Old 02-14-2011, 04:13 PM   #2491
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Graham Kenny View Post
Im my eye's yes its a better car by far, the drivetrain is much more reliable and sturdy, the car itself is sharper, turns in better and seems to hold more corner speed. So its a YES go get one :-)
thanks, reordered it.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 02-15-2011, 03:21 AM   #2492
jackdani's Avatar
Cheers Martin, good to have you on board and congrats on the ETS win. Hopefully the first of many with the Mi4CX
think here the driver makes the difference!
winner with the yoko, also winner with the mi4...
congrats Martin!
- Team Durando DNX408 v2
- Alpha a852 Lutz edition
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
jackdani is offline   Reply With Quote
Old 02-15-2011, 05:15 AM   #2493
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Blog updated:
http://hofaaa.wordpress.com/
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 02-16-2011, 06:55 AM   #2494
Kurly's Avatar
Default Mi4CX
Hey Martin, great start to the year...Good luck. Is there a reason you went to the 2 post steering system other than the stock center post? Just curious....
L2Kracing, LeisureHours Hobbies & Raceway
Gizmo Racing USA, Motiv RC.
Kurly is offline   Reply With Quote
Old 02-16-2011, 06:58 AM   #2495
more aggressive and more onpower steering
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-16-2011, 09:10 AM   #2496
Martin,
Welcome on board and congrats for the weekend... Couple of quick questions if you don't mind about your setup;
Can I ask what difference the washers under the link washers make? I have been running my car with 1mm under the front and 0mm under the rear - what does it do adding more?
Droop for carpet - you ran 6 front and 5.2 rear so would roughly 5 and 4.2 be what you would expect to run for indoor carpet?
scoyle is offline   Reply With Quote
Old 02-16-2011, 09:28 AM   #2497
Hey all, thinking of picking up a Mi4CX for outdoor racing on medium to low grip asphalt (parking lot). Any recommendations on what extra things I would want for setup/spares? Looking at boosted 17.5.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 02-16-2011, 09:37 AM   #2498
qcrc's Avatar
I would look at getting the camber link plates, med flex c-hubs and possibly the med flex arms if the grip is low. Lots of people swear by the HPI springs as well. Swaw bar kits wouldn't hurt either.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 02-16-2011, 06:53 PM   #2499
I haven't driven a CX, just the LP. But here's what I've broken, in order of frequency:
- Rear Hinge Pin Pivot blocks... Get at least 1 spare set, or if you're sloppy, just go aluminum.
- Rear Inner Hinge Pin (same as front). Get at least 1 extra pair.
- Quik Klips (they tend to get lost when you break the rear arm / hinge pin block)
- Rear Arms (when running medium, haven't broken a carbon, but haven't run 'em as much)
- Driveshaft Blades
- CVD bones
- Servo arm (stripped stock one, and bent an aluminum one)... servo saver recommended
- Crappy stock aluminum turnbuckles
- Front C-Hub
- Rear Upright
- Wheel Bearings
-Mike
Old 02-17-2011, 12:14 AM   #2500
- Driveshaft Blades
- CVD bones
- Front C-Hub
- Rear Upright
- Wheel Bearings
-Mike
Can you provide references? U2231.....
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 02-17-2011, 12:51 AM   #2501
Benzaah's Avatar
Trader Rating: 21 (96%+)
I run 17.5 boosted, i've had my car 4 weeks and run 2 meets and Ive bashed it up pretty badly. Ive only have had to replace a bent rear hinge pin and heaps of screws including the Schumacher specific 2.5x4 screws that go into above mentioned hinge pins. Pain In the Ass if anything. Ive heard a lot of complaints about the bumper but my kit one is good not too soft not too hard. I wouldn't say its as tough as an xray but these cars can take a beating and ive had zero tweak issues from the chassis from any crashes ive had but found the bent hinge pin was wreaking havoc with my rear end. I've re ordered standard pins as ive heard that the TI ones will break instead of bend so anyone's thoughts on this is helpful. I am going to order the alloy pivot blocks as i want to mess with arm height anyway.
If i was you Id order some std castor blocks and keep all the arms kit as imo the medium arms create too much flex even on low grip asphalt. Low grip is all i have run the car on and With the 2mm chassis I think the graphite arms are the go but with a Thicker chassis it would be a different story. Id order the rear links and dont worry about the sway bars initially. Having messed with them a bit ive ended up back at std and the car is awesome with only a few shims added here and there. Youll need the 3131 shim kit and some narrow wheel hexs AS its mentioned earlier in this thread, the narrow hexs with either 2 or 2.5mm of shim on the front arms is best set up everywhere. I feel like ive wasted money on the medium arms and the sway bar kits but they will come in handy one day... I'd order most of the speed packs with screws, shims and washers etc.
If your serious about your racing youll have a list of spares you like to carry like belts, arms etc. Its almost easier to buy a second kit. I wish I could order a kit with a 2.5mm chassis and top deck with all graphite arms
Id also encourage anyone to rebuild their diff with the Hudy diff grease as I finally have what id call a butter smooth diff. The schuie grease builds a very stiff diff that I don't like.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 02-17-2011, 01:34 AM   #2502
Originally Posted by scoyle View Post
Martin,
There's just a certain window the geometry of a car should be in. And to be in that window which is front camberlinks exactly parallel to the wishbone, rear 0.5 lower on the inside, you have to run 2/1.5 if you run the rollcenter like I did or 2.5/2 if you run standard blocks OR 2.5/1.5 if the car is a bit too edgy to drive.
I pretty much run the setup VERY! similar to the setup I ran on the yokomo, as well as on Alex Stocker's HB.
There is a "basic setup" that seems to work on any car. Atleast this is what I found.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-17-2011, 01:35 AM   #2503
forgot to add that I ran narrow front hexes!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-17-2011, 10:44 AM   #2504
skypilot's Avatar
sorry, going to have to disagree on this one. the xray ,hotbodies ,tamiya guys around here are bugging me for schuie diff grease.
I have lots of schuie containers of grease, some are thick some are thin, the thick ones will get thin if you stir them.
Old 02-17-2011, 12:40 PM   #2505
JayBee's Avatar
Trader Rating: 31 (100%+)
I concur. I use Schuie's diff grease on every diff I build, including on my 1/12th-scales. And have for the last 6-7 years. I haven't found a grease that rivals it yet. And as Ritchie has mentioned, we've converted several drivers to the stuff Lemme build your diff....you'll never go back buddy
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
