Old 07-20-2009, 09:53 PM   #436
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by 4wheeldrift View Post
That's me. Mostly race at Marin and Nocal. I do go to SWR and Ripon a couple times a year.
Right on. I will be around there in a few weeks to have some fun! And YGPM
Originally Posted by Verndog View Post
I had a chance to look at the Mi4 on Sunday and checked the chassis slots. For some reason they decided to widen the narrow part of the chassis cutouts by .050 inches or 1.3mm. This is going to allow too much front to rear play for me to go ahead and just machine off the existing end lug on plates using existing stock. I will be willing to build some custom plates, however it will need to hold till the next scheduled run of plates. Bottom line it will be an estimated 60 days before I expect to make next run. Sorry I wasn't able to help sooner, but... new chassis, design changes and rippling effect in process.
Kevin--PPD
Yeah making the plate a 5 cell plate would be the easiest. I dont think the car needs that much weight anyhow to balance it with the motor pushed in. So it might work perfect!
Originally Posted by skypilot View Post
speaking of the Mi4, first time out with the car was good, but something went away in the main, big time. made a few adjustments including pulling the mod motor and swapping the spur gear back to kit position and installing a 13.5. decided to drop a 17.5 in the ole trusty Mi3. Very happy to report it was a very good weekend for both cars, TQ'd and won both classes. with the Mi4 i ran two heats with no changes to get a good feel for the car and make sure the new tires and new LTC-R body were doing there job. for the third heat i swapped the bottom chassis for the 2.0 option chassis and the car came alive, way more corner speed and rotation. car went and stayed where i wanted it to. I pushed it really deep into a few corners to see what would happen, other then running a little wide, the car stayed planted. I'm thrilled with the Mi4. Back to mod with the Mi4 and 13.5 with the Mi3
You liking the LTC? I got a speed 6 and a ltc painted up for my MI4 to mess with. Sounds like the ltc has more steering, which I looooooveeeeeee
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-21-2009, 02:05 PM   #437
Racer Z's Avatar
Kevin--PPD
Put me down for 1 Kevin!!
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 07-21-2009, 02:55 PM   #438
Verndog's Avatar
Trader Rating: 16 (100%+)
Rodger that.
Keep an eye on this thread, and I'll put a post or 2 in just before I make the first run. Ballpark 6 weeks or so.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 07-21-2009, 08:35 PM   #439
Cesar's Avatar
Default Adam's Car
Adam looking.....not sure what to say
While going fast is fun, racing is about just going faster than the other guy.
Don't let the lure of speed get you away from the close racing. -Mason
Cesar is offline   Reply With Quote
Old 07-21-2009, 08:47 PM   #440
Danny-b23's Avatar
Can you send me some of those decals?
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 07-24-2009, 12:07 PM   #441
Does the car come with med flex arms, or the stiff ones? The pic on schuie is colored over so you cant see
Old 07-24-2009, 02:22 PM   #442
turbodog's Avatar
The Mi4 comes with medium flex arms......
Adam gets the stiff one..........
Troy Schafer
turbodog is offline   Reply With Quote
Old 07-26-2009, 04:52 PM   #443
Racer Z's Avatar
Default MI4 TQ!!
Once again the MI4 does it! TQ but couldn't pull off the win due to a back marker hitting me when I was coming pass to lap him. I have a good medium bite asphalt set-up for any one that is interested!! The MI4 is an awesome car on the asphalt!! I haven't been able to test it on the rug yet but I hope to get some practice soon! Thanks again Schumacher
Old 07-26-2009, 06:39 PM   #444
DaveW's Avatar
Indoor asphalt son!
Mel that Schuie looks great... lemme drive it when you get a front diff!
DaveW is offline   Reply With Quote
Old 07-26-2009, 07:00 PM   #445
Cool! thanks
and
PM sent. Im up for trying stuff.
Originally Posted by DaveW View Post
Indoor asphalt son!
Indoor asphalt would be soooo awesome!
Old 07-26-2009, 07:34 PM   #446
Racer Z's Avatar
PM replied!!
Old 07-27-2009, 03:48 AM   #447
Shev's Avatar
How's everyone finding the balance with the mi4 regarding lipo on one side and electronics on the other. Are you adding weight to the lipo side? Knowing that weight limits are 1425g, are you keeping to the low weight, or adding more weight to keep the car balanced.
Shev
Fraser Coast RC Car Club/FCRCCC
XRay T4... F104X1... M11X... SMC... FANTOM...
"fast.... but rough!"
http://www.actionrc.com.au
Shev is offline   Reply With Quote
Old 07-27-2009, 06:11 AM   #448
deviltires's Avatar
nice run melvin your car was on rail to bad you were a lap up on the field and got taken out but looking at your car im sold i will have my schumacher mi4 next month once again good run
DARNELL WASHINGTON-- TEAM MUGEN----FUTABA 4PK--HOT RACE TIRES
deviltires is offline   Reply With Quote
Old 07-27-2009, 06:13 AM   #449
Racer Z's Avatar
Shev
I am running 70 grams along side of the battery. I used two balancing pins in the center of the chassis and it seems to be really close. I am going to buy 4 minature scales in the near future to see how close everything is!! I also pushed the motor as far to the inside as I can get it without the motor touching the spur. Also make sure the rotor shaft doesn't touch the lipo case. I am running the lipo as close to the center line as possible. I noticed a big difference when you slide the battery to the outside edge. Car likes to snap with all of the weight hanging out there like that!!
Old 07-27-2009, 06:16 AM   #450
Racer Z's Avatar
Yeah time for you to step up son!! Time to become a man and get the MI4 Man Up!!
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
