Old 06-01-2010, 04:43 PM   #1921
Danny-b23's Avatar
Originally Posted by skypilot View Post
non sense
Gratz on getting your Mi4 into the A-Main at the Reedy.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 06-04-2010, 05:37 AM   #1922
Any advice on how to increase rear end grip. running shocks in middle postions at the moment with the standard shcumacher white and blue springs.
Its really loose on the rear end and almost undrivable, any quick changes i can do for tonight. i have the other schuey springs, its a low grip tarmac track.
im running 45 wt oil all round at the moment.
finch is offline   Reply With Quote
Old 06-04-2010, 06:03 AM   #1923
Graham Kenny's Avatar
Maybe soften up the oil all round down to 35wt all round, scheuy white or HPI Blue's front and back. lay the rear shocks all the way down, 1mm shim between camber link and bulkhead
Team Schumacher UK - GM Racing - TIR - Boultspeed RC Paint
Graham Kenny is offline   Reply With Quote
Old 06-04-2010, 08:53 AM   #1924
Jochim_18's Avatar
Shorter wheelbase makes your car rotate better and faster on the APEX. Less Toe in on the rear, Lower Roll Center gives you rear traction.
Originally Posted by MikeXray View Post
I need my car to rotate on power,. I drove a friends car and could throttle steer it a bit, I am going to try a tighter rear diff as I run it pretty loose, what else is good to try?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-06-2010, 12:51 AM   #1925
JayBee's Avatar
Trader Rating: 31 (100%+)
With everyone seemingly wanting to get into the gear-diff rage, does Schuie have anything up their sleeves?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-06-2010, 10:11 AM   #1926
The Bear's Avatar
Hey buddy, try laying the shocks down in the back, slip a half mm shim in the very rear toe block to increase rear toe (which INCREASES rear bite). You could also try a smidgon more droop in the back as well.
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 06-06-2010, 10:12 AM   #1927
The Bear's Avatar
What you talkin' bout' Willis?
Old 06-06-2010, 10:43 AM   #1928
Thanks will try this and see how i get on.
Old 06-06-2010, 03:11 PM   #1929
Default Tamiya steel driveshaft for TIR spool?
Hi
I've seen talk on this thread about tamiya 46mm steel drive shafts fitting the TIR spool, this is something I'd like to try as the TIR shafts have been breaking far too frequently.
I've looked around the net and can't determine which driveshaft I should get from tamiya, can anybody give me a part number of a shaft that will fit.
Markeo is offline   Reply With Quote
Old 06-09-2010, 12:19 PM   #1930
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
not to be a chump, but in case any loyalists would like dibs ...
schumacher mi4 roller - black/polished
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 06-09-2010, 02:51 PM   #1931
JayBee's Avatar
Double post
Old 06-09-2010, 02:54 PM   #1932
JayBee's Avatar
http://www.egrracing.com/shop/index....keyword=spr009
Old 06-09-2010, 04:16 PM   #1933
hanulec's Avatar
Trader Rating: 23 (100%+)
are you jumping ship Chris??
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-10-2010, 02:19 PM   #1934
hana166's Avatar
Originally Posted by Markeo View Post
Hi
53847
7 months and they're not even bent
You can drill the Schumacher hex and shim out to fit
I drilled the rear TIR shafts and hex also its much more reliable
hana166 is offline   Reply With Quote
Old 06-10-2010, 04:15 PM   #1935
Dusttt's Avatar
Trader Rating: 115 (100%+)
So I have a messed up story for you. About a month ago I ordered some parts direct from schumacher online with my debit card. Then last week someone is all over GB spending my money and it wasnt me. I never bought from GB before so just a coincidence?
Dusttt is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 04:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 11:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 01:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 02:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 11:14 PM
SEO by vBSEO 3.5.0
