Old 05-25-2010, 06:30 PM   #1906
Schumacher Mi4 with huge parts lot for sale.
Schumacher MI4
duckman996 is offline   Reply With Quote
Old 05-29-2010, 10:04 PM   #1907
Damit's Avatar
Trader Rating: 22 (100%+)
Default Gear Diff
Does anyone know if Schumacher or an after market company will release a gear diff for the Mi4LP?
B6d 2wd / B64d 4wd - SJF01 Street Jam F1 - Tamiya Mini v2
Futaba-HW-LRP-Lunsford-Reedy/Associated
South Australian Member: AERCCC #16 and ARCR 9098
Damit is offline   Reply With Quote
Old 05-30-2010, 11:49 AM   #1908
Danny-b23's Avatar
I'm thinking that if they don't think the car needs it, Schumacher won't develop it. And really, no car NEEDS it. More of a convenience thing with what guys are doing right now.
Aftermarket, maybe.
Which ever it is, I'll be all over it.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 05-30-2010, 05:48 PM   #1909
MikeXray's Avatar
Trader Rating: 73 (100%+)
I need my car to rotate on power,. I drove a friends car and could throttle steer it a bit, I am going to try a tighter rear diff as I run it pretty loose, what else is good to try?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-30-2010, 05:53 PM   #1910
Danny-b23's Avatar
You could also try standing up the rear shocks one or two holes.
Danny Buck
Old 05-30-2010, 06:02 PM   #1911
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Also, if you need more on-power steering in general, decrease your front droop. I'm guessing you want to lose a touch of rear traction though, not gain front?
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 05-30-2010, 06:53 PM   #1912
MikeXray's Avatar
I couldn't say for sure until I drove the car, I don't want it twitchy, it could use more overall steering, but I'd like to work on one aspect at a time. This layout had a few hard braking sections, I could get into the turn, but not out of the tight 180s.
Old 05-30-2010, 07:19 PM   #1913
jdm19turn's Avatar
The old track layout at my local track had several 180's on it and I used the 1 deg rear hubs so I could free the car up while still keep the same rear toe so the rotates better from there I adjust the rear trans links for more or less rear traction/rotation I'll be glad to look for my setup sheet give you a copy if you would like .
Joey
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 05-30-2010, 07:36 PM   #1914
jhock's Avatar
Run only 1mm or less of droop in front. Measure this by lift method over ride height. Doing this will have a huge impact over handling, messing with anything else like shock position camber links and so on have minimual effects on RC cars
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 05-30-2010, 09:14 PM   #1915
Joey, I ran 1mm of front droop at the race. I will email you my two setups that I have used at the track so far. Both has good turn in and rotation. One I think is better.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 05-31-2010, 08:04 PM   #1916
congratulations to jeff maurer and ritchie reynolds for thier great driving at the reedy race of champions! ritchie, (sky pilot) qualified 7th in the A main in 17.5 class. he finished abouth 7th or 8th, but only because he couldnt catch a break,,,,(what a mauling),,,sky pilot was in the B main in open mod. Jeff, (racer-x) qualified 7th in the B main in the 17.5 class. the cars, MI-4rs, were really hooked up.
gdcopbdcop is offline   Reply With Quote
Old 05-31-2010, 08:13 PM   #1917
JayBee's Avatar
Trader Rating: 31 (100%+)
It would've been really cool to see a couple more of Schuie's asphalt assassins out at the Reedy to give those guys more support With several phone calls back and forth, we got Ritchies' cars working pretty good, especially the 17.5 car. His mod car was no slouch either, but I think everyone was playing "tag, you're it!" with the orange Schuie...
JayBee is offline   Reply With Quote
Old 06-01-2010, 06:31 AM   #1918
MikeXray's Avatar
Shock position makes a huge effect on these cars, are you nuts? I started out with a 2nd car with a different setup, the biggest change that I had to undo was running the rear shock stood up one hole in the tower and in one hole on the arm, it made the car undriveable. I have not run as low as 1mm droop up front on asphalt, I can give it a try.
Old 06-01-2010, 06:40 AM   #1919
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Your cars ran real good this past weekend Steve. They looked real happy out there.......... And your right about droop settings. I ran 1mm in the front and 2mm in the rear and the rotation got real good in my Losi, especially late in the day.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 06-01-2010, 12:58 PM   #1920
skypilot's Avatar
Trader Rating: 14 (100%+)
non sense
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
