Old 12-22-2009, 03:55 PM   #1186
Trader Rating: 22 (100%+)
Default traction roll
Originally Posted by steveonamission View Post
Less rebound.
Wider trackwidth
Glue the front sidewall
Im beginning to become an expert at grip role over years on high grip carpet and sometimes still struggle myself in curing it!
thanks i will try but i want to figure this out without gluing the sidewalls. how about shock position front and rear
D-Bizzle is offline   Reply With Quote
Old 12-22-2009, 04:06 PM   #1187
Danny-b23's Avatar
If you have a full metal geared servo?,if not, get one.... then there should be no need for a servo saver...running your steering direct has a much better feel in my opinon.
Yep, just one servo mount, and double sided down.
I agree unless you run indoors. If you hit the boards the wrong way just once, it could cost you a $90 servo.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 12-22-2009, 04:13 PM   #1188
Ritchie T's Avatar
Exclamation
Running KO 2123 but in my mi3 i was stripping the plastic first gear when i had an off with a solid arm, i do a lot of indoors you see.
I just picked up my kit today but santa says i cant build it untill the 25th so im trying to get all the odds and ends i need
Ritchie T is offline   Reply With Quote
Old 12-22-2009, 04:25 PM   #1189
steveonamission's Avatar
If the cars feeling edgy before the grip role, then laying the rear shocks down will help.
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 12-22-2009, 04:36 PM   #1190
skypilot's Avatar
Trader Rating: 14 (100%+)
call adam at shouie and order some spacers and a spring set, don't think i will be back before your gonna run again. also if the front arms have M on them order the CF ones
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 12-22-2009, 04:50 PM   #1191
I do run indoors aswell, but havent had a problem with running without a saver and i'm no CG,so i like a good crash now and again especially in mod, but maybe im just lucky, none of the top schumacher uk drivers i know of use one.
Old 12-22-2009, 04:53 PM   #1192
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I just strip the servo horn. Ive blown up one since I got my car from a nasty crash. Indoors was when it happened. I had the same issue with my cat sx, no saver and the horn would strip. Stronger horn and the plastic gear in the servo would strip. But still I dont like using a servo saver
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 12-22-2009, 05:09 PM   #1193
Ritchie T's Avatar
Exclamation
Do you get a plastic arm in the kit?
Old 12-22-2009, 05:18 PM   #1194
Yeah
Old 12-22-2009, 08:51 PM   #1195
picco007's Avatar
Trader Rating: 82 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Hey guys, i received my Mi4LP last a couple of weeks ago and put it together. My buddy and I ran our Mi4LP's on a practice day on a prepped asphalt track with air temps of almost 70 degrees F. The car was great out of the box with the kit springs. I needed a little less rear traction so we messed with droop and thought about changing springs.......while there, I widened the rear close to a millimeter on each side to free up the car. The car was better.....my question is what springs would anyone recommend if I need to change them. I have the xray black springs from my previous car but would like to get your input.....
We ran rp36's and seemed to have enough traction for sure..... Once these are done I'm thinking of going to sj-r's, any advice would be greatly appreciated.
I'm loving how easy the car is to work on.......... I will tell you, this is one of the best thought out cars..... I'm a Schumacher fan for life!
EA Motorsports
picco007 is offline   Reply With Quote
Old 12-22-2009, 10:38 PM   #1196
What pound rating are the xray springs?
The kit springs are a bit soft. The car has alot of traction for sure! How much rear toe were you running? That will make a huge difference, and what swaybars? And what shock oil?
Glad your happy with the car! Schuie really did it right with the Mi4! Another happy Mi4 owner
Old 12-23-2009, 06:16 AM   #1197
jhock's Avatar
Lower your inner camber links. I think the LP kit tells you to put shims under the bracket, take those out and put the shims under the ballstud. For asphalt the stock springs Blue/white are the way to go. or even White/White. When you widen the rear it actually makes more traction. Set your droop at 5 front and 4 rear using the droop blocks. I personally run RP tires and love them. Its not the tires.
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 12-23-2009, 07:20 AM   #1198
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Johnny Wishbone View Post
Hey Chris any pics of your Mi4?
i'll see what i have. was there something in particular you're seeking?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-23-2009, 08:07 AM   #1199
Johnny Wishbone's Avatar
Inspiration and motivation.
Old 12-23-2009, 08:07 AM   #1200
Danny-b23's Avatar
Danny Buck
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
