Old 04-05-2009, 10:24 AM   #106
I wish I could find another SST 99, that was a good car. This car looks really good, I just can't afford it
JoshM20 is offline   Reply With Quote
Old 04-05-2009, 03:00 PM   #107
Send a message via ICQ to MattW
All, don't concern yourselves with the motor twisting. We've been talking about this one today. Regardless of what has been posted, none of us have suffered from motor twisting - period!
Myself and Chris G had shunts when we ran today that would have caused a motor to move IF there was an issue - neither motors moved. Simple as really.
MattW is offline   Reply With Quote
Old 04-05-2009, 04:30 PM   #108
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Questions??
I know it's probably odd lens focal distances, but the steering bellcrank looks to have some odd angle in it (in a couple of photos). Is it intentional, bent or prototype parts in short supply?
Looks like the left side is bent...
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 04-05-2009, 07:26 PM   #109
Mopar's Avatar
I think the angle is intensional so you can change the ackerman by adding or subtracting spacers and moving the pivot position front or back. Thats the way I see it.
Mopar is offline   Reply With Quote
Old 04-05-2009, 10:05 PM   #110
Drifting101's Avatar
My adding spacers ball studs get closer together and by removing the they widen. Then move the whole steering block froward/back to get closer/furthur
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 04-06-2009, 05:34 AM   #111
Skiddins's Avatar
From Chris Grainger;
Hi All
I will try and answer as many things as I have seen posted, some may be off other forums
The car is very good, clearly faster than the Mi3.5 for me anyway. The areas that needed looking at have been addressed without just copying the crowd. Longer top deck. two piece rear bulkhead.
The Motor mount is fantastic, Its almost the perfect design as it does not touch the chassis at any point, so the flex of the car is perfect left to right. The clamp works 100% fine, never had it move never seen it move.
The steering that nobody seems to have noticed is very cool, the mounts angled in so the ball joint does not over rotate.
The drivetrain is the same as on the Mi3, diff spool center pulley spur belts driveshafts etc.. Only thing new there is the diff and spool pulleys are now lighter and narrower..
The layshaft is hard to explane,but a very cool design the way it works.
on the new suspention mounts you can still alter the width and toe with shims, just the height is fixed, personally I will never move that, its in the correct place.
The upper camber links are as adjustable as before just in a different way, there will be various brackets to alter the width in half mm steps and you adjust the height with shims. the kit ones I will use 99% of the time..
I read that I was breaking lots of arms, that was Mi2 arms, I broke 4 I think But that was why Schumacher made the Mi3 arms! They dont break, Or at least I have not broken any.. The reason I was running Mi2 arms before someone asks is the Mi3 is a little heavy so I used them as they are lighter, but as the Mi4 is lighter there is now no need..
Driveshafts I have bent one bone since joining the team..
The top deck angle is a secret, but It seems to work! Today I did my fastest run ever on my local track, first time on it with the Mi4. Personally I am very happy with the car!
Chris
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-06-2009, 01:14 PM   #112
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Nick Priest View Post
All this talk of theory is bollocks.
It has been tested by Lee Woodhams and Chris Grainer and neither have had any problems with the motor rotating.
Same with the Schumacher Cat.
Theory my arse!
End of discussion.
Ding-Ding-Ding-Ding-Ding!!!! We have a winner!!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-06-2009, 01:55 PM   #113
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Thing sounds dialed!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-06-2009, 06:24 PM   #114
Ding-Ding-Ding.... Jaybee is back!
Hey Jaybee if you pick one up and come out and race, I'll pick one up too... But if you don't, I think I will any way.
Kody is offline   Reply With Quote
Old 04-06-2009, 09:17 PM   #115
Hi, can we get some pictures with the electronics installed? Thanks.
Electro-MAX RC is offline   Reply With Quote
Old 04-07-2009, 12:41 PM   #116
Korey Harbke's Avatar
I feel like I've just seen an endangered animal walk past me... haha
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-07-2009, 01:19 PM   #117
PutAwayWet's Avatar
The Coelacanth!
What once was lost is now found!
Is this a JayBee sighting?
Say it's so.
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 04-07-2009, 01:35 PM   #118
abailey21's Avatar
Trader Rating: 36 (100%+)
He even took the time in his personal recluse to call me
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-08-2009, 12:59 AM   #119
CA
The angle is intentional to allow better articulation of the track rod arms.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 04-10-2009, 06:23 AM   #120
steveonamission's Avatar
Cant Wait!
steveonamission is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
