Old 11-01-2012, 09:53 AM   #3676
poochy's Avatar
does anybody know what the replacement "Spec-R Swing Shaft Version 2" (tamiya, xray, yokomo etc...) will fit the Schumacher Spec R "Driveshaft Front True CV"....i bent the shaft that comes with the Schumacher SpecR "Driveshaft Front True CV"and so far unable to find a replacement
poochy is offline   Reply With Quote
Old 11-01-2012, 10:43 AM   #3677
spu83's Avatar
If you are talking about http://www.racing-cars.com/pp/New_Ca...4CXL/G884.html G884 Mark from Schumacher said there is no replacement parts for it. I bend 1 too and they are very soft metal compare to the stock one.
Pak Lee
XB8E, XB4'15, 410.3, T4'16, XB2de, X1'16, XT2de
spu83 is offline   Reply With Quote
Old 11-01-2012, 11:00 AM   #3678
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
I prefer the stock ones no issues ,
Old 11-01-2012, 11:05 AM   #3679
Run the tamiya servo saver if you're running indoors and you'll not bend a shaft again, well I haven't anyway lol.
Just installed the double joint shafts in mine. Few team setups and pictures I've seen recently have featured these shafts more.
Mi4cxl is offline   Reply With Quote
Old 11-01-2012, 11:10 AM   #3680
Super Moderator
Marcos.J's Avatar
Just don't crash and you won't bent anything lol
Old 11-01-2012, 11:24 AM   #3681
Harder said than done when I do the tracks and let out my full love for 90 bends and chicanes everywhere lol...
Old 11-01-2012, 11:47 AM   #3682
poochy's Avatar
Stock ones no issues for me too.awesome durability.the trues r super smooth, smooth frnt feel..im hoping the version 2 shafts r stronger...
Old 11-01-2012, 12:21 PM   #3683
I really like the true cv dcjs. They handle like a front gear diff, and keep the rip of the spool.
-Mike
Old 11-07-2012, 11:10 PM   #3684
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
What's better for a medium carpet tight, course. The extra flex or medium flex castor blocks?
Blitzrockey is offline   Reply With Quote
Old 11-08-2012, 04:40 AM   #3685
Danny-b23's Avatar
For anything on carpet you're generally going to want medium or stiffer. The XF's just flex way too much when grip is even marginally high.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 11-08-2012, 07:55 AM   #3686
Thanks. I kinda figured that I ran one race with them and they tended to grab pretty hard near the end of the corrner. I could probably carry more corrner speed with the medium ones also?
Old 11-08-2012, 10:52 AM   #3687
Danny-b23's Avatar
Most likely. If grip really starts to come up or you go to a high grip track you might even want to go with stiff hubs and arms. It will just make the car more consistent and less "springy".
Danny Buck
Old 11-08-2012, 12:16 PM   #3688
Our track is about a medium grip track. So Im thinking like you said to stick with the medium ones for now. see how those work.
Old 11-10-2012, 10:26 PM   #3689
Default Mi4cxl
Hi
Just got a 2 hand mi4cxl , completly stock. What do i need to get ?. Have been looking trough this tread , but cant find a "need to get" list. I will be running on carpet , 17,5 blinky on sorex 28 on a tight track
Its the stock chassis and top plate , Do I need the 2mm soft weave chassis and the carpet top plate ?
Right now i have ball diff and spool , gear diff is the way ?
2 arm steering or just make the "martin hofer" change on the stock one?
The new chassis arm holder from the worlds , looks like all use them
And finally the alu arm holder , nearly all pictures use the stock one.
Looking forward to again race the schumacher car , has been away since 1994 when I drove the Cougar and bosscat in offroad
Thanks for your time
Best regards
Andy
HB-forever is offline   Reply With Quote
Old 11-10-2012, 10:37 PM   #3690
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Originally Posted by HB-forever View Post
Hi
Hi
The CXL comes with the 2mm softweave but I prefer to use the standard top deck but there are times when I use the flex or carpet.
The car is pretty much decked out but nice to have a set of narrow hexes.
Only a few parts for spares (not many needed the car is a tank)
Make sure to have extra:
inner hinge pins especially if using the aluminum blocks.
Shock rebuilds kit and a few spur gears (only Schuie can be used)
Diff/spool inserts (they wear down often)
And few of the normal stuff.
Cut yourself a heavy duty bumper.
And keep a lot of shims 1,2,2.5 mm for setting up
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
