Old 08-20-2010, 09:49 AM   #2131
picco007's Avatar
Trader Rating: 82 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
You should be able to get parts at stormer hobbies or amain.
EA Motorsports
picco007 is offline   Reply With Quote
Old 08-20-2010, 10:45 AM   #2132
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I would first check stormer as a-main's prices on certain parts can be much higher. Also order direct from Schumacher at racing-cars.com.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 08-20-2010, 12:46 PM   #2133
Yeah, stormer's prices on what they have are usually better than A-Main, but A-Main seems to have a lot more stuff.
I'm a bit sketched out on ordering direct from Schumacher since all the illegal charge problems.... Maybe it's all sorted out with the new payment processing. I haven't needed anything I couldn't find at stormer or A-Main yet, though.
-Mike
Old 08-21-2010, 03:34 PM   #2134
FK05 lover's Avatar
Trader Rating: 147 (99%+)
+ 1 Stormer
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 08-24-2010, 05:51 PM   #2135
FK05 lover's Avatar
Gave the new car it's first run today, impressive on low grip for sure
Old 08-24-2010, 11:20 PM   #2136
Originally Posted by grippgoat View Post
1/8" hardened tool steel rod is pretty cheap. Has anyone tried just making their own hinge pins? It seems like you could just cut it to length with a dremel, then chuck it into a drill and spin it with some fine-grit sandpaper or metal polish or something. Maybe I'll give it a shot.
So, I gave it a shot. I got some 1/8" weld steel rod at the hardware store for <$5.00.
I used a dremel with a carbide cut-off wheel to cut the pieces. Getting the length just right was tricky, because the wheel was smaller than the dremel, and I had to cut at a bit of an angle. The results were between 54.5 and 55.7mm.
Once I cut the pieces to length, I chucked them into a drill (you could also chuck it into a dremel). I then spun up both the drill and the dremel and put the side of the wheel into the end of the pin, to flatten it and remove some length if needed. Then I went at a 45 degree angle to taper. Flip the pin and repeat. I think some kind of a stone would work better with less chance of exploding the cutoff wheel (I didn't explode it, but I was a bit nervous). I tried a sanding drum, but it wore out too fast.
Once the ends were tapered, I took a piece of 80 grit sandpaper, folded it in half, and stuck the pin on the inside of the fold (still in the drill). I ran it up and down till the finish was bright, but still rough. I then did the same thing with 1500 grit to get a smoother finish. Flip the pin in the drill and repeat.
The results will be useable, but not especially pretty. They fit too tight in the carbon front arms, but were nice and easy in the used medium rears. I bought an arm reamer to sort that out. More time with the 80 grit can adjust the fit, but I'd rather ream the arms, I think. The fit would also probably be better with a higher-quality steel with a better tolerance.
I also found that www.mcmaster.com has 1/8" x 2-1/4" steel dowel pins. About $7 for a pack of 5. You'd have to remove about 2mm from the end of it, though. Removing 2mm with my tools would be a pain. Also, that's not that much cheaper than the real ones from schumacher.
It took me about a half hour to do the first one, just kind of figuring out the process. Then I was able to do 3 more in about 30 minutes. If I had a die grinder or an angle grinder, it would probably go much faster.
-Mike
Old 08-27-2010, 09:46 PM   #2137
fycheong's Avatar
Send a message via Yahoo to fycheong
Originally Posted by RL.2002 View Post
Hy, jst wanna to know where do you guy find your parts?
Direct online order from racing-cars.com
fycheong is offline   Reply With Quote
Old 08-27-2010, 10:51 PM   #2138
skypilot's Avatar
Trader Rating: 14 (100%+)
anyone interested in buying a Mi4lp with lots of extras let me know, alum hinge pin holders (team tamale ones with the hinge pin) twin link steering system, 3mm top deck, arms, hubs, (stock and alum 1*) camber link plates in all three sizes.
so cheap they won't let me advertise it. PM me.
USA ONLY
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 08-31-2010, 08:25 PM   #2139
skypilot's Avatar
heres some pictures, I gotta find the 3mm top deck, misplaced it somewhere. car has the grey belts on it, comes with two rear black belts and one front black belt. the hinge pins aren't in the pictures, but I have them. If I told you, you were in line, you are now at the top of it, first one that says I'll take gets it for the price I gave you. all of it. in the picture it shows one set of 4* front c hubs and two pair of 6* in case you were wondering, rear arms are all medium one set of shorts one set of longs, fronts are med short and CF long
Schumacher Mi4-001.jpg   Schumacher Mi4-002.jpg   Schumacher Mi4-003.jpg   Schumacher Mi4-006.jpg   Schumacher Mi4-004.jpg
Old 09-01-2010, 06:17 PM   #2140
WildManDriving's Avatar
Trader Rating: 27 (100%+)
Hello All, Is there a gear diff for the Mi4/LP?
Thanks,
M.E.
WildManDriving is offline   Reply With Quote
Old 09-02-2010, 01:14 AM   #2141
lochness42's Avatar
Thanks,
M.E.
Not yet. There are plans on making them, though hard to say when they will be really available.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 09-04-2010, 11:04 PM   #2142
picco007's Avatar
Okay guys, I'm in need of a better front bumper for my mi4 lp. Does anyone make a lower bumper ( bottom piece) out of Kydex? or something like that? Also what bumpers are being used out there? I have the Parma bumper but it seems soft and hasn't really helped recently. Can anyone give me some tips on what to do to help make the front end more stronger?
Thanks.
EA Motorsports
Old 09-04-2010, 11:10 PM   #2143
Bobert Ross's Avatar
Losi bumpers are good but you gotta cut them out to fit. I use a parma bumper that is hard as a rock. If i had still been using the stock ones, i would have gone through 3 or so in the same amount of time.
ROAR# 1-121732
Bobert Ross is offline   Reply With Quote
Old 09-04-2010, 11:21 PM   #2144
USA ONLY
PM sent...
ROAR# 1-121732
Old 09-04-2010, 11:48 PM   #2145
MikeXray's Avatar
Trader Rating: 72 (100%+)
Thanks.
You can drill new holes in the one specialized makes for the Phi, I ended up making my own from that template.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
