Old 08-19-2009, 01:18 PM   #526
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by jdm19turn View Post
Yes the mi4 has a ton of grip and a lot of steering too excellent combo
I drove Hayne's Mi4 after the xray challenge and that's exactly how I'd describe his car, very easy to drive even for a hack like me.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-19-2009, 10:27 PM   #527
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by mjc168 View Post
Any comment to my current setup? Do i need to change medium flex wishbones for rear/front or both???
How bumpy is your track? 7mm is pretty high. I think Jdm runs 5.5 and 6 iirc. And his track is bumpy
Med flex all around will give you more traction overall. And if you run the stiff arms in the rear and med in the front you will have better rotation.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-20-2009, 04:38 AM   #528
Drifting101's Avatar
Originally Posted by BlackedOutREVO View Post
Oooo, what color are you getting done?
Im still debating on sending my car out to get it anoed black
I'm not sure, I want either black to be different or blue so I don't have to pay a fortune to get all the spacers done and I used to run Tamiya so EVERYTHING is blue from my power supply to to setup board and even my pit towel
Guys I want your opinion
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 08-20-2009, 04:47 AM   #529
abailey21's Avatar
Trader Rating: 36 (100%+)
Everyone knows I'm gonna say green
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-20-2009, 05:09 AM   #530
Had neon green once but it wasn't me
Schumacher
Old 08-20-2009, 07:20 AM   #531
mjc168's Avatar
Trader Rating: 25 (100%+)
Yeah front and rear what are you looking for more traction more steering or both. What is missing from your car that you won't better?
I am looking for more traction. my car look like can't stick to the floor. very hard to control.
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 08-20-2009, 07:34 AM   #532
abailey21's Avatar
My current setup on the rear of my MI4 is;
CF rear arms, with alloy rear hub carriers, no spacers between rear hub carrier and ball stud
Alloy toe blocks with 2mm spacers between the top and bottom blocks
Rear toe spacers are 2mm in the front and .5 in the rear
3Gr camber mount with 3mm spacers on the ball stud
white springs with 35wt, bottom shock hole outside, top is one hole in from the top
I do not run a rear swaybar!
K.C.C.O.
Old 08-20-2009, 10:21 AM   #533
jdm19turn's Avatar
Okay I would start with lowering your ride height to 5.5 to 6 mm in front and 6mm to 6.5 in the rear try to keep it as low as possible then lower your rollcenter front and rear start with a 2mm shim under rear block and 1mm under front hinge pin block
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 08-20-2009, 03:08 PM   #534
A blue MI4 would be pretty sick! Very different.
Nice avitar lol. Fox is hot!
Old 08-20-2009, 06:17 PM   #535
mjc168's Avatar
Thanks for the inputs. I will try out this weekend....
Old 08-21-2009, 08:36 PM   #536
SchuMi2's Avatar
Trader Rating: 34 (100%+)
The build so far...
SchuMi2 is offline   Reply With Quote
Old 08-21-2009, 09:35 PM   #537
Originally Posted by SchuMi2 View Post
The build so far...
Im not a fan of blue. But that car is SEXY!!!!!
Im getting mine blacked out in a few weeks. I will probably do the same thing as you, just purple parts instead of the blue bits. Maybe all black, dont know yet
Old 08-21-2009, 10:58 PM   #538
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Is there a prize for the first red mi4????
I guess I better get on the ball.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-22-2009, 01:26 AM   #539
Trader Rating: 16 (100%+)
The build so far...
Did you cut the slot larger on the outdrives? looks bigger.
BAMBAM cheapsk8 is offline   Reply With Quote
Old 08-22-2009, 01:33 AM   #540
SchuMi2's Avatar
All std...no mods on the outdrives.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
