Old 07-02-2010, 05:52 AM   #1996
Danny-b23's Avatar
Originally Posted by skypilot View Post
the difference between a 6.5 and 21.5 on MY scale is 2.835 grams. that sliverr of lead would have to be placed on the outside of the lipo across from the motor to get the equal "swing balance. which I would think is more important then static balance. isn't it? heck I don't know, and I usually don't worry about it.
Are they the same brand of motor? Same rotor size? Just from a 17.5 to a 13.5 on my scale is like 8 grams.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 07-02-2010, 11:14 AM   #1997
skypilot's Avatar
Trader Rating: 14 (100%+)
both Speedpassion motors, rotor size is whatever they came with, maybe I just need a new scale, it is a few years old
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-03-2010, 12:13 AM   #1998
Originally Posted by grippgoat View Post
Does anyone know if the Lunsford Punisher ball cups fit the Schumacher balls?
Answered my own question... they don't fit. They're close, but they're loose, and add slop to the steering.
Another question: do the axles (not the bones, but the axle that sticks out of the bearing and has the hex on it) ever bend? I've got some wobble in my left front wheel, and it looks like the tip of the axle is wobbling, too. I should probably stop crashing it.
-Mike
Old 07-06-2010, 03:26 PM   #1999
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I haven't bent dogbones or axles, but that's not to say it can not happen. Take yours apart and see if you bent it. On my old car (TC5), when I had a wobbly wheel it was because I bent the rim, or the hub got play where the bearings mount.
Just got the new body support/shock tower and dual bellcrank in. I do like the body support shock tower. The dual bellcrank is very nice, however I have already shoegoo'ed my BLS551 servo to the chassis, so that will be a no-go. One must flip the servo 180 so that the arm is on the outside. I think I will end up buying another chassis and servo to test it out rather than undo the servo.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 07-06-2010, 06:08 PM   #2000
FK05 lover's Avatar
Trader Rating: 147 (99%+)
so, if & when might we see a Mi5???
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 07-07-2010, 01:16 AM   #2001
Hopefully not soon. I feel that the Mi4lp but with the Mi4 chassis is just about perfect.
Old 07-07-2010, 04:49 PM   #2002
Dusttt's Avatar
Trader Rating: 121 (100%+)
selling my spare MI4 LP pro
Schumacher MI4LP Pro for sale cheap!
Dusttt is offline   Reply With Quote
Old 07-07-2010, 08:18 PM   #2003
JayBee's Avatar
Trader Rating: 31 (100%+)
I wish I could....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-09-2010, 04:45 PM   #2004
Dusttt's Avatar
Default for sale
Sellling My main Mi4LP Pro too cheap!!
Schumacher Mi4LP PRO plus extras. Must See!!!
Old 07-10-2010, 08:46 AM   #2005
Dusttt's Avatar
Its still there
Old 07-11-2010, 10:56 AM   #2006
Heri W.'s Avatar
Default problem by the world`s
hy chris,
can you tell us what was the problem by the worls`s.
was it the car - or the setup - witch problem????
thanks
heri
Heri W. is offline   Reply With Quote
Old 07-11-2010, 12:11 PM   #2007
Trader Rating: 20 (100%+)
Default arm lenght vs handling
I have been using Kenny Lamberts base set up for tarmac and carpet. His set up uses the long rear arms with short fronts.
My question what affect does the length of the arms play in the handling. I see most setups use the short all way around.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 07-11-2010, 12:25 PM   #2008
This is what I have found for my driving style. Short arms/ front and long arms/ rear: the car rotates better mid corner. Long arms/ front and short arms/ rear: tightens the rear end up on power on mid corner to exit.
I normally use short arms front and back and then use .5mm and 1mm shims on the hexes to adjust width. Because track changes as the day goes on.
Hope this helps.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-12-2010, 04:34 PM   #2009
THE HUNTER MKII's Avatar
Questions??
I have a question .
What does having the front arms swept back do ( i have a 1.5 shim in the front , stock 1mm )
The man who smiles when things go wrong has thought of someone to blame it on.
THE HUNTER MKII is offline   Reply With Quote
Old 07-14-2010, 09:15 PM   #2010
I got to use both the new dual bellcrank and body post mount. The body was much more solid at high speed, and the bellcrank had close to perfect steering characteristics for my driving style.
The steering was buttery smooth, and the car would dive deeper into the corners and keep railing out with increasing steering. I was able to steer more proportionately in the corners rather than full lock to full lock. I did not play with the ackerman though, I left it on the the outer middle hole and front most hole on the bellcrank. Still lacked a touch overall cornerspeed, but I think I know the changes I have to make to make that progress.
Here's how I have it installed and please excuse the dirty car:
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
