Old 04-15-2011, 04:38 PM   #2656
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
CX's first run on our (mainly used) zero grip track was quite EXCELLENT
Only gripe was car stepping out on power out of corners but I guess that's a combination of low grip, getting diff adjustment right & gorilla hands
Xray T4'17 - LRP - PF - Futaba - Muchmore
Brokin Racing is offline   Reply With Quote
Old 04-17-2011, 03:55 AM   #2657
the catman's Avatar
Default sway bars and out drives
I had the same problem with the sway bars and the out drives so I rebent the bars to miss the out drives. You do how ever need to make sure that all the bends you make are the same for both sides and that the end result is that the bars are flat
the catman is offline   Reply With Quote
Old 04-18-2011, 05:24 PM   #2658
I haven't had any noticeable problems with the outdrives vs. swaybars in the front. I put the o-ring into the insert, then carefully put both over the outdrive. When it pops on, check inside to make sure the o-ring is seated before sliding on all the way. When I put the sliders on this way, I had absolutely no problems with them coming loose in 3 rounds of racing and a couple test runs.
-Mike
Old 04-21-2011, 09:52 AM   #2659
poochy's Avatar
dont have the car in front of me right now, does anybody know if the 4mm arm reamer is the correct size for the mi4cx?
poochy is offline   Reply With Quote
Old 04-21-2011, 10:23 AM   #2660
nutsisneat's Avatar
No, you will need a 3mm reamer...
nutsisneat is offline   Reply With Quote
Old 04-21-2011, 11:21 AM   #2661
jrxs-r's Avatar
I think the correct size is 1/8" for the inner holes on the arm.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 04-21-2011, 11:44 AM   #2662
lochness42's Avatar
This is right answer
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 04-23-2011, 01:47 PM   #2663
Anyone have comments on the dual swing steering over the standard set-up?
Old 04-23-2011, 09:40 PM   #2664
FYI, TC6 rod ends fit Schumacher balls very nicely.
-Mike
Old 04-23-2011, 10:03 PM   #2665
jrxs-r's Avatar
The twin point steering offers a lot less akermann angle, and has a more direct/quicker steering. I have tried it, and have gone back to the standard steering setup for now till I get the car more dialed. The standard setup with 3mm spacers actually has the ideal ackermann angles (I took the time to photograph the car and photoshopped it to extend the steering lines and axle lines). The twin point steering intersect angles are forward of the rear axle line, so will offer a lot more steering.
My 2c...
Cheers,
Zack
Serpent S411
Old 04-24-2011, 12:15 AM   #2666
I have recently installed the twin point and find it a lot better. Steering is faster and more direct. I would also describe it as more linier throughout its full lock. This seems to give it the edge on consistency when pushing hard for me where the original system could make the car feel raggedy when pushing.
Admittedly the first few runs the car felt a bit edged with the twin point but you soon get used to that and now can't see myself going back to the original.
YZFAndy is offline   Reply With Quote
Old 04-24-2011, 01:14 AM   #2667
Do you use any expo with the twin-point?
Do you think the reason it feels less raggedy could be a reduction in slop?
-Mike
Old 04-24-2011, 04:09 AM   #2668
poochy's Avatar
-Mike
Mike, are you referring to the out of the ball severe ballcup bind on the ball when brand new out of the box?---FYI i was able to loosen up my ballcups by snapping the ballcup on and off the ball it is going on -about 6-8 times each cup did the trick-every ball cup, when new, was binding--unless the ballcup was damaged due to over tightening of the rod-those were replaced
the needle nose works great-but after the initial tightness is removed--sanp on/off a few times, needle nose squeezes, then a few more snap on/off will get them freed up.
-if the ballcups bind badly-like mine did on the frnt end will steer slow, losing steering
Old 04-24-2011, 07:19 AM   #2669
-Mike
I don't used expo and believe if you have to use more than 5% to take the edge of the centre point something is wrong. And good luck finding any slop anywhere on my car as its something i hate and spend a lot of time getting ride of as i like a very direct car. So not that having an influence on things.
To me it seems like the original steering has a very negative expo curve to it now. My mate has my setup on his car and the only difference is the steering, so easy to do a back to back comparison. This is also why i think the twin point has a better feel because when pushing and chucking the steering lock to lock it stays consistent and doesn't get progressive more aggressive like a lot of negative expo would.
physically looking at the two you can see why this is. The original system, no matter what initial akerman you're running, gains akerman throughout its full movement, especially after the first 50% of travel. Probably explains why there is a lot more speed scrub with it too. The new system starts of with about the same amount of akerman, when using the 2nd hole compared to 3mm of spacers on the original, but stop or slows its gain after the first , say 20% of travel.
Old 04-24-2011, 12:13 PM   #2670
No, actually the opposite. My Mi4LP is over a year old, and the ball cups are sloppy. The Pro cups are like $12 for 8 from a-main, and not reliably in stock. I was looking for a cheaper alternative. $4 for 14 from a local hobby shop sounds good to me.
-Mike
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
