Old 08-31-2011, 04:05 AM   #2956
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by Benzaah View Post
Ive found that minimal grease works better than slathering it in there like in the Grainger Video. Here is a link to a good rebuild article when the Mi3.5 was out. Diff is pretty much the same these days anyway's. I was getting around 30 runs before rebuild in boosted stock doing it this way.
http://www.actionrc.com.au/downloads...ateMi3Diff.pdf
As for the Springs the pro 4 springs are the ones everyone uses. I have found Xray springs much better with either 2.8 all round or 2.8f/2.6r an awesome combo and on my home track kit springs are also faster than the Hpi's. I have found the HPI's to be a waste of my money...
Schumacher whites all the way around works great , I have also used the tamiya yellows for asphalt
RACE OPT USA
Bartolo Racing R/C
Old 08-31-2011, 10:30 PM   #2957
skypilot's Avatar
Trader Rating: 14 (100%+)
diff building instructions that were posted a while back that I had saved on another thread...
The following is Diff building tips, it was on the shouie thread but should transfer over to most if not all diffs
Try this and let me know if it helps...
Before starting think of diff building like cooking with chicken. The black thrust lube is the chicken and if you get it on the diff balls, rings or pulley your diff will get sick and DIE!
Before I start I clean EVERYTHING with motor spray.
1. If you havent gotten a U1954 Tungsten Carbide Thrust Bearing get one. Its better then the one inculded in the kit.
Clean it all out and use Schumacher Black Thrust lube. Measure the outside diameter of the thrust washers. The small diameter one goes on the screw first.
Go wash your hands and get every bit grease off your fingers.
2. Sand U2408 diff rings with 600 grit wet dry on both sides using motor spray to wet the paper until you see even scorring of the rings entire surface.
Clean them with motor spray and place them on a clean paper towel.
3. Toss the ceramic diff balls. The U2459 Tungsten Carbide diff balls are smoother and longer lasting. Place the balls on a clean paper towel and CAREFULLY spray them with motor spray to get rid of any protective oil that is on them. If you spray too hard you will launch $15 of diff ball all over you room and they will be gone forever. When they are clean and dry put them in the tub of U1301 Silicone diff grease. Pluck them out and place them in your diff pully. Thats all the grease you will need.
4. Gradually tighten up the diff untill one output starts to spin opposite the other one. Gradually tighten the diff a little then spinn it a little untill you feel the diff screw has colapsed the spring washers next to the thrust bearing and it dosen't want to turn anymore.
The goal is to tighten the diff but not pit your freshly sanded diff rings.
5. Loosen the diff 1/4 turn then lock down the grub screw on the opposite side.
6. Put the diff in your car and turn everyhting on. wit the car up on a car stand. Run the car at low throttle while alternatly touching each rear wheel untill it stops. Repeat this 2-3 time per side.
The diff should be super free, super smooth and should not slip at all.
If you diff slips just once during a race it will score your rings and it will be junk. You will have to rebuild it and flip, resand or replace the rings.
The U1954 thrust will last longer than yuor kit so it will never be the cause of diff problems. The U2459 ball will survive at least 6 months or more. The only things that go bad in a diff assembled with these parts as described are the rings and you can resand them several time before you need to replace them.
Adrian Martinez
BMI Racing
bmiracing.com
DB12R NOW AVAILABLE!!
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-01-2011, 03:15 AM   #2958
BrodieMan's Avatar
"Before starting think of diff building like cooking with chicken. The black thrust lube is the chicken and if you get it on the diff balls, rings or pulley your diff will get sick and DIE!"
Tungsten Carbide balls are better than Ceramic. Good to know. I thought ceramic was the end all and be all of diff balls.
Going to finally get myself a Muchmore bearing remover tool. Been on my "Need" list for far too long. Mi4 hub bearings are 5x10x4 which would make them M5 size correct.
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 09-01-2011, 02:09 PM   #2959
Super Moderator
Marcos.J's Avatar
i have my gear diffs on the way for the front and rear should have them by tomorow.
RACE OPT USA
Bartolo Racing R/C
Old 09-03-2011, 05:48 AM   #2960
Super Moderator
Marcos.J's Avatar
The gear diffs fit just fine. The belt alignment in the front is good. All I did was I removed a little off the diff case and added another shim in the right side. It's perfect
RACE OPT USA
Bartolo Racing R/C
Old 09-03-2011, 07:10 AM   #2961
Super Moderator
Marcos.J's Avatar
Here is my set up so far , Ran it with the spool in the front and works very well
Testing again tomorow if I make any more changes I will post a new revised sheet.
pm me your email and I will email it to you , file is too big too post
RACE OPT USA
Bartolo Racing R/C
Old 09-03-2011, 10:40 AM   #2962
Super Moderator
Marcos.J's Avatar
this is the best that I can do got it from a snap shot from my IPhone
RACE OPT USA
Bartolo Racing R/C
Old 09-03-2011, 10:05 PM   #2963
BrodieMan's Avatar
What pinion were you using Marcos? Looking for a good starting point for my FDR running 17.5 on a small carpet track. Will try your setup and see how I like it. Thanks
Mark Richardson
Old 09-03-2011, 10:52 PM   #2964
skypilot's Avatar
with a 118 spur he must be using boost, and unless your using the same esc and setting his pinion info is useless
Old 09-03-2011, 10:58 PM   #2965
BrodieMan's Avatar
different ESC & Motor but boosted 17.5 on a similar track. Just looking for a good starting point as I have been running un-boosted with my previous TC with an FDR of 5.64 and never ran boosted before.
Mark Richardson
Old 09-04-2011, 01:08 AM   #2966
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Setup using Sweep OG-Spec 40 Tires
Hi all
Has anyone got a setup running Sweep OG-Spec 40 tires in Mod.
Regards Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 09-04-2011, 04:34 AM   #2967
Super Moderator
Marcos.J's Avatar
I'm running a 32 pinion with the 118 spur
Yes I'm running boost , lrp sxx v2 using 11boost
RACE OPT USA
Bartolo Racing R/C
Old 09-04-2011, 10:32 PM   #2968
Super Moderator
Marcos.J's Avatar
Ran the above set up in mod today and it was very good, I ran a 6.5 with a little boost
RACE OPT USA
Bartolo Racing R/C
Old 09-06-2011, 11:03 AM   #2969
Super Moderator
Marcos.J's Avatar
Originally Posted by GSM Storm View Post
Hi all
Regards Gary
Asphalt or carpet? I ran the above setup with rp 40's on carpet with a sp6.5 and worked very well , I did however changed the front diff fluid to 500,000.
Also I have over 10 PDub hard front bumpers for the mi4/3/3.5 if any needs one send me a pm.
RACE OPT USA
Bartolo Racing R/C
Old 09-06-2011, 12:58 PM   #2970
Marcos,
those things are as scarce as teeth on a chicken. Could I buy 2 of them? 1 for me and 1 for racer-x.
Rich
gdcopbdcop is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
