Old 05-03-2010, 12:56 PM   #1846
Does the battery fit on the mi4?
http://www.r2hobbies.com/eng/proddet...od=rcve3301002
thrilos is offline   Reply With Quote
Old 05-03-2010, 01:23 PM   #1847
rc-racer-kirby's Avatar
Send a message via MSN to rc-racer-kirby
Originally Posted by thrilos View Post
Avoid these cars! They are cheep rip-off clones of the Schumacher Mi4!
Schumacher UK - Lite Modz - Gingapaint
Schumacher Mi4LP - Nosram Matrix Evolution Spec Racing, Speed Passion V3.0, GM 5400 50C, Savox 1251MG, Futaba 3GR 2.4ghz, TiR Screws, TiR CVD's, TiR Layshaft, Ti Turnbuckles.
rc-racer-kirby is offline   Reply With Quote
Old 05-03-2010, 01:42 PM   #1848
Kenny L's Avatar
Trader Rating: 16 (100%+)
Finally settled down to a solid base setup here you go
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 05-03-2010, 02:19 PM   #1849
Hi Kenny,
Why do you use always long rear arms ??
It's to have more traction ? Because I see on your setup sheet thats it's a high grip track...
Regards,
Manu
Manu_05' is offline   Reply With Quote
Old 05-03-2010, 02:20 PM   #1850
And also, medium arms...
Old 05-03-2010, 02:34 PM   #1851
Kenny L's Avatar
Originally Posted by Kenny L View Post
I'm running med flex ones like the rear bite they give me. Not big fan of rear shorts for carpet because the shimming needed to make width makes weaker around bulkhead and hinge pin mounting area. I rather break an arm not pivot blocks or bulkhead screws in bulkheads but thats just me
here you go sir
Old 05-03-2010, 04:53 PM   #1852
Mike Haynes's Avatar
Even on a high bite track it is very helpfull to have a stable planted car, just make it steer another way
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-03-2010, 05:23 PM   #1853
MikeXray's Avatar
Trader Rating: 72 (100%+)
Car needs stiffer rear springs
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-03-2010, 09:27 PM   #1854
heavyjeffd's Avatar
Trader Rating: 14 (100%+)
Sup fellas.
I'm about to pick up an Mi4LP and have a few questions:
Bodies: what are you guys running/what do you recommend?
Tires/Wheels: any preferences for asphalt/parking lot tracks?
Batteries: I figured most hardpack 2S lipos (ie: Reedy) would fit, do any actually snap into those chassis holes?
I'm going to be running this in a 17.5 class at a local hobby shop, any recommendations for gearing?
Thanks in advance.
heavyjeffd is offline   Reply With Quote
Old 05-04-2010, 11:08 AM   #1855
Kenny L's Avatar
Reposted with edits
Old 05-04-2010, 12:39 PM   #1856
Hi Kenny,
Regards,
Manu
Old 05-04-2010, 01:47 PM   #1857
Kenny L's Avatar
I'm running med flex ones like the rear bite they give me. Not big fan of rear shorts because the shimming needed to make width makes weaker around bulkhead and hinge pin mounting area. Its seems to be fine line of rear bite and steering with the car which I find the rear longs seem to be planted where the shorts rotate to much for me making car unstable mid run. Med flex 1st durability factor then add carbon as less flex is needed.
Old 05-05-2010, 10:06 AM   #1858
Send a message via ICQ to MattW
We run 1mm of spacers against the plastic blocks with short arms in virtually all of the UK team, so no problems there.
MattW is offline   Reply With Quote
Old 05-05-2010, 10:16 AM   #1859
Okay so this is gonna sound weird but my car is set up pretty, well really good with just a base set up. I'm running outdoor asphalt on a large track and the car handles really well. 2* camber all around, stock roll center spot, no sway bars, stock springs and the biggest change ive noticed is playing with different tires.
now I'll admit I'm not great when it comes to trying different set ups because if something works, why change it? To go with that i dont know what to adjust to pick up more speed. the one thing i'm mostly looking for is mid-exit cornering. I run a spool up front with a diff in the rear and I like the way it flows but would like to see it rotate a little more . Am i only going to get that by going with a differential up front? What about more caster or Ackerman?
Double D Donuts is offline   Reply With Quote
Old 05-05-2010, 10:34 AM   #1860
MikeXray's Avatar
1mm is fine, on carpet its more like 4mm.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
