Old 02-06-2011, 03:11 PM   #2461
Originally Posted by Double D Donuts View Post
Has anyone tried the litemodz CVDs yet? I'm looking to get rid of the nasty chatter from the front end.
Don't wast your time on them. They fall apart easily and have not been fixed despite being on their 3/4 revision no matter what some people might be saying . They wear the fastest i have ever seen a driveshaft wear. The company has appalling service. They don't dispatch stuff for weeks, even months in some cases and take no notice of customers asking, well anything!
Just buy the new schumacher steel shafts and spool or diff cups. Very little chatter and only on full lock( which far exceeds the cvd's limits). No sign of wear after a lot of practice and three/four meetings now. And the axles fit the bearings so 1.5 degrees of camber is that and not +/- 2degres of 1.5degress like some other companies.
YZFAndy is offline   Reply With Quote
Old 02-06-2011, 09:40 PM   #2462
Mine fell apart about 1/3 of the way through my first run. I still need to send them pictures and see if I can get a refund.
I just rebuilt my diff. I sanded the diff rings on 1500, like Chris's video, but I should have used a fresh piece of paper for the 2nd ring. I also used new balls, but kept the old spring washers. I also washed and scrubbed the pulley twice. I think I tightened it the way the video recommended... screw it in until it just engages the springs, then another half turn. It's much, much better. Nice and smooth, and doesn't slip. It still feels a little "thick" from all the grease, but it's smooth.
-Mike
Old 02-07-2011, 05:21 AM   #2463
Benzaah's Avatar
Trader Rating: 21 (96%+)
First serious run with the CX on the weekend and its very good considering we are breaking in a new surface coat on the track. Couple of questions.
I have a problem with the rear suspension. I am running the second hole from center on the shock tower and I wanted to run the shocks in the outside hole on the arm. With this configuration the ball cup on the end of the shock fouls the much more rim's I am using. My options are using another companies shorter ball end and cups and changing the geometry of the rear suspension or investing more money in Sorex tires on speed mind rims which do not foul and i cant really afford.
Would it be advisable to possibly take out 1mm of shim from the rear bulk head and add 1mm shim to the wheel hex to get me a little more clearance? Would this adversely affect my handling as it would shorten my camber links and possibly reduce rer toe i na touch. I was doing hand brake turns unexpectedly with the wheels rubbing and leaving the arm hole the same position and leaning the shock all the way in did not have the desired affect. Basically we are looking for a roll center change without investing in the alloy blocks to drop the arms in the rear. Any help is appreciated. Regards Benzaah.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 02-07-2011, 07:27 AM   #2464
NiMo's Avatar
I've not touched the diff on my MI4LP since I built it last August, and it is still silky smooth with zero slip.
Qualified 5th yesterday (after setting a new PB) and finished 2nd and 3rd in the two 13.5 finals, and that is running on used RP30 tyres someone threw away a few years back.
NiMo is offline   Reply With Quote
Old 02-10-2011, 12:24 PM   #2465
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
http://www.redrc.net/2011/02/martin-...to-schumacher/
Nice!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-10-2011, 02:50 PM   #2466
Danny-b23's Avatar
Originally Posted by BlackedOutREVO View Post
+1
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-11-2011, 02:19 AM   #2467
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Has anyone looked at the Spec-R gear diff range and found a diff that will take little work to fit to the Mi4-LP? I've seen a TOP diff fitted but takes to much work.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 02-11-2011, 09:21 AM   #2468
All the tamiya and xray diffs have like a 20-21mm bearing spacing, with the case going all the way out to the bearing on one side. The Schui diff is like 16mm bearing spacing. You could get a wider bearing spacing by flipping the eccentrics, but it still wouldn't clear the case on the diff, and I think the pulley might be in the wrong place. I was actually wondering about the Top u-pro one, because it's so much more compact.
Where did you see the Top one done? Any online how-to's?
-Mike
Old 02-11-2011, 03:11 PM   #2469
-Mike
A local racer did the mod. I can no longer remember how he did it, but it is starting to look like I need to find out again.
Old 02-11-2011, 03:21 PM   #2470
That would be nice. Please share details if you get them.
After I posted, I realize that you can't even flip the eccentrics, because if you did, the bearings would slide out. :/
-Mike
Old 02-11-2011, 05:57 PM   #2471
Graham Kenny's Avatar
Spec R Tamiya Gear diff, With tamiya shafts and tamiya front pulley, a fella in the UK done this mod last year
Team Schumacher UK - GM Racing - TIR - Boultspeed RC Paint
Graham Kenny is offline   Reply With Quote
Old 02-11-2011, 07:44 PM   #2472
Benzaah's Avatar
Thats a real Bitsa. Xray ball cups and tie rods and looks like xray sway bars as well.
Cant wait for my next session with this car tomorrow.
Adelaide RC
Walter Rc Hobby
Old 02-11-2011, 09:00 PM   #2473
I ran a Top gear diff in mine. Had to grind some ofthe casing away to make it fit. Bolted a schuie pully to it.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 02-11-2011, 09:25 PM   #2474
Is that the TA-05 Spec-R gear diff? Do you know what mods need to be done?
That was it, turn down the casing and change pulley. Did it work well for you? Did you find what weight (cst) oil worked best?
Old 02-12-2011, 07:11 AM   #2475
Im not sure what diff it is other than a Spec-R The front Spool pulley had to be changed too which changed the internal ratio, and i dont think there Xray ball studs, there just drilled out schumacher ones
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
