Old 10-17-2009, 08:28 PM   #856
The Bear's Avatar
Originally Posted by Kenny L View Post
Great outing with the Mi4 today here is my setup from the weekend great for 13.5 foam.
Got a 1st hand ass whipping by this setup, ya'll gonna want to try this.
I'd post my setup, but this one is way better. I'll have some pics of my latest paint atrosity soon.......
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 10-18-2009, 10:03 AM   #857
I'd like to thank all of you who recommended the Mi 3.5 Racer for my budget racer. I haven't switched it to foam yet.
Yesterday I managed to put the car in the A main in rubber tire at the 5th Annual Halloween Howler at RC excitement.
I didn't even plan on racing the brand new car with no track time. I ran a few practice laps before sign up where I had planned in running 1/12 scale. By my second practice run I knew I had to race it and I put the 1/12 away.
Unfortunatly, at the start of the A main, I ran right into the middle of the first turn pile up and stripped my servo horn. I managed to continue for a while, but it wasn't pretty.
The best setup I found was close to stock except for green front springs (18 LB) 2.6 degree rear toe, 50 wt AE front shock oil and Losi #56 rear shock pistons with Losi 30wt oil. I ran Sorex 28 tires most of the day.
(Blue front springs gave the fastest lap of the day, Greens gave much better 10 and 20 lap averages even though it felt like the car pushed slightly)
If any mid level rubber tire guys are looking for a car, this is a great one. It's a lot of car for $300.
The only problems were that it's impossible to set the ride height with the kit shims alone. You need the 2 thin sizes of shims from the Associated shock accessory kit ($5) The shims needed are .050" and .075" thick. The other thing is you must unscrew the shock ball cups 2 turns to get proper droop settings using the stock shock mounting positions.
The Mi3.5 racer weighs exactly 1400g with a Tekin RS, HS 625MG servo, Airtronics DSS receiver, 17.5 motor and TP 5400 sport pack Lipo and is perfectly balanced .
I HIGHLY recommend using the servo saver.
Eddie_E is offline   Reply With Quote
Old 10-18-2009, 10:37 AM   #858
The Bear's Avatar
Good driving Eddie, you've come a long long way.
1st night with my Mi4 rubber on carpet. Very little practice time, but the car performs very very well.
Old 10-19-2009, 05:28 PM   #859
skypilot's Avatar
Trader Rating: 14 (100%+)
Another update the prototype camber plates are in the country wont be long before you see them with Schumacher part #
anywhere to see a picture of the part
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 10-19-2009, 06:17 PM   #860
1/-1
Before we even got our cars we had these in mind. They go based off the same convention Schumacher uses with the 1/2/3 groove camber link mounts. So 0 is 3mm longer center to center than a 1gr. And so on. Main goal was to be able to run shorter camber links.
We have been running 0 front and -2 rear links with Foam sedan with great success. Haven't gotten rubber cars yet, but the plan is to start with 1 front/-1 rear. We haven't had to make any wholesale changes to our original planned setup. Just fine tuning it in. Hopefully the same goes for rubber when the time comes.
JoelV is offline   Reply With Quote
Old 10-19-2009, 06:22 PM   #861
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by JoelV View Post
0/-2
1/-1
you can also use the old MI2 shock towers , cut the shock mouting holes off then use the rest of the shock tower ( the camber link holes) to mount the camber link. The BMI MI2 Shock tower gives you alot of mounting options.
Old 10-19-2009, 06:31 PM   #862
skypilot's Avatar
thanks, but just so my slow mind will understand,
standard shouie is 3g 39mm, 2g 42mm, 1g 45mm, so your 0 is 48mm?
Old 10-19-2009, 06:38 PM   #863
Kenny L's Avatar
Trader Rating: 16 (100%+)
You got it
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 10-19-2009, 06:42 PM   #864
skypilot's Avatar
thanks, looks like our asphalt racing is finally over, so need to make changes for the carpet, guess i better get them all
Old 10-20-2009, 09:32 AM   #865
M-Technic's Avatar
Trader Rating: 15 (100%+)
Got a few questions for the MI4 drivers out there:
1) Are the front driveshafts supplied with the kit steel or aluminum?
2) How well do the blades hold up in the front spool?
3) Does the kit include extra camber link mounts for adjusting the link length, or are those optional parts?
4) I love the flipped layshaft from the standpoint that it takes little to no weight to balance left-right. However, with all the weight of the car further inboard how much is handling affected? There must be a noticeable change since there is less moment of inertia.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-20-2009, 09:44 AM   #866
steveonamission's Avatar
1) Aluminium
2) They hold up ok-ish, depends what class you do, in mod they wear quite fast...(with TIR spool you dont need blades, but the standard driveshafts dont work with it, you need the TIR drievshafts or a drievshaft with a 2mm pin. Tamiya 46mm steel ones fit.
3)No, there optional 3groove are kit.
4) The team guys over here, i havent seen flip them, i havent either, honestly i dont think theres a HUGE advantage, but each to there own, if your car is balanced left to right, then its all good.
Steven
steveonamission is offline   Reply With Quote
Old 10-20-2009, 09:48 AM   #867
M-Technic's Avatar
Thanks for the info. I suppose to convert to the Tamiya driveshafts you need to change the axles and universal joints as well.
Do you mean to say that the kit camber plates have 3 holes for each side to adjust the link length?
Old 10-20-2009, 09:52 AM   #868
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
yeah, i think it's more a clearance issue, giving more room for electronics when the belt is on the battery side. i may keep the spur close to the motor, but just flop the belts like some guys did on the mi3. but yeah, it's not a tough car to balance, which leaves some of that other ballast for tuning.
technic - when the motor goes inboard, the battery has to move out some. i won't say the moment is unchanged, but i doubt it's real detectable unless things were real goofy to start with.
the camber plates are optional. the 3-gr comes with the car, which makes for the the longest link. there are (as of this moment) two optional plates that shorten the link by 1.5mm increments (per side).
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-20-2009, 09:56 AM   #869
Yeah the complete driveshaft, axle/bone etc....also the you will have to use tamiya wheel hexes too, as the the schumacher pins/hex hole are not the correct size for the tamiya driveshaft axle.
No, the option links each have one hole , as said above
Standard is 3 groove 39mm
Official options are currently 2g 42mm , 1g 45mm
Old 10-20-2009, 10:02 AM   #870
MikeXray's Avatar
Trader Rating: 73 (100%+)
0/-2
1/-1
You may want some more meat between the 2 holes, the force applied to that is going to be severe.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
