Old 02-07-2012, 01:45 PM   #3331
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
Default Glue
Shoo Goo...
works like a charm on the lipo tabs..
let it sit overnight...
if there is ever a need to remove it..then just take an exacto knife or small driver and prop off.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-09-2012, 05:14 AM   #3332
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Schumacher Mi4CXL built and reviewed: at Action R/C here
And video from the first run with the car by Chris Sturdy in Australia: at Action R/C here
We're very happy with what we're finding so far.
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 02-09-2012, 08:02 AM   #3333
poochy's Avatar
Originally Posted by olhipster1 View Post
Shoo Goo...
i tried shoo goo-works best so far but it has failed a few times..though i still use shoo goo....theres gotta be something that works better...?
btw does anybody want to get rid of the old stock CX chassis?
poochy is offline   Reply With Quote
Old 02-09-2012, 08:33 AM   #3334
Talking
Nice !
But haha kind of funny you say
"What it does mean is that a new Schumacher customer gets the best package of chassis and updates all in one go (and for much less than buying the CX and each of the optional parts). From our perspective its a win-win situation. We d much rather Schumacher release an up-to-date kit every 12-18 months bundling the best of the improvements, than have to tell customers they need to buy a kit and a shopping list of optional extras."
And just a little bit further down you show us a list with optionparts you are using when building the kit
MarcusEngdahl is offline   Reply With Quote
Old 02-09-2012, 09:54 AM   #3335
olhipster1's Avatar
Default sand paper
did you sand the area where the sho goo is getting placed?
i have sho goo'd servos to chassis and never had them come out.
on CX i haven't even used the lipo tabs..I tape the battery in...never had it come out or shift out of place.
CAUSE and EFFECT
Old 02-09-2012, 10:03 AM   #3336
olhipster1's Avatar
i think a little further down (1 paragragh) he stated:
"Partly we used these options because we had them floating around, and partly because we’re particularly building the car for modified. In spec class racing we wouldn’t change diff balls, belt or centre body post. There are optional grey belts available that are specifically designed for the stock classes
Please keep in mind just about every Brand out there has the same type of option parts to add to there respective cars.
I've been using my CX with all the standard parts from the stock kit...it's been quite durable
the only thing I wanted to add so far was the Spec R gear diff.
Just got the CXL and looks like I won't have to do anything to the car.
Car has been good so far.
But I will admit I have a habit of adding options parts at some point to see performance effects.
o
CAUSE and EFFECT
Old 02-09-2012, 11:57 AM   #3337
poochy's Avatar
some may know but i dont knw anybody who got faster getting option parts...at least for the major sedans
those that practice and run competitive tires seem to make the leap
Old 02-09-2012, 12:39 PM   #3338
Default Aggressive bite mid-corner
Struggling with a really aggressive "bite" in the steering (mid corner).
Running on very high grip carpet, -1/-1,5 camber (front/rear), Schumi Yellow/blue springs, shocks laid down all the, 1,6/1,4 swaybars. 1,5 mm washer under the steering mount ball studs (using the new CXL steering mount). Any ideas, maybe decreasing camber (adding washer) so that inside tire will slip more?
JiiIii is offline   Reply With Quote
Old 02-09-2012, 12:45 PM   #3339
I got faster with HPI springs, and the gear diff also helped due to consistency.
-Mike
Old 02-09-2012, 12:57 PM   #3340
olhipster1's Avatar
on the CX....
the first day..the car would generate way too much grip..then ass out..mid turn.
ending up taking the sway bars off...i let the car roll more...
changed to HPI pinks in the front...Schui Whites in the rear.
Front shocks = 2nd hole from outside
rear shocks = middle or 2nd inner hold
shock oil = 42.5 f / 35 r
camber = 1.25 front / 2-2.25 rear (Solaris Med)
camber link plates...1mil shim under plate (not under ball).
front pivot blocks = standard
rear pivot blocks = alloy...slammed them all the way down.
rear arm shimmed = inner rear = 1mm / outer rear = 3mm...approx.
i found after a day of testing..
moving the arms rearward made a big difference. Car did not snap on entry or mid turn, felt very planted.
basically i took a day as a setup day..to play around with different stuff, to see where the car felt best.
Try everything you think...but 1 thing at a time.
too many changes at once and mayhem will occur.
ohh...don't forget to check dual rate...CX turns very aggressive...you have to dial out a lot of steering on the radio. I am 82% throw then dialed dual rate down to 61%.
CAUSE and EFFECT
Old 02-09-2012, 10:52 PM   #3341
Thanks for the tips. Are the HPI springs people using for example these:
http://www.amainhobbies.com/product_...ing-Set-Hard-6
Old 02-10-2012, 12:35 AM   #3342
olhipster1's Avatar
Default these type
i believe this is one of the HPI Racing springs colors.
http://www.amainhobbies.com/product_...15mm-6-Coils-2
they are black and the color is painted on the bottom.
don't know the part number for the full set...way cheaper than buying the colors individually...
CAUSE and EFFECT
Old 02-10-2012, 01:09 AM   #3343
You really only need gold, pink, blue, and 2 pairs silver. I think silver is 6542. The others are close. If you're searching for the full set, look for the pro4 set. The picture on some sites is outdated.
The spec-r springs are pretty cheap, too, but I haven't run them much yet.
-Mike
Old 02-10-2012, 02:22 AM   #3344
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
ive been test on mr33 ride moorespeed and i real like how car drive on them
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 02-10-2012, 02:58 AM   #3345
scoyle's Avatar
Are you using medium or flex hub carriers (steering yoke) - I find on tracks with lots of grip moving from flex to medium makes the car dive less and rolls through the corners.
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
