Old 03-30-2011, 12:34 AM   #2596
caltek1's Avatar
Trader Rating: 33 (100%+)
Jim,
Will be better when the other big bore springs are released. I am still running my MI4LP, fitted with the Tamiya TRF shocks and HPI springs. I used silver springs front and rear.
The car works Ok to me, managed to win the 21.5 TC class at Kambah. Only thing when the grip came up was to add a 1mm spacer on the front hub, to stop the car from traction rolling, especially when using tyres that were used for a few runs. On new tyres it was not an issue.
I ran the LRP SXX SS V2 ESC with a LRP X11 21.5 motor. I had a FDR of approx 4 and a rollout of approx 50mm. Next time I would turn down the boost and increase the FDR and lower the rollout to approx 40mm.
I will have to get off my butt and build a CX and test the car out. From what I have read on this thread it is better than the LP. The only problem I ever had with the LP was breaking the hinge pin holders, which I changed to alloy and only run 2 degrees rear toe. That certainly asisted with settling down the rear end and making the car faster and having less push.
Later,
Calvin.
caltek1 is online now   Reply With Quote
Old 03-30-2011, 01:11 AM   #2597
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by Brokin Racing View Post
+ 1
Very good car, excellent quality, almost as good as Xray
I also got the big bore shocks though this somewhat limits your spring options
+1 more for the CX.
Some of the fit and finish on the plastics is to be desired but other than that im a happy camper with a big plus next to the Diff on the Cx as its freakin awesome compared to any other diff ive built. I will be updating to the alloy pivot blocks next as im sick to death of the plastic ones. This is one area where Xray wins hands down and makes changes at the track easier as ive found the Schuie plastics to bind up a lot. Although im still searching for the best set up on my CX and ive got near 2 years under my belt with My T3 they do near identical lap times. But i can drive the CX much more consistently over 5 minutes so im hoping i can get some more speed out of it and take it to the next level.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 03-30-2011, 07:12 AM   #2598
skypilot's Avatar
Trader Rating: 14 (100%+)
Boosted 21.5 ?
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 03-30-2011, 02:15 PM   #2599
caltek1's Avatar
skypilot,
Yes. Boosted 21.5. We have to run two door bodies, so the NSX, 350Z, Porsche, etc and no protoform TC bodies.
I used the recommendations in the LRP Instructions for 17.5 and adjusted from there. Motor was 67C or 157F after six minutes of racing including two warm up laps on a largish track. Laptimes were 16 sec plus.
Regards,
Calvin
Old 04-01-2011, 07:47 PM   #2600
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
With the Smokem link paltes on you certainly get more adjustment
The dual steering seems of little difference to me, overall the car is quite pleasing...might keep it for a while
Xray T4'17 - LRP - PF - Futaba - Muchmore
Brokin Racing is offline   Reply With Quote
Old 04-02-2011, 01:58 AM   #2601
Dusttt's Avatar
Trader Rating: 118 (100%+)
Check this
Schumacher Touring Car Big Bore Shocks With Springs and Ti Posts
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 04-03-2011, 01:43 PM   #2602
Hi
Can any one tell me what chassis plates will run out on Tarmac.
Currently I have installed the standart chassis plates.
In Germany, the outdoor season starts soon.
Since I`ve never been on the MI4cx Outside. Cann you give me then a few more tips.
Grettings Stefan
need not be
stefan Köhler is offline   Reply With Quote
Old 04-04-2011, 12:29 AM   #2603
lochness42's Avatar
Hi Stefan,
as car was designed on tarmac I guess it should be good out of the box with just minor tuning to your needs.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 04-04-2011, 08:16 AM   #2604
mr fit's Avatar
Its been awhile since I have been on the forum. Ive been searching for the front a arms (standard med flex and graphite) for the mi4, it seems that they dont make them any more. All I see is the short ones or the extra flex standard arms. Which ones should I use and what is the difference between the short and long a arms, how does it change the cars handling and what are the pros and cons. Any help would thankful.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 04-04-2011, 11:27 AM   #2605
SlideMasteR's Avatar
Originally Posted by stefan Köhler View Post
Hi
Grettings Stefan
Originally Posted by lochness42 View Post
Hi Stefan,
yip i must say have been running the cx for a couple of months now, all on outdoor asphalt tracks, bumpy and smooth tracks and the std decks work just fine, awesome cars !
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 04-05-2011, 04:44 AM   #2606
poochy's Avatar
Default preparing for the arrival
hi,
just trying to make sure i have everything before the mi4cx kit arrives in a few days.
should i buy hpi pro springs set or is there something else better (for springs)?
what else may i need that the kit lacks?
cant wait to run MOD on this car on our huge smooth parking lot track!
thanks
poochy is offline   Reply With Quote
Old 04-05-2011, 09:09 AM   #2607
CA
You can use the short arms, just add 1mm washer against the pivot block to retail the same overall width.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 04-05-2011, 05:32 PM   #2608
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Much more shock o rings
Hi all
Some were in this thread it was said that some people were using muchmore "o" rings in the shocks, what color "o" ring are you using.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 04-05-2011, 09:11 PM   #2609
poochy's Avatar
Originally Posted by Shev View Post
Hi, has anyone had trouble with the spur on the CX when running 17.5 no timing? I stripped every tooth off the spur almost instantly. I was running the spur on the battery side. I have since swapped it back to the motor side. I have heard of one other person having issues.
Thanks in advance.
shev, did you solve this?
Old 04-05-2011, 10:33 PM   #2610
Just run your spur on the motor side
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
