Old 02-03-2012, 11:05 AM   #3316
Originally Posted by MattW View Post
Not sure who posted about differences between LP and CX.
That was me, and I was wrong. I went back to see where I got that from, and it was a difference in setup that someone was referring to, not a difference in the actual bulkheads.
-Mike
Old 02-03-2012, 12:06 PM   #3317
Originally Posted by GSM Storm View Post
Well the car is ready for it's first hit out on the weekend.
Regards
Gary
What's that thing on top of the top deck?
-Mike
Originally Posted by olhipster1 View Post
i would imagine the CXL is lighter
since they reduced the amount of metal in the bulkheads as well as probably needing the optional alloy mounts..
my CX fully stocked came in at 1390
10 grams over...but i have a lot of wire on it. and no TI screws or alum installed yet.
let's cross our fingers and hope it's lighter.
The long top deck conversion on my LP added 13g. That was without trimming the bulkheads, though. The LP bulkheads are beefy and heavy, so it wouldn't surprise me if trimming them got that 13g back. The CX bulkheads are lighter, though. The CXL bulkheads look like trimmed CX bulkheads. So with the addition of the long top deck, I'd be surprised if the CXL is appreciably lighter than the CX. But anything is possible, I guess.
I never did find out how much lighter the CX is than the LP.
-Mike
Old 02-03-2012, 12:16 PM   #3318
Send a message via ICQ to MattW
I think as Grippa has suggested, the weight of the CXl and CX are likely to be similar. There is probably a few odd grams in it, but I'm not sure which way.
MattW is offline   Reply With Quote
Old 02-03-2012, 12:38 PM   #3319
GSM Storm's Avatar
Trader Rating: 112 (100%+)
-Mike
-Mike
Hi Mike
The thing on the top deck is the capacitor rack for the GM-120 speedy, the wires were too short to put it any were else.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 02-06-2012, 11:25 AM   #3320
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Default CXL
CXL
i have to say the CXL is quite a nice ride...
first impression..
flex left to right is very even..
the new chassis adds a few options...
primary the battery placement is a very nice option to have...forward about 2mm..
sway bar setup is very nice...i like very much...
keep in mind if you want to use the low mount sway bars, you still can...all holes are still there.
alum pulley it a very nice addition.
different turnbuckle links...looks quite stronger.
as mentioned before...the bulkheads have been lightened, cut off the top deck mounts where no longer needed...that should save on quite a bit of weight.
i do like the new rear shock tower, quite a bit more tuning options now.
should be able to take the edge off the car now. Will see next weekend.
the kit comes with two plastic outdrive option...grey and black...it think the greys are a softer material...blacks are harder. i wasn't aware this was coming in the kit. very nice.
the T6 sleeve is still there...and I for one am glad. very nice outdrive system. Easy on the pocket and quite durable.
The car is just freakin' gorgeous.
Good job Shumacher....let's see what it starts doing on the rubbers.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-06-2012, 02:20 PM   #3321
CXL
first impression..
Pics or it didn't happen!
-Mike
Old 02-06-2012, 02:27 PM   #3322
olhipster1's Avatar
-Mike
not sure what "it didn't happen!"?
maybe pics tomorrow...i'm working long hours for the few next days.
when i get a chance, i will take a few shots....not sure how I want to change the electronics around.
can someone tell me what lbs the light blue springs are? CXL came with LBlue front and White in the rears.
CAUSE and EFFECT
Old 02-06-2012, 03:30 PM   #3323
"Pics or it didn't happen" is common on some forums as a way of saying "post some pics". There's also TTIWWOP (this thread is worthless without pics). Apparently not so common on this forum, though.
Light blue are supposed to be 16lb, and white are supposed to be 14lb. I've been told Schui springs run stiff, though, and comparing whites vs. HPI Pinks I'd believe that. Also, make sure the lengths are even, as I haven't had good luck with consistent spring lengths on the Schui springs.
-Mike
Old 02-06-2012, 08:52 PM   #3324
olhipster1's Avatar
Default a few pics
I didn't think of measuring the springs....but actually usually drop in HPI spring on most cars. Best price for a full set.
i didn't notice before the new soft weave chassis has cutout under the pulleys....
the chassis feels stiffer overall than the CX.
Note: a Servo saver will probably a must now...look at the amount of metal holding the steering assembly. very nice..and light..
quick question...is the Schui servo saver worth assembling? or just go with another....i can't put this thing together to save my life.
CAUSE and EFFECT
Old 02-07-2012, 06:20 AM   #3325
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
sorry for not posting for so long. Busy writing exams. Luckily it's my very last one in about an hour.
Bachelor of engineering afterwards whoop whoop :-)
The bulkhead, threads are .5mm lower, plastic mounts are the same
Regards
Gary
correct
Originally Posted by mesa80 View Post
so on the cxl how are you supsto change arm angels ??? you cant without the blocks correct so i assume they still have their benifits or is running dive or squat not benifical enought to even consider blocks
you don't. If you have a look at my setup sheets, I have and still do, always run the pivot pins in exactly the same hight. And that's the kit-height now on CXL. dropping or raising them is pretty much pointless unless your track is very different to regular conditions.
I used to run anti-dive in the front but with tires constantly changing I think it's ok to run the front wishbones level now.
Originally Posted by Drwonder View Post
Hi Martin
Is it any particular reason wy the swaybars on your car differ from that of the original on Schumacher site, regarding attachment and ballends ?
painted black. I have used the HPI swaybar linkages on the CX already. It makes setting the sway bar much easier as during racing it will always bend slightly out of shape and not be entirely level. with the vertical ball stud it's very easy to correct the link-lengthes so the sway bar effect is the same left and right.
Please don't misjudge that! a sway bar is only good when it acts the same left and right and you would be very very surprised how big the difference actually is between a 100% correct sway bar and one that has been thrown into the car with no effort.
Originally Posted by defcone View Post
Thanks for the pics, car looking very nice as usual. How come you can solder the motor wires like that? Aren't the A and C poles swapped around?
It's a speed controller in testing I made myself to try some ideas. So far the results are very good as I'm able to run a mod-motor indoors with no fan on the heatsink. As you might see from the pictures, the footprint = genius 75!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 02-07-2012, 08:55 AM   #3326
a few pics....probably won't get to mount the electronics again until Wed. Too much freakin work piled up.
You should probably get all your turnbuckles flipped the same way.
I'm wondering why they still have so many bends in the front swaybar. Seems unnecessary with the new layout.
I picked up a couple Yokomo SD200-H servo savers while I was in Hong Kong. I haven't installed it in the car yet, but it looks like it'll work well. That being said, with the new upper deck being higher, a Kimbrough or Xray will probably fit without a problem.
-Mike
Old 02-07-2012, 09:10 AM   #3327
olhipster1's Avatar
-Mike
turnbuckle direction doesn't make a difference at the end of the day. as long as they are the same length it's good to go.
CAUSE and EFFECT
Old 02-07-2012, 12:14 PM   #3328
Got to see a few of these cars at the local track on Sunday. Very nice.
They were all running them for first time with one being built.
Biggest thing that we noticed was that the car was very unbalanced with a standard lipo(orion pack). Once that was sorted the car seemed very good. The other thing is that the front suspension is very light compared to the back with box stock setup. Seems strange... springs and oil changes seemed to fix that.
One car ran in 17.5 boosted and other ran in Blinky.
I know a few more want to get them after taking a look... one other thing was zero breakage.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 02-07-2012, 12:36 PM   #3329
Thumbs up
did they go to thicker oil and springs front and rear?
what were the lap times compared to the 4-cxl?
rich
gdcopbdcop is offline   Reply With Quote
Old 02-07-2012, 01:24 PM   #3330
poochy's Avatar
What is the best glue for the lipo tabs? Brand?
is there a super strong lipo brace.....?
poochy is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
