Old 11-18-2011, 06:28 AM   #3166
poochy's Avatar
Originally Posted by outtafocus View Post
Its been a little quiet in here lately, so I thought I should ask some more questions.
I am currently running the Losi JRX-S Type R and having read through some older pages of this thread I see people were using the Losi LCD drive shafts. Seeing as I have a few of them here I was going to try them out. Are people still using these or have you guys found other parts to work better?
When guys talk about the HPI silver spring, is this the one they refer to?
http://www.amainhobbies.com/product_...5mm-65-Coils-2
fyi-i just ordered these from amain the other day and they came in black color not silver like the picture indicates--
poochy is offline   Reply With Quote
Old 11-18-2011, 06:47 AM   #3167
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
they do come black with silver paint mark on them
Craig W is offline   Reply With Quote
Old 11-22-2011, 08:46 AM   #3168
kwiksi's Avatar
Trader Rating: 101 (100%+)
Send a message via AIM to kwiksi
Fanboyz check my F/S thread.
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - Vision Racing Products - Reilley Motorsports - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 11-23-2011, 06:01 AM   #3169
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Hello there.
I have once again updated my blog!
Have fun reading!
Martin.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-23-2011, 06:10 AM   #3170
kp-61's Avatar
Hi Martin,
Im trying to replace the quick clips with the purple spaces but they dont fit. Did you drill those tiny washers to make it fit?
Any updated setup sheets?
cheers!
Ryan
kp-61 is offline   Reply With Quote
Old 11-23-2011, 06:15 AM   #3171
Hotbodies/HPI purple washers are a direct fit. Inner diameter of 3.15mm
I still use the same setup as always. No changes at all. Boring I know :-)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-23-2011, 08:34 AM   #3172
kp-61's Avatar
Nah why change what works btw which setup sheet is your latest with the new carpet spec top deck. Also what is a good one for standard topdeck for indoor carpet
thanks !
Old 11-23-2011, 09:14 AM   #3173
Craig W's Avatar
hi martin
i just got to gear diff was wondering what oil to run on carpet
Old 11-23-2011, 12:56 PM   #3174
NikoRacing's Avatar
Hello to all!
I'm new to electric world. I come from 6 years in 1/10 nitro racing and this winter I want to keep racing.
I have now a Mi4CX and I still need to buy a body.
What do you suggest?
Which are the best bodies on the market now and their many features?
There are light and regular bodies like in the nitro class?
I will use the car in a small indoor track with rubber tyres.
Thank you for the replies
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 11-23-2011, 07:11 PM   #3175
jhock's Avatar
Bodies of choice are Mazda 6 or ltcr from pro line. Those are the best handling bodys
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 11-24-2011, 08:47 PM   #3176
BennyBagems's Avatar
Trader Rating: 15 (100%+)
Roughly how long does it take to change over to the long top deck?
My supplier is coming to the track on Sunday and I would like to fit it before the first round of qualifying.
Am I right in thinking it replaces the center bulkhead where the layshaft is, and the little diff retainers?
BMAX 4 III - YZ-2 - S350BE-1
Ryper Hobbies - AKA - Arrowmax Tools - Yokomo Australia
Vice President GOMCC - http://www.gomcc.com.au
BennyBagems is offline   Reply With Quote
Old 11-25-2011, 02:41 AM   #3177
lochness42's Avatar
It's really hard to say - it depends how quickly you can wrench
Yes it replaces center bulkhead and diff retainers - don't forget threadlock as you'll need to use it on grubscrews for roll bars.
Uh and if anybody is using twin point steering system - don't forget to switch std nyloc nuts to low nuts and preferably also shorter balstuds. You most likely can get away also with little dremelling on nyloc nuts but I didn't like that idea.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 11-27-2011, 12:15 PM   #3178
Do the soft weave chassis fit the Mi4Lp? Going to get the long top deck, and chassis needs replacement too
JiiIii is offline   Reply With Quote
Old 11-27-2011, 01:31 PM   #3179
Send a message via ICQ to MattW
Softweave chassis is fine for LP, long top deck is a little difficult, as you end up needing a 1.5mm spacer between LP bulkhead and new diff mount part, makes it a little tricky to build - although is possible.
MattW is offline   Reply With Quote
Old 11-27-2011, 01:46 PM   #3180
Thanks for the info, saw the post earlier about fitting the long deck on an LP, going to give it a try.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
