Old 06-26-2011, 08:00 AM   #2821
Trader Rating: 16 (100%+)
Default GEAR DIFF
I would like to know if the 700 to 1000 weight oil for the gear diff,is that the same as 70 to 100 weight shock oil.
jtsbell is offline   Reply With Quote
Old 06-26-2011, 02:06 PM   #2822
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default What class
Originally Posted by WildManDriving View Post
Thank you for the help guys though I have now changed so many settings and confused myself. What setup sheet should I go back to for MuchMore 32V on low traction outdoor Tarmac both tight and open.
What class are you running.
regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 06-26-2011, 02:45 PM   #2823
WildManDriving's Avatar
Trader Rating: 29 (100%+)
regards
Gary
I step between 13.5 boosted and Mod (6.5t). On big race days it's 13.5.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 06-27-2011, 09:52 AM   #2824
No.
Numbers into the hundreds and thousands are normally rated at Centi Poise cps, which is another way of rating thickness. 1000cps is 70-75 wt and 700cps would be around 50-60wt.
Here's a converter. But use just as a rough guide as even different brands rated as the same weight or cps can still have quite different thickness's.
YZFAndy is offline   Reply With Quote
Old 06-29-2011, 03:02 AM   #2825
may have been covered before but i cant find it. im planning to put the twin point steering setup on my mi4. in all the pics ive seen have had a low profile servo fitted. can you use a full sized servo or do i need to get a low profile one to get it to fit?
scytherat is offline   Reply With Quote
Old 06-29-2011, 04:40 AM   #2826
Benzaah's Avatar
Trader Rating: 21 (96%+)
You can run the twin point steering with the servo mounted the same way as with the single point set up. You just have to shim out the ball stud a little. Here is a pic with a low profile servo. No reason this could not work with a normal sized servo...
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 06-29-2011, 07:51 AM   #2827
Ahh ok thanks. That car you posted a pic of has some very different looking rear body mounts. Where are they from?
Old 06-30-2011, 02:56 AM   #2828
Benzaah's Avatar
That's Martin Hofers car from the Polish round of the ETS. Those body posts mounted off the shock tower are there to stop the rear of the body crumpling and fouling the rear tyres when lots of traffic is riding up your but....
Adelaide RC
Walter Rc Hobby
Old 06-30-2011, 05:10 AM   #2829
poochy's Avatar
Where can i find some short pinion set screws that wont rub on the frnt belt?
poochy is online now   Reply With Quote
Old 06-30-2011, 09:41 AM   #2830
skypilot's Avatar
Trader Rating: 14 (100%+)
One set of body mounts, one set of body posts, must be some rough driving going on. Lol
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-30-2011, 10:49 AM   #2831
qcrc's Avatar
I would try Tony's screws.
http://www.tonysscrews.com/main.sc
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 06-30-2011, 01:38 PM   #2832
I think the aluminum thingies are more to provide support for the rear wing.
-Mike
Old 06-30-2011, 02:51 PM   #2833
qcrc's Avatar
-Mike
That would be my guess as well. It would put the down force on the chassis and not deform the body. If you look at some of the pics of his car the wing is as far back as it can go. It helps on those huge nitro tracks like the last ETS series race.
Schumacher Cars
Old 06-30-2011, 04:56 PM   #2834
skypilot's Avatar
well, actually, I have those and am fully aware of there function.
you guys need to learn to take a joke.
Old 07-01-2011, 05:44 AM   #2835
Where can you get those alloy bits? Where i race it isnt uncommon to be used as a brake into some of the corners so this would really help
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
