Old 04-06-2010, 09:45 AM   #1771
Dusttt's Avatar
Trader Rating: 118 (100%+)
Originally Posted by seaball View Post
the short-c/f arms come with the lp.
u3549 front
u3550 rear
the short arms are way stronger because the webbing is beefed up. i would call any of the standard length arms obsolete at this point. they'll run fine, but they are brittle unless you run the medium flex versions, which have tons of flex.
stick with the above. if you're breaking them, you can go with the short-med flex versions.
u3551 front
u3552 rear
Thanks !!!
Dusttt is offline   Reply With Quote
Old 04-09-2010, 11:05 AM   #1772
Kenny L's Avatar
Trader Rating: 16 (100%+)
Now we are talking about arms here is setup I have been playing with last few weeks. Uses long arms in rear
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 04-09-2010, 12:53 PM   #1773
MikeXray's Avatar
Trader Rating: 73 (100%+)
Kenny what flex compound are you running?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-09-2010, 01:16 PM   #1774
Kenny L's Avatar
I'm running med flex ones like the rear bite they give me. Not big fan of rear shorts for carpet because the shimming needed to make width makes weaker around bulkhead and hinge pin mounting area. I rather break an arm not pivot blocks or bulkhead screws in bulkheads but thats just me
Old 04-09-2010, 05:45 PM   #1775
Jochim_18's Avatar
Anyone here knows where I can get MI4LP setup sheet in PDF format that I can edit and save?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 04-09-2010, 06:05 PM   #1776
http://www.racing-cars.com/search.as...e1=prodvalue14
JoelV is offline   Reply With Quote
Old 04-09-2010, 06:26 PM   #1777
Jochim_18's Avatar
Thanks...
Old 04-09-2010, 07:03 PM   #1778
MikeXray's Avatar
I see it now on the sheet, I check the screws often to make sure their not bent, for asphalt I tend to run the car narrower anyway.
Old 04-11-2010, 01:00 AM   #1779
Thanks for setup Kenny, is there some interesting ideas, this for low grip?
I think to test, in small, low grip asphalt track. I see similar things to our asphalt setup.
I have a good base setup, for long, medium grip asphalt tracks.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-11-2010, 08:00 AM   #1780
I'm going to set my car up narrow this year. I always ran the Mi3 wider. Not sure if I'm going to put the car back to the LP for Jackson or put the 2.5 mm regular Mi4 chassis on it. See you in 2 weeks.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 04-11-2010, 06:49 PM   #1781
Kenny L's Avatar
Greetings, Luis C.
Luis,
this setup will be pushy in low grip. Funny thing is its not far off what I'm running in asphalt either. Body, top deck, drop and toe are only things I change for asphalt .
I'll be there too looking forward to it
Old 04-12-2010, 11:52 AM   #1782
Send a message via MSN to jontang001
Hi All
I have a question about buying Mi4 parts on internet...
Can someone to have a web store address to me?
Because our local RC stores are pool in Mi4 parts, all you can do is waiting and waiting...
So, please give an advise or a web address to buy such parts that I need!
Thanks!!!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 04-12-2010, 11:57 AM   #1783
Jochim_18's Avatar
Order directly from schumacher...
Old 04-12-2010, 12:02 PM   #1784
Thanks...but...
Is that work? Are they fast?
I never buy anything directly from factory...
Old 04-12-2010, 12:21 PM   #1785
Originally Posted by jontang001 View Post
Thanks...but...
You can buy directly from Schumacher in the UK. at www.racing-cars.com
Steve Walter
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
