Old 09-06-2011, 02:11 PM   #2971
Originally Posted by Marcos.J View Post
this is the best that I can do got it from a snap shot from my IPhone
(Sorry for the picture quote... I was afraid it wouldn't make sense without it.)
Did you mess up the quik klip settings? There should be 4mm total on each arm, but you've only got 2mm total.
-Mike
Old 09-06-2011, 02:58 PM   #2972
GSM Storm's Avatar
Trader Rating: 112 (100%+)
[QUOTE=Marcos.J;9622875]Asphalt or carpet? I ran the above setup with rp 40's on carpet with a sp6.5 and worked very well , I did however changed the front diff fluid to 500,000.
Hi Marcos
On Asphalt, car lacks grip all round, on Sorex tires the car is good with our current setup, not with the Sweep OG-Spec 40 tires.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 09-06-2011, 04:19 PM   #2973
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
-Mike
My bad 1.5/2.5 sorry lol
Old 09-06-2011, 05:10 PM   #2974
So... you moved weight back? For more steering?
-Mike
Old 09-06-2011, 05:12 PM   #2975
Super Moderator
Marcos.J's Avatar
-Mike
1.5 in front of arm 2.5 in the rear of the arm
Old 09-07-2011, 01:20 AM   #2976
I got that. That moves the arms forward, which moves weight back. I was asking if you did that for more steering?
-Mike
Old 09-07-2011, 01:55 AM   #2977
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
moveing the wishbone forward tends to give a bit more initial steering and might be better through sweepers on some tracks, however it usually creates huge understeer in hairpin turns / corners that tend to get tighter
This is why the team is running (front to back) 2.5/1.5/2/2 wheelspacing basically everywhere. Rearhubs spaced .5/.5
This seems to be the sweetspot of the car.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-07-2011, 02:02 AM   #2978
Benzaah's Avatar
Trader Rating: 21 (96%+)
What effect would this have on the car compared to 1mm front, 0 rear and vice versa?
A couple more questions if you dont mind?
Have you tested the 6 degree caster blocks with your anti dive set up in the front of the car?
Have you also tested using arm sweep on the car at all? My previous Xray liked 1.9 front 1.5 rear pivot block spacing and handled the tracks sweeper with ease. I have not bothered to test this on the CX yet.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 09-07-2011, 02:23 AM   #2979
I'm not running what you would call a lot of antidive. 0.3 almost makes no difference. It's just enough to keep the car from diving on brakes but little enough to no sacrifice steering.
I ususally don't use front inboard toe-out. It needs to suit the car and the developement seems to go away from that and just use staight front hingepins.
rearhub in the middle gives the best driveshaft angle. and the wheelbase is right then.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-07-2011, 02:57 AM   #2980
Super Moderator
Marcos.J's Avatar
-Mike
Yes
Old 09-07-2011, 02:58 AM   #2981
Super Moderator
Marcos.J's Avatar
I haven't encountered any understeer yet on this track, but I see what you mean
Old 09-08-2011, 06:07 AM   #2982
kp-61's Avatar
Just got the kit and am currently building the drive train.
I was wondering if you were able to fit in regular spur gears or I have to stick with Schumacher ones.
Thanks !
* VISA * MASTER CARD :)
kp-61 is offline   Reply With Quote
Old 09-08-2011, 10:33 AM   #2983
Super Moderator
Marcos.J's Avatar
Thanks !
Stick with the Schumacher ones you can reach any fdr that you desire.
I made an adapter a while ago to be able to use any spur gear but I always ended up using the Schumacher ones.
Old 09-08-2011, 12:09 PM   #2984
poochy's Avatar
for those with rear belt problems with the gear diff.......i rid this problem by adding a shim to the diff float area-this slightly improved the the center pulley alignment with the gear diff pulley-no more rear belt problems (4.5 motor)!
hope this helps somebody. also set the belt tension tight enuff so the rear belt teeth sinks into the gear diff pulley on normal hand rotation test. too tight causes extra heat.
poochy is offline   Reply With Quote
Old 09-08-2011, 12:13 PM   #2985
Super Moderator
Marcos.J's Avatar
Haven't encountered any problems running 5.5 but thanks for the info.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
