Old 10-21-2011, 01:39 PM   #3121
notch johnson's Avatar
YEEEPPPP....
www.topnotchseries.com TNT NITRO SERIES ROUND 3 @ DIALED IN RACEWAY 11-19-16
RACE LINE DESIGNS! Track Building Specialist! PM ME
Follow me on twitter @notchzilla or @topnotchseries
notch johnson is offline   Reply With Quote
Old 10-21-2011, 03:52 PM   #3122
Send a message via ICQ to MattW
Originally Posted by grippgoat View Post
I was wondering how the swaybars mounted with the long top deck. Looks like the holder is integrated, pretty slick! Does look like it could be a PITA getting to that lower screw, though. Maybe you can just take out the upper screw and go down through the hole? If not, I might finally have to get a 2mm ball-tip driver.
-Mike
Correct - this is the reason that the screw above is M4 - so that the hole is big enough to get a driver through to get down to the lower fixing screw. There is also a hole in the new alloy mount that allows you to get a driver to the grub screw for the roll bar.
MattW is offline   Reply With Quote
Old 10-22-2011, 02:44 PM   #3123
Preliminary report:
I'm in a hurry, as I have to be somewhere. But so far, the long top deck does not exactly fit the Mi4LP. There's a difference in the shape of the bulkhead between the swaybar holder and the diff retaining post. However, it looks like 1.5-2mm of spacers should resolve the issue. I won't know for sure until later this evening when I get to fit it the rest of the way.
-Mike
Old 10-22-2011, 04:12 PM   #3124
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
What fdr should I be looking at for a smaller indoor carpet track 17.5 blinky? Thanks. I run about a 3.9 rite now and full endbell timing and temps are about 150. The stright is about 70ft long.
Blitzrockey is offline   Reply With Quote
Old 10-22-2011, 05:11 PM   #3125
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
4.25 should be ok
Old 10-22-2011, 05:22 PM   #3126
Originally Posted by Marcos.J View Post
4.25 should be ok
Thanks, would that keep my top end and still have good rip? I think its 3.94 right now, and works really well, jw if a higher fdr like you listed will be even better?
Old 10-22-2011, 06:05 PM   #3127
Our club is something like 45x100 feet. It's pretty tight on the infield. Most of the 17.5 blinky drivers are in the 3.8 ballpark with two marks over 0 on Duo 3.
-Mike
Old 10-23-2011, 02:33 AM   #3128
Default Long Top Deck on Mi4LP
Here are some pics.
-Mike
Schumacher Mi4-cimg1533.jpg   Schumacher Mi4-cimg1534.jpg   Schumacher Mi4-cimg1535.jpg   Schumacher Mi4-cimg1536.jpg   Schumacher Mi4-cimg1537.jpg
Old 10-23-2011, 02:34 AM   #3129
Here are some more pics.
-Mike
Schumacher Mi4-cimg1538.jpg   Schumacher Mi4-cimg1539.jpg   Schumacher Mi4-cimg1540.jpg   Schumacher Mi4-cimg1541.jpg   Schumacher Mi4-cimg1542.jpg
Old 10-23-2011, 02:39 AM   #3130
And one last pic, and some notes.
1) I needed 1.5mm of spacers between the mount and the bulkhead. I imagine that will become a PITA very, very fast when it comes time to pull the mounts to get the diff out.
2) The long screws that go through the top deck mount, through the 1.5mm of spacers, and into the bulkhead, are only getting 3 turns on the screw. That's 3 threads, and with a .5mm thread pitch, that's only about 1.5mm of depth, which doesn't seem like a good idea. I'd want to get longer screws before running this.
3) With the front gear diff, the front belt is reeeeeeeally close to the top deck. There's a tiny fraction of a mm of space, but I think as soon as the car runs and the belt moves around a bit, it'll rub. I could try moving both diff shims to the pully side to get a hair more room.
I didn't get a weight difference yet. I'll weight it before I take it off. I think I will sell it and go back to the stock setup.
-Mike
Old 10-23-2011, 05:55 AM   #3131
lochness42's Avatar
Yeah CX has this bit raised - I've just checked it. Maybe you should try to glue them in place - I know it's a bit crazy idea but it will sort out disassembly issues
As I mentioned - these screws should be just fine with CX bulkheads as you've got longer used thread (that's difference as you don't have to use shims)
Is it just close to top deck or new diff holders? If it's just topdeck - I would try to sand it a bit and space diff to the other side as much as possible.
All in all it requires some work to fit it on other Mi4s in the end. Thanks for letting us know what kind of problems one can encounter.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 10-23-2011, 01:07 PM   #3132
Hi. Ive just an MI4CX 2.5mm Softweave chassis on my mi4. Ive come to fit the servo and have hit a problem. The servo mounts on the CX are offset so the servo wouldnt sit square. I spaced the mounts out until my CX/LP (there the same) ones arrive, so that fixed that but then my next problem was that i cant get the servo far enough away from the centre of the caqr to allow me to fit my servo saver. Is there a servo saver that people with a cx use that fits nicely. My servo is a full size one. None of this would be a problem with a low profile one. Thanks for any help
Also I have been thinking of getting the twin point steering setup. How does this affect the steering??
Also I have seen some pics of cars with an 'O ring' Mod to the rear trans links. Doe sthis just give more flex on the rear end?
scytherat is offline   Reply With Quote
Old 10-23-2011, 07:49 PM   #3133
poochy's Avatar
read the rctech thread about your motor-not all motors fall into the same fdr range
poochy is offline   Reply With Quote
Old 10-23-2011, 08:53 PM   #3134
-Mike
The long top deck seems to weigh about 13g more than the standard LP setup. If you dremeled off the unneeded portions of the LP bulkheads, it might actually be lighter than the stock setup. I'm pretty surprised.
-Mike
Old 10-23-2011, 09:50 PM   #3135
skypilot's Avatar
Trader Rating: 14 (100%+)
13g holy cow, that could end up being the difference between 1st and 7th.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is online now   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
