Old 10-05-2009, 07:23 PM   #766
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Originally Posted by BlackedOutREVO View Post
About time
Yea for real
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 10-05-2009, 08:00 PM   #767
jhock's Avatar
What is everyone running motor and gearing? also, anyone really tried without swaybars? I was tinkering with them and found that taking them off the car rolls to much and has too much grip.
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 10-05-2009, 08:05 PM   #768
Brandon (Blacked out) said he took the sways off and it was pretty bad roll wise. I ran sways only up front on the Xray, they were not that bad. But to each his own
Old 10-05-2009, 08:39 PM   #769
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Yeah I liked mine on better. I tried a thinner bar in the rear and went back to the kit sway bars. Car had way to much traction with out the sway bars.
As far as motor and gearing. depends on the ESC. SPX and a duo or a ballistic I run 5.8
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-05-2009, 08:40 PM   #770
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Leave the sway bars on the car is alot better. Do you run asphalt? I posted a set up a few pages back its very easy to drive with tons of steering.
Is posted here
http://www.racing-cars.com/usa/searc...e1=prodvalue14
Old 10-05-2009, 08:56 PM   #771
rezenclowd3's Avatar
Send a message via AIM to rezenclowd3
Marcos,
looking at the setup you just posted (as I will use it to start with this weekend) I noticed your screw block spacers on the rear arm seem odd. Is 2mm front and .5 rear correct? That would be positive toe and a backward sweep of the rear arms correct?
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 10-05-2009, 08:59 PM   #772
bukil's Avatar
Trader Rating: 37 (100%+)
Originally Posted by rezenclowd3 View Post
Marcos,
Were you running your MI4 last club race?
bukil is offline   Reply With Quote
Old 10-05-2009, 09:04 PM   #773
Marcos,
the pivot blocks have toe molded into them. Running a 2mm shim in the front of the back of the car, and then .5 at the very rear gives very little toe. I run a 1mm shim at the very back and 2 in the front, Which I think is 1.5 or 2 deg of rear toe
Old 10-05-2009, 11:42 PM   #774
Mark, ran the TC5 last race. Its now stripped of electronics It sure looked like it could have been my maiden run with the Mi4 though.....that was NOT expert class driving.... :-( :-(
Interesting. I hadn't thrown my Mi4 on the setup station yet hence why I didn't know that. I thought it looks like I have a TON of toe-in currently ( put 2mm in rear and 1mm in front) Have changed off the bat to the short med flex arms as well to start...gotta check that the width is "correct"
BTW BOR, I know you asked Vernog about some Mi4 lipo weight plates. I cut the rear batttery location out to fit the PPD bottom plate. Fits like a charm now. HOWEVER, with my Reedy 5A and weight plate, I gotta dremel the right front bulkhead just a tad as its scratching right now :-( No biggie though
Old 10-06-2009, 07:43 AM   #775
The Bear's Avatar
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 10-06-2009, 07:55 AM   #776
The stock rear blocks add 2.5* of toe in if they are shimmed equally front to back. For each .5mm shim you add .6*.
JoelV is offline   Reply With Quote
Old 10-06-2009, 09:35 AM   #777
yeah with the short arms just add a 1mm shim all around. As for the toe, haha I did the same thing in the beginning. I threw it on the set up station and it had wayyyyy to much toe. Like said above me though 1mm shims don't quite add 1deg of toe. It's a little bit more, So keep that in mind
The lipo tray, I don't even need one. The car is perfectly balanced the way it is. It might be a little off, but it runs great! I know adding a ppd tray would put wayyyyyy to much weight on the lipo side with the motor flush to the chassis.
Old 10-06-2009, 10:28 AM   #778
skypilot's Avatar
Trader Rating: 14 (100%+)
you need to be careful with the molded blocks, as stated, they have built in toe, so with a 1mm spacer front and rear it has like 2.5 rear toe, when your adding or removing spacers your actually twisting or putting a bind on the molded blocks. make sure your hinge pins don't bind
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is online now   Reply With Quote
Old 10-06-2009, 10:38 AM   #779
Send a message via ICQ to MattW
About time
I was thinking about getting the spool and CVD's for the front. For now any anyhow lol. Is there any advantage to using them in the rear? Other then having matching CVD's
You have 2 options for the front CVD's, you can either use the standard style front shaft, or the new Stealth driveshaft.
The stealth in the rear gives the car more rear traction.
MattW is offline   Reply With Quote
Old 10-06-2009, 11:22 AM   #780
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by The Bear View Post
Adam you need add a clause for team members, no bodies that were painted by a chimp with a crayon
Casey, I can still give you the same price I did last time bro, I can give you drips now if you want them instead of flames, and they will be in the RIGHT direction
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
