Old 01-06-2010, 09:54 AM   #1306
Because with the bearing protruding from the hub, running the narrow hex makes the offset the same as the rear.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 01-06-2010, 01:27 PM   #1307
Ritchie T's Avatar
Exclamation
Ok thanks guys.
Can i just take a pair off the mi3? Are these narrow enough?
Ritchie T is offline   Reply With Quote
Old 01-06-2010, 01:35 PM   #1308
CA
The narrow hex reduces the offset between the king pin and the hex. Generally it gives more steering.
All the top UK team run with this set up with 2.5-2.75mm of washers against the pivot block.
Std hex in the rear with 1mm washer against the block.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 01-07-2010, 09:15 AM   #1309
Ritchie T's Avatar
Exclamation
Ha was just flickin through the manual and clocked your in the back
Yer just noticed now you and Grainger wrote Narrow Hex U3570 under driver notes. Ill have to snap a pair up soon. By standard in the rear do you mean the ones that come with the kit?
You also wrote under tyres Sorex 28 JB, i usually use the 28's a lot but i dont think theyre JB. Whats the difference?
Get to try it out for the first time tommorow woo
Old 01-07-2010, 06:11 PM   #1310
Default Schumacher on the tube.
Adam did you happen to catch Robin Schumacher on www.rctvlive.com?
He is on the latest episode. What were you doing back then?
Enjoy.
Ginsu is offline   Reply With Quote
Old 01-08-2010, 08:19 AM   #1311
Originally Posted by Ritchie T View Post
Ok thanks guys.
The Mi3 ones are a different part no to the Mi4 ones, so guessing they won't fit.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
Old 01-08-2010, 08:21 AM   #1312
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
yeah. from the mi2ec to the present mi4lp, the axles have the same geometry. (they have changed materials, though, as have the bones).
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-08-2010, 08:23 AM   #1313
I can answer that for Chris, the standard in the rear are the ones that come in the kit.
The Sorex tyres with the JB have a foam insert in rather than the grey rubber insert in the other type available. The JB version has more grip, and equates to being about half a second a lap quicker. This is on carpet, I wouldn't like to say what they are like outside.
Keep us posted on how you get on with the car, good luck!
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
Old 01-08-2010, 09:03 AM   #1314
Ritchie T's Avatar
Exclamation
Thank you for the replys John and Seaball.
In a couple of hours ill be trying kit setup but next week ill order some narrow hexes and stick the spacers on the front and give that a blast
Thanks again
Old 01-08-2010, 09:29 AM   #1315
turbodog's Avatar
aluminum hexes
U3525 wide hex (comes with Mi4)
U2991 medium hex (comes with Mi3)
U3221 super narrow hex (option part)
U3570 ???????? don't see this one listed
Troy Schafer
turbodog is offline   Reply With Quote
Old 01-08-2010, 09:37 AM   #1316
lochness42's Avatar
Originally Posted by turbodog View Post
aluminum hexes
Use search function next time on shumacher's site http://www.racing-cars.com/pp/New_Ca..._CF/U3570.html
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-08-2010, 11:21 AM   #1317
turbodog's Avatar
lol I tried the search on the USA side of the site and it's not there........i guess we are always the last to know.
thanks!!
So I am assuming the U3570 are like the U3221 but o-ringed?
Troy Schafer
Old 01-08-2010, 11:37 AM   #1318
lochness42's Avatar
thanks!!
I guess so, I've got only older version without o-ring.
Pavel Balint
Old 01-08-2010, 11:40 AM   #1319
seaball's Avatar
aluminum hexes
here's a quick (but incomplete) synopsis: (and in chronological order)
2991 - 3.9mm wide (mi2ec through mi3.5 kits - oring style)
3221 - 3.9mm wide (slip-on, no o-ring, released for mi3)
3525 - 4.9mm wide (mi4 kit - oring style)
3570 - 3.9mm wide?? (no idea what's different)
Old 01-08-2010, 12:29 PM   #1320
turbodog's Avatar
U3221 and U3570 are less than 3.9mm, don't have the U3221 in front of me but guessing it's 2.99mm. U3221 is slip on no o-ring/ U3570 has o-ring according to description.
Troy Schafer
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
