Old 05-03-2012, 08:31 AM   #3511
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Originally Posted by bdortch View Post
Are you guys using aluminum spacers on the outer hinge pins? I would like to use aluminum spacers but don't know what size fits the pins???
i believe aluminum spaces for any hinge pins need an internal diameter of 3mm...
the outer hinge is the same diameter as the inner pins.
I am currently building my second car...I put in alum shims in the rear (usually use the plastic clips provided in the kit).
this will be a testing car trying to build new setups for different weather and tracks.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 05-03-2012, 08:57 AM   #3512
Chaz955i's Avatar
Originally Posted by olhipster1 View Post
i will be honest...not being rude..
but if you read thru the posts 90% percent of your answers are there.
part of this hobby/sport is getting your "On-hands" time and seeing what works and doesn't.
after you get an answer, you ask the same thing several times..
a bit OCD, perhaps!!!!
if you go with a different brand you won't get the same response you received on this thread...go ahead and try...
Every car is different. Without buying it and trying it, You will not know, it's as simple as that.
as I stated before...Good Luck.
we tried to help you.
Don't feel bad. He does this everywhere. Asks a laundry list of questions, many of which could be easily answered by taking a minute to look at a manual or throw some parts on a scale, or heaven forbid actually make the change and test it on the track. Guess someone else is supposed to do all the work for him.
BTW.. the new Schumacher looks good. A bunch of people were running them at my track a couple years back. Hopefully we can get someone running them again. Nice to see some variety.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 05-03-2012, 11:48 AM   #3513
the car is not just good, its great.....olhipster said it best, and i agree...if you dont like the answers you recieved, go find something else...
gdcopbdcop is offline   Reply With Quote
Old 05-03-2012, 12:49 PM   #3514
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Kensei View Post
As to why using this LiPo:
to put it simple: more mAh leads to more power and more running time. A higher C rating leads to more power.
However, even more important than these factors is the temperature of the battery. The warmer it is, the lower the resistance will be and the more power it will give.
If maximum performance is ones aim, than one would want the highest C rating AND the highest capacity in mAh AND one wants the battery warm, but not hot.
I am a big fan of prewarmed LiPo's, but sadly rules don't allow that.
Look for battery info too.
Higher mAh leads to more run time. Higher C is only a factor when drawing max current, you do that once in a race, the start for about 2 seconds. A couple laps later, that fresh charge edge goes away. Warm batteries do not provide any more current, but keep the peak voltage output up. Current draw is limited by the ESC. Most ESCs can not draw the current a high C battery can provide, if they do, they fry. Internal resistance is a factor in proper balancing and in effect output. The IR of each cell should match. Warming batteries for the sake of warming batteries is a waste of time. If you want warm batteries, use a lower C rating battery. As current draw approaches C the battery will warm on its own. This has been proven over and over.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 05-07-2012, 04:30 AM   #3515
Does anyone know if the alloy pivot blocks from the mi3 and 3.5 are the same as the mi4. The number for a pair of pivot blocks is the same just wondered if there was any differences.
scytherat is offline   Reply With Quote
Old 05-07-2012, 07:34 AM   #3516
lochness42's Avatar
They are exactly the same. Many parts from Mi3 fits Mi4 series
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 05-07-2012, 07:59 AM   #3517
poochy's Avatar
Default help, need spool spindle for mi4cx
hello mi4 drivers, i badly need an mi4cx/cxl "spool spindle (u3826)" --> http://www.racing-cars.com/pp/New_Ca...CXL/U3826.html
please pm me if you have one, need it for saturday's race
i cannot find it anywhere in the USA
thanks
poochy is offline   Reply With Quote
Old 05-07-2012, 08:48 AM   #3518
skypilot's Avatar
Trader Rating: 14 (100%+)
Whos going to the Reedy Race?
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-07-2012, 08:53 AM   #3519
olhipster1's Avatar
i want to go so bad...
I am trying to schedule the days off...
don't think there is anyone else who is running Schui? if there is post up.
CAUSE and EFFECT
Old 05-07-2012, 08:55 AM   #3520
olhipster1's Avatar
thanks
i will look in my pit box but it's a long shot....
Schu UK has it in stock.
.but you can order a Diff gear and use hard putty ...and will feel very close to a spool.
or buy the internal lock for the Diff gear.
CAUSE and EFFECT
Old 05-07-2012, 10:29 AM   #3521
skypilot's Avatar
screw em' just quit.,,
hope to see a good turn out of Schuies this year, its been pretty slim in years past
Old 05-07-2012, 10:46 AM   #3522
Anyone got a good low grip tarmac setup for the CXL ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 05-07-2012, 10:50 AM   #3523
olhipster1's Avatar
Default setup
Edit...
post number 3453
try this setup...i have been having very good results.with this setup.
change the droop and it should work with low grip.
CAUSE and EFFECT
Old 05-07-2012, 02:18 PM   #3524
RACER-X and I are going...cant wait...i will be going down for the last club race just prior to the REEDY also,,,,who else will be there?
Old 05-07-2012, 04:41 PM   #3525
skypilot's Avatar
I'll be doing the club race, more then likely it will be the first race on the new car
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
