Old 10-22-2009, 01:15 AM   #886
You also Need TIR Driveshafts
MChandler is offline   Reply With Quote
Old 10-22-2009, 05:48 AM   #887
steveonamission's Avatar
Seems like people are snapping them indoors, so if you wanna break down, then you NEED them.
And these are very good drivers, guys that make Carpet Wars A finals etc.
Id stay away, seems like TIR driveshafts dont cut the mustard still, there spools better though.
As i posted on the Schumacher UK forum, Tamiya 46mm drivehshafts are the best option for indoors.
steveonamission is offline   Reply With Quote
Old 10-22-2009, 08:54 AM   #888
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Are those tamiya driveshafts steel? And do they use a diff
blade?
I want steel cvd's up front but haven't found any so far.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-22-2009, 09:00 AM   #889
M-Technic's Avatar
Trader Rating: 15 (100%+)
Tamiya makes both steel and blue aluminum driveshafts and you can use blades on either of them (not sure if the Schumacher blades will fit, but Tamiya makes blades).
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-22-2009, 09:42 AM   #890
blade?
Yeah the Tamiya 46mm "steel" complete set with axle etc, you have to run the TIR spool with them, so no blade needed, just slots into the outdrive. Obviously you have to run tamiya hexes too.
Old 10-22-2009, 11:00 AM   #891
Hmmm. I gotta look into that!
I hate diff blades! Has. Especially with a spool, they wear to fast
Old 10-26-2009, 09:23 AM   #892
turbodog's Avatar
Florida State Series Race #2 race report- http://fseara.com/test2009-2010Results/ Superior SS13.5 A-main
Saturday we had the club race/practice. My Mi4 was really fast but was having some issues with the car just snapping loose in a few corners. it wasn't consistantly doing it was the bad part, it made for an evil car to drive. i took off the c/f arms front and rear and went to the medium arms and that helped the car alot but it still wasn't where I wanted the car to be heading into qualifying on Sunday. Sunday I made a couple of changes -shock position/moving the weights and qualified 2nd after the first round. This season we only get 1 set of tires so I opted to sit out the rest of qualifying to save my tires for the main. Well....the Xenon28 tires just didn't drop off enough for my strategy as I dropped to 8th on the grid and that just made to much ground to make up in the main. I had a really good run in the main and some luck as well as I made it back to a podium run, finishing third. Could've been a hero if my strategy worked but happy with my car as it worked great on raceday.
Troy Schafer
turbodog is offline   Reply With Quote
Old 10-26-2009, 03:04 PM   #893
dbmartin's Avatar
here is the direct link to the results.
http://www.fseara.com/raceresults/20...ck_A-Main.html
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 10-26-2009, 04:58 PM   #894
MikeXray's Avatar
Trader Rating: 73 (100%+)
Are you running a locator on your lipo with the tape? is there a lipo brace for the 4 or 3.5? Car needs to loose 50g..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-26-2009, 06:51 PM   #895
Nope. I just have lead weight down the center of the chassis shoe goo'd in there so the lipo cant move in to hit the spur/pinion. And weight to get it to min weight
Im sure you could make any lipo brace/holder work. But I dont think its needed...
Old 10-27-2009, 06:31 AM   #896
turbodog's Avatar
You the man Dave.
Troy Schafer
Old 10-28-2009, 02:37 PM   #897
BrodieMan's Avatar
Default On-Road Newb
Looking to start racing TC's for the first time and am going to get a Schumacher for sure, might be a bit overly agressive with my XXX4 to warrant a new Cat SX too If I get a used Mi3.5 it can be upgraded into an Mi4 I understand, is that right? Any suggestions for foam tires on a less than perfect tarmac. Not the warmest climate here in B.C. so thinking foams would be better on cold pavement than rubber tires.
Cheers
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 10-28-2009, 03:47 PM   #898
Cheers
Upgraded as in buy a complete new MI4 kit.
There two completely different cars, no such upgrade.
Cant help on foams, rubber uk guy
Old 10-28-2009, 05:28 PM   #899
BrodieMan's Avatar
or was it the Mi3 into Mi3.5?? never stupid questions right I have all winter to get a TC so maybe better to shell out on a new Mi4 as parts for the Mi3.5 might get hard to find when it eventually gets discontinued. Never need much of an excuse to get a brand new car huh
Mark Richardson
Old 10-28-2009, 05:51 PM   #900
Yeah more like MI3 to MI3.5, that is possible.
If your money isnt the worry, then MI4 all the way, its a much improved car over the mi3/.5
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
