Old 05-29-2011, 11:35 PM   #2776
skypilot's Avatar
Trader Rating: 14 (100%+)
and thank you Rich for the kind words and for driving down just to lend a hand. thanks a ton.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-30-2011, 10:30 AM   #2777
Trader Rating: 28 (100%+)
Ritchie,
Thanks for coming out to the Reedy. You are a gentleman on the track and got the skills to back it up. Hope to see you northwesterners out again at some point.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-30-2011, 12:23 PM   #2778
skypilot's Avatar
Good Times indeed, and with Family in the area, I may just fly down for weekend club race soon, I love that place. if it wasn't for the overpaid job i have I'd move back in a minute.
the compliments goes both ways. where did you end up overall?
Old 05-30-2011, 01:04 PM   #2779
Ended up 5th overall had an awesome car for the mains but had bad luck in A1. A2 and 3 had to work to get around the 4th place guy and when able to finally do so was able to reel in Juan but time ran out being that it was a 4 minute format. Brumblay was not playing in a2 and 3 and was gone.
Team I'm Over It
Old 05-30-2011, 07:18 PM   #2780
skypilot's Avatar
Cool deal, I just found the results a minute ago, 7th for me, which isn't to bad for not running the A3. A2 my car was a dog, later found the pinion jammed back into the spur for some serious drag. I have no idea how that happened, it was all good after A1, lesson learned.... at big races, the car comes apart and goes back together. oh and run only one class. maybe see you soon, maybe you can come up for our annual big race the " Fantasy World Summer Sizzler ", its the 2nd weekend in August I think, you can stay with me, only cost you a plane ticket. hopefully they can get a "big name racer to join us again, Keven H. was here a couple years ago, Barry Baker a couple years before that.
Old 06-05-2011, 04:48 AM   #2781
WildManDriving's Avatar
Trader Rating: 26 (100%+)
After chat with local races on setup for MuchMore tyres I am wanting to try long suspension arms front and rear with long camber links. How much longer are long arms? and what handling effect does narrow hexs have?
Thanks,
Michael.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 06-05-2011, 11:40 AM   #2782
Danny-b23's Avatar
Thanks,
Michael.
The long arms are 2mm longer than the short versions, and putting a narrow hex on one end of the car is going to give that end of the car a little bit more grip at the cost of stability.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 06-06-2011, 10:19 AM   #2783
poochy's Avatar
Default front belt wear
i am noticing my front belt is wearing out too quickly (teeth side). is it possible that the pinion is doing this?
i run option 2, and to move the motor closer to the center i flip the pinion so the teeth number is facing the lipo.
poochy is offline   Reply With Quote
Old 06-06-2011, 11:17 AM   #2784
timmay langdell's Avatar
short wishbones are 1mm narrower than the long wishbones
timmay langdell is offline   Reply With Quote
Old 06-06-2011, 11:37 AM   #2785
If you are running a big pinion that has a long grub screw that is raised above its threaded hole then it can hit the belt and trash it.
YZFAndy is offline   Reply With Quote
Old 06-06-2011, 12:19 PM   #2786
poochy's Avatar
YZF, running 48p 14t pinion with a short grub screw-i replaced the frnt belt and went to short grub screw (sits almost flushed with pinion) and raced yesteday and still noticed wear on the new belt (minor wear this time).
even with the short grub, it seems to still slightly touch the pinion. anyone notice wear with the short grub?
Old 06-06-2011, 04:45 PM   #2787
I raced two cars each with a rear gear diff on saturday. I don't see myself going back to a ball diff, since I seem to be incapable of properly building them.
-Mike
Old 06-06-2011, 04:54 PM   #2788
Trader Rating: 17 (100%+)
-Mike
Did you have to make any setup changes with the gear diff after running a ball diff? What weight oil did you use?
Cheers, Lee
Xray T4 Sanwa M12
Team Xray Australia
STMCC President:
I was alright, .......but I got over it
New Web Address www.stmcc.webs.com
lethallee69 is offline   Reply With Quote
Old 06-06-2011, 11:02 PM   #2789
Cheers, Lee
Have to? Probably. Did I? No. It was my first asphalt event of the summer, I didn't really mess with the setups at all. Was busy trying to figure out gearing for my boosted 13.5 car (which I failed at, blew the motor big-time).
Anyway, one diff, the first I built, had 60wt assoc shock oil, and was clearly leaking a bit. The second one I built, which I didn't even use any diff grease to seal around the case (just under the outdrives), I put 80wt Losi oil into, and it stayed bone dry all day.
In the car I put the 2nd diff into, the ball diff was pretty tight and gritty. The car was understeering, and wanted to kick the tail out under power. After I put the gear diff in, it smoothed things out considerably. It rotated a bit better into the corners, and was smoother on corner exit. But, it probably wouldn't have been as noticeable if the ball diff wasn't so bad. It did still understeer, but I didn't try much with the setup to fix that.
-Mike
Old 06-07-2011, 10:12 PM   #2790
loriding69's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to loriding69
In need of 48p spur gears. If ya have some, send me a PM of what you have and what you want for them. THanks!
Double E
If your not here to have fun, then stay at home!!!
Breast Cancer Awareness is my race for the cure!
loriding69 is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
