Old 05-07-2012, 04:46 PM   #3526
Originally Posted by skypilot View Post
I'll be doing the club race, more then likely it will be the first race on the new car
COOL! if olhipster shows up we will get you dialed in very quickly...hey hipster, have you reserved a room yet?
gdcopbdcop is offline   Reply With Quote
Old 05-07-2012, 05:26 PM   #3527
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
haven't reserved a room...not sure if I can go.
plus the darn plane tickets keep changing in price.
3 weeks ago...550....two days 332...today 460....WTF...
sucks...
i should have bought it two days ago...
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 05-07-2012, 10:19 PM   #3528
olhipster1's Avatar
Default oh..yeahh..Reedy here I come
screw em' just quit.,,
hope to see a good turn out of Schuies this year, its been pretty slim in years past
Confirmed one more Schuie...will be at Reedy...
will call in my Race entry...and bam..i'm in.
CAUSE and EFFECT
Old 05-08-2012, 08:11 AM   #3529
great news! when you get to the track, look for us...we will be wearing our schumacher blue shirts!
Old 05-08-2012, 08:28 AM   #3530
olhipster1's Avatar
sent over an email to Mark to see if I can get a shirt or two....
will be good to share info...
if you guys have any questions...feel free to ask...
i'll do my best to help out.
Not sure how traction will be out there...so will probably take two cars...one setup for high grip and other setup for med to low grip.
CAUSE and EFFECT
Old 05-08-2012, 10:14 AM   #3531
skypilot's Avatar
Trader Rating: 14 (100%+)
Grip is good, see you there.
Rich, no box yet,
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-08-2012, 11:27 AM   #3532
What's going on....
The kit is very easy to build.
YouTube "Mi4 or Mi3" there should be a few videos on how to build diffs and shocks...
diffs
- will say the hardest part is putting on the fence (outside part to hold belt in).
The trick is to take an exacto knife and scrape the inner edge off the fence..then it just snaps into place.
(do the same for the pulley fence)...same process in the MI3 thru Mi4CXL
-don't forget to follow the instruction when building the diff...the lock grub screw is super important.
shocks
-they go together very easy. just choose the correct o-ring. Red or blue are fine. the clear is going to leak.
butter smooth.
bearings
-i just oiled mine right from the box (no cleaning). still on my original set.
spool
Use the black plastic outdrives in the front and Grey soft in the rear. Greys are softer and when used in the front it bind the bones eventually.
No modifications needed to make the car work..just find the right setup for your driving style.
the rest is very easy...same as building others.
*Suggest* get a few extra spur gears...other brand spur gear do not fit the car.
layout electronics with the motor in the most forward position...this will give you the largest window for spur and pinion combination. There is a lot of room, double what most other brands have.
A few pages back I uploaded a setup (for CLX but on CX sheet) I've been using and there a number of others on the Schumacher website.
I should have reviewed this when building the kit last night.
I'll have to redo the fences on the diff. it seems that they aren't straight and there is very little space for the belt (almost exact size).
My shocks only came with the clear o-ring. Is it okay to run as-is or should I replace them now?
How important is the bearing oiling? They felt nice and smooth so I just put em right in. They did have an oily coating on them.
Also is there a strength difference between the 64pitch and 48 pitch gears? I figure the 48 would be stronger since there is more tooth to grab. I will be running in the mod class with a 7.5 on a large outdoor track.
I drive a Schumacher
Skyrocket Racing Team Member
Double D Donuts is offline   Reply With Quote
Old 05-08-2012, 12:11 PM   #3533
olhipster1's Avatar
once they snap in it could be a bit difficult to take off...
You can run the clear..but change them if they do leak..very cheap...the Associated Red orings work..as well as a few other brands.
they do come oiled...or at it feels like it...but I just put a few drops just in case.
Easier to gear with 64 pitch...but 48 pitch is a bit more hardier and I feel the braking is a bit more effective with 48 pitch...but it's quite a bit louder with 48p.
either way is fine..comes down to personnel preference.
CAUSE and EFFECT
Old 05-08-2012, 01:02 PM   #3534
grip here is off the hook....when you walk on the track, your shoes will stick to it...
Old 05-10-2012, 07:14 PM   #3535
skypilot's Avatar
more then likely has been changed to most definitely.....
apparently theres some sort of HEE HAW marathon happening on Kentucky TV as my car has been sitting there since the 2nd. absolute non sense going on over there.
Old 05-10-2012, 09:55 PM   #3536
skypilot's Avatar
this is going to keep me from doing the reedy...
http://www.cbp.gov/linkhandler/cgov/...llbearings.pdf
Old 05-10-2012, 11:56 PM   #3537
olhipster1's Avatar
Not sure what the pdf is for...
What section or paragraph says/states I can't check in a car?
Don't have time to check all those pages.
CAUSE and EFFECT
Old 05-11-2012, 11:55 AM   #3538
skypilot's Avatar
It was suppose to be a link to home land security form for bearing compliance. Yes a form for ceramic bearing I ordered. The whole shipment is being held,
Old 05-11-2012, 08:16 PM   #3539
olhipster1's Avatar
Ohh..okay
The kit bearings are pretty darn good....
Ceramics placed in-line would be nice to have...
On the outer parts not such a good idea.
See u guys at the Reedy race.
Good luck to all.
CAUSE and EFFECT
Old 05-11-2012, 08:34 PM   #3540
skypilot's Avatar
I've had every car since the Mi3, I've always used the ceramics thoughout except for the outter front wheels, there is a difference.
see you at Reedy, I'll try and remember to bring a banner for you guys to sit under/by. I'll be doing pit b duty.
and in case theres any confusion,
Mark and Schmacher have been top notch in all of this doing their best to get my shipment freed up. the issue has been with UPS/customs.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
