Old 05-05-2011, 05:40 AM   #2716
poochy's Avatar
Originally Posted by 6Venom View Post
Here are a couple of the rear. You can see the cut into both the front and rear side of the arm. The fronts have the same cut but only on the front side. Thanks again.
i saw this and checked mine. running mod on a large asphalt parking lot. with the stock CX c/f rear arms, i am showing some wear as well..the tires i am using are MuchMores 28s, i also see a black circle on the inside rim. i will try schumacher sorex 28s this weekend and see what happens.
poochy is offline   Reply With Quote
Old 05-05-2011, 09:19 AM   #2717
skypilot's Avatar
Trader Rating: 14 (100%+)
This issue isn't a big deal. I've had every model back to the the mi3 and they all have done.it.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-07-2011, 03:04 AM   #2718
Gear diffs were in stock at Schumacher, briefly:
http://www.racing-cars.com/pp/New_Ca...i4CX/G868.html
I think I ordered the last two, though. They went out of stock after I placed my order. I hope they actually have two for me.
Apparently the diff has CX-style outdrives, but works with the blade axles, too. This piqued my curiosity, so I just tested my CX diff in an LP with blade axles. The blades are very close to bottoming out, but seems to just clear through the full range of travel.
EDIT: I had to remove the slider rings to get the the CX diff to work with the blade axles.
-Mike
Old 05-07-2011, 01:31 PM   #2719
skypilot's Avatar
you ordered those for me to take to Reedy thanks
speaking of which,, any Schumacher Team guys going to Reedy??
Old 05-07-2011, 03:52 PM   #2720
Sure, if they get here in time.
-Mike
Old 05-07-2011, 11:08 PM   #2721
jrxs-r's Avatar
Seems like EGR Mart has some in stock. Purchased 2 yesterday.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 05-07-2011, 11:11 PM   #2722
skypilot's Avatar
-Mike
I was joking, but sweet deal, thanks
Old 05-08-2011, 11:23 AM   #2723
Send a message via MSN to jwright1
Exclamation
Could anyone help me with a setup for this car ? I run lipos in it and wanted to know a camber/toe/droop setup all front and rear (any at all would also be much appreciated) I'm looking for a medium - slippy surface setup. I believe my rear droop is currently 25.5 mm and my front is 23.5mm (it was somewhere in between what it was when I measured it) (with a vernier gauge from stub axle to ground on a flat surface) it could be bang on or completely wrong I have no idea, so approximate measurements would all be appreciated.
Cheers - James
W.R.C.R.T
jwright1 is offline   Reply With Quote
Old 05-09-2011, 04:15 AM   #2724
CA
We have plenty of stock of the gear diff's. Some drivers tested them yesterday and reported a few 10'ths knocked off the laptimes and more consistant throughout the run.
Obviously there is more force on the rear belt and pulley so you have to watch those more closely.
It is recommened to fit the small shims on the output shaft as it doesn't show this in Spec R's instructions.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 05-09-2011, 08:13 AM   #2725
poochy's Avatar
good to hear, am about to make the order. who in the U.S. might have it now? would like to make sure i order everything, what oil is recommended, and do these small shims come with the Gear Diff set, if not then what shims should i get?
Old 05-09-2011, 08:45 AM   #2726
CA
Our US dealers wont have them yet as they only came in here friday. All shims are included. Just as the website says we've been running Schumacher 70wt shock oil in them.
www.racing-cars.com
Old 05-09-2011, 09:22 AM   #2727
jrxs-r's Avatar
Hi Chris,
any new updates on the center pulley from Harvey yet?
Cheers,
Zack
Serpent S411
Old 05-09-2011, 02:55 PM   #2728
Racer X's Avatar
Skypilot: I wish I was going to be there with you at the Reedy, but lack of preparation on my part is keeping me away this year. I may drive down on Saturday and watch you tear everyone else up. Ramping has just kept me from racing hardly at all since last years Reedy. Let me know if there is anything I can do to help you...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 05-09-2011, 03:20 PM   #2729
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Gear diff oil
Hi Chris
Was the 70wt oil tested running mod class and other classes as well.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 05-09-2011, 05:21 PM   #2730
They shipped today. I'll let you know when they get here.
-Mike
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
