Old 06-12-2011, 07:13 PM   #2791
Benzaah's Avatar
Trader Rating: 21 (96%+)
Very quite in here. Will be interesting to see the Hofer set up from the ETS this weekend gone. Large open tracks is what we run here in australia and a lot of the set up's online just don't carry over.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is online now   Reply With Quote
Old 06-12-2011, 08:48 PM   #2792
how did he finish up, and what class was he running?
thank you,
gdcopbdcop is offline   Reply With Quote
Old 06-12-2011, 10:06 PM   #2793
Danny-b23's Avatar
thank you,
He finished 2nd in 13.5 Pro Stock.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 06-12-2011, 10:57 PM   #2794
Benzaah's Avatar
Getting pipped by a local in a Tamiya is a solid effort especially When Tamiya have Groskamp in the pits setting up the teams cars! They are almost unbeatable...
Adelaide RC
Walter Rc Hobby
Old 06-13-2011, 11:08 AM   #2795
Danny-b23's Avatar
Key point. Lots of guys there can drive well, but if Groskamp is giving you setup advice you've got a massive advantage.
Danny Buck
Old 06-13-2011, 11:24 AM   #2796
Wow, Great JOB!
i bought and installed the gear diff in my car. I ran it with 40 wt oil. made the back end way tooo loose. i then used 60 wt oil, was better, but i didnt have anything thicker. what oil do you guys recomend for the spec r rear gear diffs?
Old 06-13-2011, 12:24 PM   #2797
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Wow, Great JOB!
1000wt diff oil if you cant get that try 100wt shock oil
Craig W is offline   Reply With Quote
Old 06-14-2011, 08:26 AM   #2798
Craig,
I put some 1000 wt in, still feels very smooth. Cant wait to try it.
Rich
Old 06-15-2011, 06:00 PM   #2799
Trader Rating: 16 (100%+)
Default gear diff
Just goi my spr009mi built and started to put it in,the dog bones are way to small for the gear diff joint.Is there a part number I need to get the wright gear diff joints to fit my MI4CX?
jtsbell is offline   Reply With Quote
Old 06-15-2011, 06:44 PM   #2800
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Gear Diff
I think if you buy the diff from Spec R it suits the Mi4, the old drive shafts, when you get the diff from Schumacher it does have different out drives that fit the plastic sliders.
I have not seen the part number for the outdrives to suit the Mi4CX, check on the Schumacher site.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 06-15-2011, 11:39 PM   #2801
lochness42's Avatar
I got Spec-R diff off Schumacher directly and it was direct fit for my CX (didn't have oportunity to try it yet on track though).
http://www.racing-cars.com/pp/Manufa...ec_R/G868.html
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 06-16-2011, 12:39 AM   #2802
caltek1's Avatar
Trader Rating: 33 (100%+)
If you want to use the SpecR oil gear diff on the MI4 or MI4LP, then you need to use the Cx rear universals. I have this fitted to my MI4LP.
The standard MI4/MI4LP universals will not fit.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 06-16-2011, 10:03 AM   #2803
skypilot's Avatar
Trader Rating: 14 (100%+)
Craig,
Rich
hey Rich, I was using xray cst 650 shock oil in mine at Reedy, on a low traction track it will be loose, but high bite it is ok, and when you get used to it, steal Jeffs gear diff, put 50,000 in it, and put it in the front of your car thats for low traction, I haven't done high traction yet, but I'm thinking at 100k or more that. I should have ran that at Reedy, IT IS FREAKING AWESOME.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-16-2011, 01:37 PM   #2804
Regards,
Calvin.
If you take the slider rings off, the older blades fit the newer inserts. Just make sure you're not bottoming out the blade. I ran an LP with SpecR diff and LP driveshafts with no problems a couple weeks ago.
-Mike
Old 06-16-2011, 01:48 PM   #2805
caltek1's Avatar
Mike,
I tried the standard rear universals fitted with the grey blades and these did not fit, that wa with the slider removed. Perhaps I should have tried a different blade on the standard MI4LP universal. It would have saved me a few dollars.
The main thing is it is working.
Thanks for the heads up.
BTW,
I run between 700 and 1000 wt oil in my oil gear diff, depending on grip levels at the track.
Calvin.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
