Old 07-22-2010, 02:35 PM   #2041
abailey21's Avatar
Trader Rating: 35 (100%+)
I appreciate the kudos guy's, let's hope the medical field is as nice to me as all of you guys
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-22-2010, 05:46 PM   #2042
Danny-b23's Avatar
Originally Posted by zleader_99 View Post
I have been trying different posted set ups. I Running a MI4lp and MI4. Both my cars have the alloy pivot blocks. If a set asks for setting based of the standard blocks how do I change my alloy blocks set up to reflect it.
Is there a conversion chart that I have missed?
I assume 2mm is a tarmac chassis and the 2.5 is carpet?
Well, the 2mm chassis is the "rubber tire chassis" but on really high traction carpet surfaces like at the Snowbirds or IIC a lot of guys are switching to the 2.5mm chassis to free up the car. For low traction club racing, the 2mm is the way to go, but if your track has a major groove, you might be better off with the 2.5mm.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 07-22-2010, 05:54 PM   #2043
Send a message via MSN to clintscreations Send a message via Yahoo to clintscreations
I don't know if any of you seen the mi4 lp test in the august issue of rc car action, but if you did and would be interested in purchasing the body drop me an email..... clintscreationspaint@yahoo.com
Asking $80 shipped shipped to any where in the lower 48 united states
Adam.....glad your landing on your feet.....you still thinkin of comin to kc in august?
airtronics radios - www.airtronics.net
checkered flag raceway - www.cfrkc.com
hobbytown north - gladstone, mo
kcrc - shawnee, ks
Last edited by clintscreations; 07-22-2010 at 06:20 PM. Reason: brain not working right
clintscreations is offline   Reply With Quote
Old 07-26-2010, 08:06 AM   #2044
Will the spool from a Mi4 fit the Mi3.5?
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 07-26-2010, 08:40 AM   #2045
MikeXray's Avatar
Trader Rating: 72 (100%+)
Yes
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-27-2010, 01:32 AM   #2046
On Saturday, I ran the dual-link steering with 2mm spacers under the cross bar, and it seemed to work OK. But at the end of the day, I got the hole counter-sunk, so the spacers are off now.
Does anyone know the spacer configuration for the alloy suspension blocks that give the same geometry as the plastic ones? I only installed one side on the front so far. I used 1mm between the upper and lower block, and the stock 2.5mm between the upper block and bulkhead, and things look pretty close (I've only installed one side so far, so I was comparing to the other side). But I don't really have a way of measuring more precisely.
Also, now that I've got the front apart, I'm noticing that my front swaybar is pretty tweaked. When I push up on one side, it lifts the other almost the same height. If I push the other side up, it barely lifts the first side. I had previously noticed the same thing in the rear, but I've ripped off the left rear a couple times, so it wasn't surprising. The front has never been wrecked like that, though. Is swaybar tweak pretty common?
-Mike
Old 07-27-2010, 01:35 AM   #2047
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Yes, swaybar tweak is very common, especially if you have torn off a side. Easy fix though, just keep bending back while checking on your tweak board or piece of glass. Even check and fix new sway bars.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 07-27-2010, 08:09 AM   #2048
mihy's Avatar
does the rear belt of the mi4 fit the mi2?
mihy is offline   Reply With Quote
Old 07-27-2010, 08:19 AM   #2049
1mm between blocks in the front and 2mm between blocks in the back. The hole on the bulkhead is 1mm higher on the bulkhead in the rear.
JoelV is offline   Reply With Quote
Old 07-27-2010, 05:51 PM   #2050
skypilot's Avatar
Trader Rating: 14 (100%+)
-Mike
what he said about the block spacers, and by front and rear he means the front of the car and rear of the car, not front and rear of the hinge pin. and the bulk head spacers are your choice, if you 2.5 with the plastic then use 2.5 with the alum. I don't usually run sway bars for that very reason,
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-27-2010, 05:55 PM   #2051
skypilot's Avatar
Mi4 rear belt part # is U2721 and it says on the header card... rear belt, black narrow - Mi2.
so I'm gonna say yes,
just a fyi the front Mi4 belt part # 3011 header card says.... Front belt 171T x 3.6mm - Mi-2 EC
hope that helps
Old 07-27-2010, 10:59 PM   #2052
mihy's Avatar
i know its kinda obvious but i was hopen sum one had done the belt swap and if there were any issues, anywho i will order 1
Old 07-28-2010, 01:31 PM   #2053
Default mi4lp
I used to run a schuey back in the SST days and i loved it.
I recently got a new Mi4lp.
Who's running these and why isn't everyone saying these cars are great?
Sterling Racer is offline   Reply With Quote
Old 07-28-2010, 01:33 PM   #2054
I'm not talking about it so much because I do not have any problems to resolve. It was easy to setup, easy enough to work on, and puts a smile on my face every time I pull it out of my pit bag.
Is that a good enough answer?
Old 07-28-2010, 01:35 PM   #2055
Owen RaCing's Avatar
Nobody is saying they are bad, but a majority of the drivers that ran Schumachers in america 6 months ago don't run them anymore due to the USA distributor closing down.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
