving the body mounts to the outside of the bumper? It would add some strength to the bumper and it would help stiffen up the body as well. So far that seems to be my only gripe with the car. It goes together as it should and with a few tweaks it is as slop free as any car out there.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
stuartkeith
