Old 06-17-2010, 03:54 PM   #1966
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
IF YOU HAVE PURCHASED FROM SCHUMACHER UK, CHECK YOUR CREDIT CARD FOR CHARGES THAT SHOULD NOT HAVE BEEN MADE FROM UNKNOWN COMPANIES.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 06-18-2010, 06:56 AM   #1967
excuse the dumbness, but where do you put the 1mm shim between camber link and bulkhead ?
need more rear end grip ?
finch is offline   Reply With Quote
Old 06-18-2010, 07:11 AM   #1968
Dusttt's Avatar
Trader Rating: 121 (100%+)
Sounds like another victim. Sorry to hear that bro they got me for just over $800 after all was said and done.
Dusttt is offline   Reply With Quote
Old 06-18-2010, 09:09 AM   #1969
lochness42's Avatar
Easy as:
screw
countersunk washer
camberlink bracket
1mm washer
bulkhead
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 06-19-2010, 08:13 AM   #1970
Thanks i catch your drift now !
Old 06-20-2010, 11:30 AM   #1971
Car was still poor on friday !
Spent saturday rebuilding the diff and doing some adjustments including 1mm washer on bulkhead.
also notices i only had 1.5mm washers on screw blocks up front, increased it to 2.5mm and also put my kwik clip in the front of the wishbone on the rear to give longer wheelbase.
So much more drivable now,
Hopefully i can dial my driving skills now i seem to have abit more rear end grip now.
need abit more straight line speed now, seem to be struggling on mode 6 with the spx with 10.5 x12 compared to the guys running the latest GM speedo's
Old 06-24-2010, 12:10 PM   #1972
RC MARKET's Avatar
Arrived 2.5mm Ceramic Diff ball $5/12pcs
RC MARKET is offline   Reply With Quote
Old 06-24-2010, 01:07 PM   #1973
MikeXray's Avatar
Trader Rating: 73 (100%+)
An SPX will not be able to keep up at any setting, the other speedos are just that much better.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-28-2010, 01:58 AM   #1974
I noticed the price on the Mi4 LP Pro is down to $399 on A-Main. I wonder what's up with that.
Does anyone know if the Lunsford Punisher ball cups fit the Schumacher balls?
How sensitive does the the Mi4 tend to be to front/rear weight distribution? More specifically, if I have a choice between an 85T spur and 38T pinion, versus a 70T spur and 31T pinion, should I go with the bigger gears to keep the motor more forward?
FYI, if anyone cares, the ProTek RC 2S 5600/50C lipo barely sneaks in under the front bulkhead. The corner of my pack is getting scratched a bit. I think I'm going to file the bulkhead just a wee hair so it's not so sharp.
I noticed today that the front track width is noticeably wider than the rear. Is that why Ritchie and some others like the narrower front hexes, and while that factory driver (too lazy to go find his name a few pages back) is using the longer rear arms? What is the length difference between the normal and short rear arms?
On my Mi4 LP Pro, the chassis has a second set of countersunk holes for mounting the servo. They're farther back, and more inboard. However, the aft hole on the 2nd set is more inboard, instead of more outboard like the normal holes. It looks like I could sneak my servo in that way, and definitely could sneak in a low-profile, but I can't figure out a way to make the kit servo mounts work that way. The one with the slot would need to be mirrored from the way it is. Am I missing something obvious?
I feel like I want a bit more rotation at all stages of cornering, but mostly under neutral/light throttle, and corner exit. But I don't necessarily feel like I want more front end bite. Exiting tight corners, I kind of have to goose the throttle to get the rear end to kick around, rather than just smoothly applying throttle. Also, on infield decreasing-radius corners, I feel like I have to completely let off the gas, maybe even touch the brake, to get the car turned, and that there's a point coming off throttle where the steering gets much more reactive, and hard to predict. I feel like it should be possible to just ease off the throttle and turn the car in smoothly. I kind of feel like less rear toe-in might do what I want. Does that sound reasonable?
-Mike
Old 06-28-2010, 11:15 AM   #1975
jhock's Avatar
What are you guys doing about the fradulent charges? It just happened to me!
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 06-28-2010, 01:09 PM   #1976
skypilot's Avatar
Trader Rating: 14 (100%+)
-Mike
what are you using for Tires/traction compound
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-28-2010, 07:49 PM   #1977
rezenclowd3's Avatar
Send a message via AIM to rezenclowd3
Oooh just saw these today on the RC Car Action forum:
Just had to order both from Schu UK since its not at Amain or Stormer yet. Mainly been wanting the windshield body post for awhile now.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 06-28-2010, 10:03 PM   #1978
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Hi Guys, got myself a MI3 (as new) recently & gave it a run in 540 at club level & scored fastest lap at both meets against some very capable guys
Question I have for you, is there any benefit going to MI4LP-Pro? I will be using it for stock soon & we race on a low grip concrete surface at night.
Also, do any parts cross-over from MI3 to MI4?
Thanks in Advance..
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 06-28-2010, 10:32 PM   #1979
Tires: Sweep EXP 36 http://www.sweepracingusa.com/produc...products_id=29
Sauce: Sweep X3 http://www.sweepracingusa.com/produc...roducts_id=135
-Mike
Old 06-28-2010, 10:33 PM   #1980
Oooh, is that a dual bell-crank steering setup?
-Mike
EDIT: Removed the picture quote.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
